Question about Sport & Outdoor - Others
I have a 1993 Four Winns 180 Freedom with 115 HP Johnson outboard and a fish and ski package. The boat is in excellant condition and has less than 50 hours running time. It was serviced awhile back and was running good. On my last outing the alarm horn started doing regular long beeps and the motor would not get further than mid speed and cut out if attempting to go faster. Also the speedometer was not registering anything even though the tach, fuel, trim etc. was operating. Any suggestions of how to trouble shoot? Anyone have some type of wiring schematic for the dash to make sure some connection isn't loose or detached?
captainjeffq
  • 52 Answers
SOURCE: 1974 60hp johnson outboard won't run on full throttle.
Carbs probably need to be cleaned and re-built. Common problem in outboards that havent been run in a while
Posted on Apr 13, 2009
  • 6 Answers
SOURCE: 1974 johnson outboard motor 25hp stalls when hiting high end
Not familiar with that specific motor but had similar vintage smaller HP Johnsons. From my experience it sounds like it could be that the high speed carb adjustment is too lean. What I would try is running the backing off the high speed screw 1/4 turn to 3/4 turn, then test. If works better, screw back in in 1/8 turn increments until the problem recurs, then back out 1/4 turn and leave it there.
Posted on Jun 30, 2009
finish line
  • 207 Answers
SOURCE: johnson 1998 175 hp motor seems to be in safe mode
U CAN DISCONNECT THE OIL RESOVIOR SWITCH THAT TAKE IT OUT OF SAFE MODE BUT IM LEANING TOWARD THE POWER PACK
Posted on Jul 13, 2009
thehumble1
  • 137 Answers
SOURCE: 1985 40 hp Johnson outboard wouldnt open up and
sounds like your mix is off and it's fowling the plugs. probably too rich. make sure the level in your carb bowls isn't too high. Really sounds like you should clean and bench set your carbs. Especially if a plug change helps but doesn't last, then it's got to be your fuel mix, or maybe timing.
Posted on Jul 24, 2009
SOURCE: Boat engine 1995 Johnson Outboard 70 HP
Ihave a 1991 70 hp Johnson outboard thats hard to start the first time but starts good after that. Seems to be flooded. Starting rpm seems to be low.
Posted on Jul 25, 2009
Looking to repower 1997 Four Winns bowrider with newer outboard engine. What max HP is boat rated for? Found Yamaha 150 XB 2016 for a good price . Will boat work with a 25 inch shaft? Thanks,Kathy
there should be a manufacturers plate attached to the hull of the boat with a number of passengers it can carry and the max hp motor allowed to be fitted
talk with boat shops as they will know the approximate hp for each make of boat and length
while it may be attractive to fit big hp motors to small boats , it in fact makes the boat less sea worthy and makes capsizing easier so get the advice right from the boat shops
Feb 07, 2017 | Yamaha Boating
What is the idle timing for 1993 90hp evinrude
90 hp 1993 evinrude idle speed - MarineEngine
www.marineengine.com > ... > Johnson Evinrude Outboard Archive
Aug 3, 2008 - 2 posts - ‎2 authors
"How many rpm should the engine idle at,and where and how do you adjust it Thanks" 50 hp evinrude no idle and no top speed need assistance ...
Jul 6, 2013
1993 50 HP 2 cyl Evinrude stalls, runs at idle when ...
May 7, 2012
adjust carburators and idle speed 1993 48hp
Jul 29, 2010
90 hp stalls when going in gear
May 21, 2010
More results from www.marineengine.com
1993 Johnson 90-HP Runs Only At Idle Speed On Spring Start-Up
Johnson 1993 115 xflow Link and Sync - YouTube? 4:55https://www.youtube.com/watch?v=ReeuaVh8uZQNov 25, 2012 - Uploaded by Brian O'DellJohnson 1993 115 xflow Link and Sync. Brian O' ... Also if you can give me some details on how you got the ...DOWNLOAD Evinrude 90HP (90 HP) Repair Manual
Dec 14, 2015 | Boating
How do I change the starter in a 1988 Four Winns 180 Horizon 3.0 liter 4 cylinder engine
Disconnect the battery then remove the wire off the starter , remove the bolts that hold the starter to the engine !
Bolts might be across ways or come upwards ! Pending what modle /make of engine you have !
Sep 29, 2014 | Volvo Starter, Mercury, Force Jet Boat,...
1991 four winns boat gets stuck in a gear
What engine, drive, outboard?
Aug 21, 2014 | Boating
Video on how to replace a water pump for 1993 30hp johnson
One of these videos on YouTube may work for you
http://www.youtube.com/results?search_query=johnson+30hp+outboard+water+pump
Jun 25, 2014 | Boating
115 hp johnson great difficulty to cold start,sometimes it even run the baterry flat but once it started there is no problem in starting again what could the reason for this be or do i just start the...
Hello vcd9,
When You Turn The Key On ,Press It In To Activate The Choke Solenoid And Then Crank At The Same Time,This Should Solve Your Problem, If All Is Fine With The Engine.
Cheers
Gordon
Feb 11, 2013 | Light Outboard Motor Boat Bass Fishing...
Fuel oil mixture for 1986 mercury 115
I own a small Mercury outboard so I did alittle reading in the manual and the ratio for your 86' 115 HP is 50-1. Hope it helps. Coach Theune
Oct 25, 2009 | Boating
Looking for a starter solenoid wiring diagram
save yourself some money and go get a lawn mower solenoid and find a way to mount it yourself. I have done a johnson outboard and a tigershark jet ski this way with no problems.
Jun 18, 2009 | Boating
Sport & Outdoor - Others Logo
153 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
