Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
Curtailment active The first time we turned on the AC mode on a new Infinity system the control panel said CURTAILMENT ACTIVE.  Don't know what that means but i do know that the AC won't cool AT ALL!!!  All winter the system worked perfectly in heat mode.  Now nothing in AC mode.  What's up? Thanks for any help you might be able to provide. Wilting in SC
  • Anonymous May 19, 2009
    I had this same problem and the fix above worked. Thanks
A follow-up to my previous post. I talked with a technician from the Co that installed my unit, and the issue lies in the "Utility saver mode" for the 2 stage heat pumps, and having the high stage locked out. In the Advanced Setup menu (hold the "Advanced" button for 10 seconds to access this menu, look for the "Utility Saver" menu item. Select it and your system probably shows that "Utility Saver" is enabled, which only allows your heat pump to run on the low stage and not the high stage. If you change the the setting to be disabled, this will allow your system to run at the high stage and should solve your problem.
I have not changed the settings on my system yet to confirm this solution. That will have to wait until I get home this evening.
Posted on May 19, 2008
  • Samuel S WALTERS
    Samuel S WALTERS Jun 07, 2011
    THANKS! It was 92 in Minneapolis today and it got up to 89 inside the house before I found this post which solved my problem immediately.
    So sad that the manufacturer's web site had nothing about this.
I have the same problem and have only found indicators of the cause but no solutions.
From an installation manual found online at: http://www.carrierwest.com/PDF/Operation_Service/24ana-3si.pdf
I discovered this note on page 9:
Utility Interface
With Infinity Control
The utility curtailment relay should be wired between R and Y2
connections on the control board for Infinity Communicating
Systems only (see Fig. 9.) This input allows a power utility
device to interrupt compressor operation during peak load
periods. When the utility sends a signal to shut the system down,
the User Interface will display, “Curtailment Active”.
How do you change out 4 wheel drive switch on 2004 Yukon
Before trying to replace the switch ,are any lights flashing ? 2hi , 4lo, 4hi etc... Do you know which transfer case yours has ?
Transfer Case - BW 4482-NR4
Transfer Case - NVG 246-NP8
How many buttons ?
The BW 4482 transfer case features a 3-button shift control switch located on the instrument panel.
The NVG 246 EAU transfer case features a 4 button shift control switch located on the instrument panel
Before you replace the switch and finding out that it isn't the problem . The switch is a low voltage input to the tansfer case shift control module (A COMPUTER ) Could have diagnostic trouble codes stored .
DTC B0790
DTC B2725
DTC C0306
DTC C0327
DTC C0329
DTC C0359
DTC C0550
Auto part stores can not read these codes .
The BW 4482 transfer case features a 3-button shift control switch located on the instrument panel. When the vehicle has the ignition key in the RUN position, the transfer case shift control module starts monitoring the transfer case shift control switch to determine if the driver desires a new mode/range position. At a single press of the transfer case shift control switch, the lamp of the new desired position will begin flashing to inform the driver that the transfer case shift control module has received the request for a new mode/range position. The lamp will continue to flash until all shifting criteria have been met and the new mode/range position has been reached, or has been engaged. Once the new mode/range position is fully active, the switch indicator lamp for the new position will remain ON constantly. In addition, the switch includes a VSES request button which sends a voltage signal to the transfer case shift control module. The transfer case shift control module in turn sends a request via the class 2 data bus to the ABS control module which controls the VSES system.
The NVG 246 EAU transfer case features a 4 button shift control switch located on the instrument panel. When the ignition key is in the RUN position, the transfer case shift control module monitors the transfer case shift control switch to determine if the driver desires a new mode/range position. At a single press of the transfer case shift control switch, the lamp of the new desired position will begin flashing to inform the driver that the transfer case shift control module has received the request for a new mode/range position. The lamp will continue to flash until all shifting criteria has been met and the new mode/range position has been reached, or has been engaged. Once the new mode/range position is fully active, the switch indicator lamp for the new position will remain ON constantly.
