Question about Plantronics Radio Communications
I have been using Plantronics 995 for several weeks. I quit working without any system cnanges. Have tried re-paring, and reset all audio settings to plantronics. Bought replacement unit ( plantronics 995 ) - is has same problem - if vol is turned to max I can hear slight static Any suggestions
  • dlo_odell Sep 03, 2010
    I think I may have not stated the problem correctly. The problem is that I 'can not hear anything through the head set". The mike has not been the issue , as I do not use it routinely I have not tested the mic function. The only thing I can hear is a very slight 'static' type noise if I turn the speaker volumn up to max. The speakers work fine if there is nothing pluged into the head phone jack, and I have pluged in another basic head set ( wired unit ) to the jack and it works fine.
  • 4,924 Answers
This is a normal reaction ..specially on a wireless device ..the idea is to lower the volume into the computer ..(to max 80%)..and also get into the volume control by double clicking on the speaker icon in the task bar ..and in here look at the mic volume
if there isnt any volume section for the mic..than click options ..than properties..and from the list tick the case for mic in ..and will list the volume for mic..
if the advanced function is on ..check into the advanced under the microphone it is started the mic boost function ..if it is ..and you want to keep it for a better mic reception ..than you have to put the mic on mute to eliminate the static noise..
THis should not mute it for good..but you can make a trial to be sure..
If the advance boost function is on ..and the muting puts it out for good..the choice is to get rid of the boost but usually works if you mute it ..cause only mutes the noise ..
let me know if you didn't understood anything ..
Posted on Sep 03, 2010
  • Catalin Turcu
    Catalin Turcu Sep 03, 2010
    In this case you have to see if any of the devices are out of battery ..in this case the emitter that plugs into the inlet ...
    or ...just push those button to pair them again ..like the first time you set them ...cause if it has sound on a regular headset it means that it is nothing wrong with the computer and it is a n issue of signal transmiting between the 2 devices..so check the batteries.first ...(they might not work if they are almost empty) ..and after that pair them again ..Usually the device shave some buttons that have to be pushed in for one to blink ..and in one to find the signal..I thing when the signal is located they change color or something like that ..Take a look in the manual for exact procedure..but it is something like in a wireless mouse....
    anyway ..is the only thing you can do to try and trouble shoot them ...cause if this isnt working ..I mean battery changing and re-pairing than it is something physical wrong and you will need to be seen by a repair-man ..
Plantronics audio 995H wireless headset not charging when plugged into computer. It does not show a red light for charging. When turned on it stays blue for several seconds then flickers red for 2 or
38cafd7a-6060-4717-bc4f-b4db91cc266a.jpgI recently fixed my 955 headphones... it's probably not going to be attempted by most folks, but it saved a great set of headphones from being tossed and replaced.
Basically you need to remove the right side padding and take out the 3 screws. This gets you access to the battery. The battery is a standard 3.6V lithium battery. Pretty much the same that is in most cell phones and many small toys. You can simply replace the battery with something like:
http://dx.com/s/3.7v+li
Or... here's what I did... add a lithium USB charger to the battery.
http://dx.com/s/li+arduino
Now, if the battery dies I can plug it into USB and the phone will work while it charges.
Nov 12, 2013 | Plantronics .Audio 995 Digital Wireless...
CAN I GET A REPLACMENT USB FOR MY PLANTRONICS 955H?
No plantronics have replaced 995h a model with 995h b model.
They use different dongles. Very good reason to hack the protocol
Jul 31, 2012 | Plantronics .Audio 995 Digital Wireless...
Recently my headset does not turn on. I thought perhaps it needed to be charged, but even when plugged in none of the lights come on. After charging over night, it still did not turn on. It worked fine...
Have you seen this FIXYA Link?
Plantronics audio 995H wireless headset not charging when plugged into...
Or could be your tiny "POWER" button-switch has gone bad"? Or perhaps a actual battery 'hard failure'?
Here is part of the text:
The 603443 next to its replaced counterpart. The new battery is a 850 mAh lithium polymer battery while the original is a 500 mAh lithium ion. Sweet!
See the Link about Battery Replacement...
While you are in there try a Q-Tip with a tiny-tiny dab of contact cleaner sprayed on the Q-Tip... now try to apply some cleaner right to the Power Switch CONTACTS.
*** BE SURE TO USE A CONTACT CLEANER THAT IS "PLASTIC SAFE"!*** and with silicone is better.
Plantronics 995H battery upgrade
Anthony
Dec 24, 2017 | Plantronics .Audio 995 Digital Wireless...
MY VOYAGER PRO .. LIGHT FLASHES BLUE RED BLUE RED ... CAN'T TURN OFF, CAN'T RESET, CAN'T RE PARE
If you manually turn the headset off, make sure that it is by itself, no other phones in the area, no WiFi hotspots. Once this is done make sure that there is not a bluetooth already installed on the phone itself, if there is, delete it. Make sure that the headset has a full charge. Try the pairing again. If this still won't work, you can try Plantronics Tech service line 800-544-4660.
Here are two links that may be helpful:
Plantronics Voyager Plus User's Guide
Plantronics Voyager Plus Pairing Instructions
Good luck from Headsets Direct!
Jun 04, 2011 | Plantronics Voyager PRO Bluetooth Headset
My Plantronics .Audio 995 wireless headphones refuse to charge with the cord provided me or any other one I substitute it for.
It sounds like the battery is dead in the headset. That headset has a non-replaceable battery. If the .Audio 995 is still under warranty you should have it replaced. I have included this link to the Plantronics .Audio 995 User's Guide.
Apr 16, 2011 | Plantronics .Audio 995 Digital Wireless...
Can one get the plantronics audio 995 USB headset (with microphone) to work with the PS3? The headset uses 2.4GHz, not bluetooth, so it's not a bluetooth pairing issue.
I believe it should work...
You may want to review this guide for connecting a bluetooth headset to a PS3:
(Click here)
http://boardsus.playstation.com/playstation/board/message?message.uid=26900460
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!!
Dec 14, 2009 | Plantronics .Audio 995 Digital Wireless...
Computer can't discover wireless device
I want to use it on a PS3. Can I and if so, I've lost my pin#. How can I find out what it is?
Nov 08, 2009 | Plantronics .Audio 995 Digital Wireless...
My new headset
If you are using windows XP -- as unreal as it sounds just plug the device in and allow the Plut and Play installer to do it's thing -- it will appear as a device without a driver (in the device management list) but it will generally work. I have tried it on an HP machine and the control panel for sound and audio devices voice tab (as well as the audio tab) needs to be set to the plantronics device, too -- if you use the sound icon in the system tray the device seems to reset periodically to the one in the sound and audio control panel (just learned yesterday). The headset control on the wire -- the mute button (red illuminated button) has ceased to work for some time (possibly around the Service Pack 2 update) but the volume control does seem to work.
Nov 29, 2007 | Plantronics DSP-400 Headset
Radio Communications Logo
648 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
skiffy99
skiffy99
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
