Question about Sharp LC40E67U 40 in. HDTV LCD TV
Need to find a flat panel replacement for my lc-40e67u.
  • 11,361 Answers
That will be really expensive (more than the TV is worth), LCD panel is a limited production part and it is the most expensive part of the TV, you can try contacting www.shopjimmy.com to see what he has.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Sep 03, 2010
How do I replace fuse?
Sharp LC46D43U - Aquos - 720p LCD HDTV Service Manual
www.manualslib.com > ... > Service manual
Flat Panel TV Sharp AQUOS LC-46D82U Operation Manual. Sharp flat ... Flat Panel TV Sharp LC46SB54U - LC - 46" LCD TV Operation Manual. Operation ...
Sep 11, 2015 | Sharp Televison & Video
Why my tv is working and after 15 minutes shut down and star 1 minutes later
This problem is often caused by overheating of a part inside the TV. There are two kinds of overheating: the whole set is getting too hot; or a part inside the set is heating up because it is failing. When the set or part gets hot, the set shuts down, then restarts when everything cools off. So first, if you recently moved the TV to an enclosed space (like a cabinet), try pulling it out of that space into the open air. If the problem goes away, you need to provide more ventilation in the cabinet. If the problem does not go away, then there is something wrong inside the set, and you should have a service professional diagnose the problem right away -- overheating TV sets can start fires! Once you know what's wrong and how much it will cost to fix, you can decide whether to repair the set or buy a new one.
There is one other possibility: the software program in the set has gone bad and needs to be reinstalled. You can download new software at:
http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx?model=LC-40E67U
This is not likely to be the cause -- as I said at the start, it sounds like an overheating issue -- but it might be worth a try.
May 01, 2014 | Sharp LC40E67UN TV
Lc-40e67un sharp aquos. Power light is blinking in a constant rhythm with no variation. I tried the volume - and input reset. I saw a flash of the channel number and a gray screen for 1 second. Went right...
How many times do this standby light blinks at one time switch On? Count it carefully. These are called blinking codes, and from the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. If you wish to get more details about these blinking codes, check this link.http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 23, 2013 | Sharp AQUOS LC-40E67U 40 in. LCD HDTV
Sharp aquos LC-40E67U HDMI board KF030 XFO30WJ red light on the HDMI board.
Normally, these board have no repair. It will be best to replace it.
Jun 06, 2013 | Sharp Televison & Video
Sharp lcd flat panel won't power up.
You will most likely need to replace the power supply. This is a very common problem now days, especially with newer electronics.
Aug 24, 2009 | Televison & Video
Picture Problem with Sharp LCD Model LC-42D43U
Hi...there,
It's seems your backlight inverter are busted... Need to replaced a new one.
Oct 15, 2008 | Sharp LC-42D43U 42 in. LCD HDTV
Replace protective platic panel in an lcd tv
unfortunatly the protective screen is not available as a seperate part, it is the whole LCD panel that needs to be replaced. if the TV is the LC-42d62U then the part number is R1LK420D3LF21 and can be found at www.vancebaldwin.com for $2362.80.
May 10, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp LC40E67U 40 in. HDTV LCD TV Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