DTC B2725
Circuit Description
The range/mode switch circuit consists of 5 modes. The transfer case shift control module supplies 5 volts to the switch through the 5 volt reference circuit. The current travel through the resistor of the currently active mode. The current is then returned to the transfer case shift control module through the switch signal circuit.
The transfer case shift control module constantly monitors this signal voltage to determine the condition of the mode switch circuit.
When each of the modes are selected they complete a circuit through their own specific resistor. The transfer case shift control module continuously monitors the switch input to determine whether the Neutral, AWD, 2HI, 4HI, or 4LO mode was selected by the driver.
You may want to take this to a repair shop .
Jul 28, 2017 | Cars & Trucks
I have a 2008 Chevrolet Silverado and the warning lights keep coming on telling me AC not working/engine hot ,, ??
ENGINE HOT TURN A/C OFF
Cooling System Description and Operation
ENGINE COOLANT HOT
The instrument panel cluster (IPC) displays ENGINE COOLANT HOT message when the IPC receives a class 2 message from the powertrain control module (PCM) requesting illumination of this driver warning.
ENGINE OVERHEATED
The IPC displays ENGINE OVERHEATED message when the IPC receives a class 2 message from the PCM requesting illumination of this driver warning.
DTC P1258: Engine Coolant Over temperature - Protection Mode Active
Have it check
Mar 03, 2017 | Chevrolet Cars & Trucks
Changed the dashboard switch for 4wd. That didn't work. Still cannot get into 4wd.
The NVG 263 transfer case features a three button shift control switch located on the instrument panel. When the ignition is in the RUN position, the transfer case shift control module (TCCM) starts monitoring the transfer case shift control switch to determine if the driver desires a new mode/gear position. At a single press of the transfer case shift control switch, the lamp of the new desired position begins flashing to inform the driver that the TCCM has received the request for a new mode/gear position. The lamp continues to flash until all shifting criteria has been met and the new mode/gear position has been engaged. Once the new mode/gear position is fully active, the switch indicator for the new position remains ON constantly. In the event that the TCCM can not or will not complete the shift, the indicator returns to the previously selected position; this is a Transfer Case Shift Control Switch Indicator Flashes, then Returns to Previous Mode condition.
The New Venture Gear model NVG 246 RPO NP8 transfer case is a two speed automatic, active, transfer case. The NVG 246 EAU provides 5 modes, Auto 4WD, 4HI, 4LO, 2HI and Neutral. The Auto 4WD position allows the capability of an active transfer case, which provides the benefits of on-demand torque biasing wet clutch and easy vehicle tuning through software calibrations. The software calibrations allow more features such as flexible adapt ready position and clutch preload torque levels. The technology allows for vehicle speed dependent clutch torque levels to enhance the performance of the system. For example, the system is calibrated to provide 0-5 ft lb of clutch torque during low speed, low engine torque operation, and predetermined higher torque for 40 km/h (25 mph) and greater. This prevents crow-hop and binding at low speeds and provides higher torque biases at higher vehicle speeds, in order to enhance stability.
Mar 26, 2016 | 2004 Chevrolet Silverado 1500 Crew Cab
If I lock my 2006 Chevy Cobalt, the security system will randomly lock and unlock the doors accompanied with the horn honking
I think you have a BCM - body control module problem ! The BCM controls the automatic door locks .
Automatic Door Lock Operation
This BCM controlled feature can be personalized to driver preference. Refer to Power Door Systems Connector End Views Personalization Description and Operation in Personalization.
The BCM will automatically lock the vehicle doors if the following conditions exist:
All vehicles doors are closed.
The ignition is in the ON position.
The vehicle is shifted out of PARK.
The BCM will then unlock the doors when the ignition is placed in the OFF position. Do the exterior lights flash as well as the horn sounding ?
Body Control Module (BCM)
The
Content Theft Deterrent
system is an internal function of the Body Control Module (BCM) which utilizes class 2 serial data and various switch input information to perform CTD functions. When the BCM detects an unauthorized entry, it activates the horns and exterior lamps.
When the BCM detects an unauthorized entry, the BCM enters the alarm mode. The BCM activates the horns and exterior lamps for 2 minutes. This is followed by a 3 minute time-out with the horn no longer active. If no new intrusions are detected after the time-out, the horn is not active. The system must be disarmed or the intrusion condition removed after the time-out for the system to exit alarm mode.
Dec 23, 2015 | 2006 Chevrolet Cobalt
My hydroquip cs6230-u pack on my hot tub shuts off for days and comes back on. None of the circuit breakers pop. The cold weather is coming and I don't want any pipes to freeze. I would also like to u
I do not know this unit so this is only a guess on my part.
I am not sure what you are by it shuts off for days. If it is hot that may also cause it to shut down but for less then an hour. The manual can be found by googling:
hydroquip cs6230-u pack manual
Several of the manuals show up. Be sure CGFI is OK.
This is what I found in the manual. Measure your water temperature it may be OK.
FREEZE PROTECTION - There are two(2) levels of freeze
protection integrated into the system.
1 - SMART WINTER MODE, this mode will activate any time the
temperature falls below 59BF. This mode will be active for a period
of 24-hours. In this mode, if a pump has not been activated in the
last 2 hours, the system will automatically turn it on for 1-minute
to prevent freezing. The "Filter Cycle" indicator will illuminate
while this mode is active.
2 - If the spa water temperature drops below 49BF, the heater &
pump will be activated until the water temperature reaches 50BF.
While freeze protection is active no other functions will be
possible.
Nov 28, 2014 | Cars & Trucks
I have a MOD 600 alarm, installed about 9 years ago. Every time I pass a sensor the alarm makes three beeps. How do I stop it?
Hello. This is a normal response to the motions detector while people are active within the home.
The alarm is a semi active mode that is the motions detector will beep, if a door is open there could be active voice alarm or beeping from Central alarm within the home. The same will happen if a window is opened, beep,beep,beep.
In this mode it lets the home owner while in his/her home that the alarm is on and it will let you know when the doors, windows or floor pressure sensor is activated.
There another mode for the alarm system that is if you have pets. It can be activated that only things that are inactive is the motion and pressure sensors. They beep but will not execute the full alarm system.
The there is full alarm system activation where every sensor is operational----full Alarm On....
Now, if you don't like the beeping, then you can turn the alarm system off while you or your husband is in the home. But it will not notify you if the door, window, motion, pressure sensor are activated. I hope this help you. GB....stewbison
Aug 24, 2011 | Kitchen Ranges
Script error, active desktop in recovery mode, how do I fix script error says line 65
PLEASE LET ME KNOW IF THIS HELPS AT ALL
How to enable / disable windows active desktop. Question:How to enable / disable windows active desktop.
Answer:Microsoft Windows XP users
  1. Open the Control Panel.
  2. Open the Display icon.
  3. Click the Desktop tab.
  4. Click the Customize Desktop button.
  5. Click the Web tab in the Desktop Items window.
If you wish to enable the Active Desktop, check My Current Home Page.Add your current home page into your desktop or click New to addanother web page and/or other Active Desktop features. To update thecontent, click the Synchronize button.
If you wish to disable Active Desktop, make sure all checkboxes in this window are un-checked.
Nov 09, 2009 | Compaq Presario 5000 PC Desktop
Fisher Paykel Active Smart fridge turned into storage unit by power surge
I would unplugg the machine for 5 minutes, plug back in again and close the freezer door, open fridge door and press the mode button
Jun 22, 2008 | Fisher and Paykel Active Smart® E522BR...
SAFE
Pro-Tect Plus™ Locking Feature
To disable VCR usage or to protect set timer recordings, the unit can be locked so that the
buttons on the VCR or remote control don’t work.
• To Lock: Press and hold either the remote control’s ON•OFF or VCR button until SAFE
appears in the display to indicate Pro-Tect Plus is active. SAFE also appears if the VCR is
turned on while the feature is activated.
To Unlock: Press and hold either the remote control’s ON•OFF or VCR button until SAFE
disappears from the front panel display. Unlocking is the only way to use the VCR.
May 10, 2008 | Televison & Video
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
3,009 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
