Question about Avanquest Fix-It Utilities 9 Professional for PC
I had to reinstall Windows 7. I put Fix-it 9 on a flash drive. When I tried to reinstall Fix-it, I got the message that the serial number could not be found in the registry. How do I obtain a new serial number.
    President:
  • 2,678 Answers
Presumably you purchased online in which case conact the vendor who will have a record of your purchase, email and serial.
Posted on Sep 03, 2010
How to fix please insert disk into removable disk
W 7
First, please disconnect all USB devices and then perform the following steps: Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for XP or earlier
Click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
Jan 04, 2014 | A-Data Technology Computers & Internet
My sandisk 8gb cruzer micro flash drive is not recognised, plug into my macbook or dell, lights up for second, flashes on screen, then off
W 7 First, please disconnect all USB devices and then perform the following steps:
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. for XP or earlier click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
Hope it helps.
Jan 08, 2013 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Can't read micro usb drive
error 43 is a usb universal serial bus controller problem
click start control panel administrive tools ,computer management ,device manager scroll down
universal serial bus controllers you should see a yellow question / exclamation mark? ! or a red X
right click to reinstall drivers or
ports(com&lpt)right click update driver
for windows 7 you might try
First, please disconnect all USB devices. Then, go through the following steps:
1. Press "Ctrl + Esc" to open the "Start" menu.
2. Type "devmgmt.msc" in the Search bar and press "Enter". Click "Continue" if necessary.
3. In Device Manger, press Tab and use "Up" and "Down" to move the highlight to "Universal Serial Bus Controllers".
4. Press "Right" and expand it.
5. Press "Down" to move to the first item and press "Delete" to remove it.
6. Repeat the step 5 and uninstall all items under "Universal Serial Bus Controllers".
Then, restart your computer and Windows 7 will reinstall all controllers automatically.
hope this helps
Oct 14, 2012 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
The computer won't boot Windows 7. It starts up fine, with the fans running with the LED lights on. Then I get an error message: "CD-ROM Boot Priority ..No Medium" I have checked the bios of...
It sounds like either Windows 7 did not install properly or you have a bad hard drive. I did some research on similar problems and most people have also tried to change the boot priority with no luck. If your are tech savvy I would try to run hard drive diagnostics and possibly reinstall Windows 7. If you are not very technical I would suggest taking it to a competent pc repair technician.
Apr 08, 2011 | Systemax SYX Crossfire X58 Gamer Intel...
Adobe flash player installation; though the message is received that i have installed successfuly, flash is not installed
Try to uninstall the Adobe Flash Player Active X and Plug in and then reinstall it as there could be traces of previous versions in the computer which are interfering and making it difficult for the browsers to properly display videos on your computer. You can do this from the computer user settings and manipulating the "Add/Remove" programs list.
-- Try to use Flash Player 9 is your Flash Player 10 is not working fine. You can simply download it from the Adobe web site.
-- Update the drivers, the link is given below which would ask you to download the file through internet and run it on your computer.
-- The problem behind the Shockwave Flash crash could be your sound drivers. Follow these steps:
1) Open Device Manager 2) Look for the sound-card device 3) Note down the name for that device 4) Just uninstall the it. 5) After uninstalling restart your machine. 6) Your Windows 7 or Windows Vista would automatically download and reinstall the sound driver. You can also do it manually through approaching the sound card company's web site.
-- Fix your Windows Registry which is a highly recommended thing you should do to find a quick and reliable fix for common PC errors and crashes.use registry cleaner reginout
Oct 09, 2010 | Dell Inspiron E1505 Notebook
I have a lot of info that I need on my Flash drive but every time I put my Flash Drive in my computer or the other computer in the living room, it always says. You need to format the disk drive J: before...
Better you check the drive at your neighbours system (should have original antivirus) and scan for any viruses...
My better advice is dont keep any valuable info on your flash drives better make always a backup...
and always do safely remove of your flash drives (a green arrow at the right bottom of the screen)
if there is no possible way to connect the drive then try to recover your valuable data with stellar recovery centres...
Sep 18, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
"Plsase insert a disk in the drive" message for USB drive
Up to you,, if you put a flash drive into your USB port, and windows see's the drive, because its listed under my computer, but when you go to open the drive it says, please insert disk
This is telling you the flash drive has failed.
The only good thing is, if you have anything on the drive, there are programs that will extract the data from the drive so you don't lose it.
You have three options,
Extract the data that is on the drive.
Try a repair program, which can erase the drive when it tries ti repair it.
Send the flash drive to the company for repair.
Feb 16, 2010 | Kingston Technologies 512MB DataTraveler I...
I would like to scratch-install the new WINDOWS 7 on the TOSHIBA P105-S6114. Is this okay? Are there any problems I may encounter?
ecommended Windows 7 Installation Method SelectionToshiba provides support for installing Windows 7 on laptops built since 2007. Depending on your model, Toshiba recommends using one of the following software tools as part of the Windows 7 installation process, to support ongoing use of Toshiba provided features and functionality:
  • Toshiba Upgrade Assistant for Windows 7, for upgrading from Windows Vista to Windows 7 on laptops made in 2009
  • Toshiba Software Installer for Windows 7, for performing a Custom Installation of Windows 7 ("clean install") on laptops made 2007-2009
Find your laptop's serial number on a sticker on the bottom of the laptop, note the second character in that serial number, then click on the matching link in the list below for instructions on Toshiba's recommended Windows 7 installation method for your model.
For all laptops made since January 1, 2007*
When upgrading from Windows Vista (not a Custom or "clean" Install)
  • if the second character of your laptop's serial number is 7 or 8, click here.
  • if the second character of your laptop's serial number is 9, click here.
When upgrading from Windows XP, or doing a Custom Install ("clean install") from any operating system
  • if the second character of your laptop's serial number is 7, 8, or 9, click here.
  • if the second character of your laptop's serial number is not 7, 8, or 9 then it was manufactured prior to 2007.*
* Installation of Windows 7 is not supported by Toshiba for laptops made prior to 2007.
Hope it helped.
Nov 21, 2009 | Toshiba Satellite p105-S6114 Notebook
Pendrive light not blink error massages.
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. for XP or earlier click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts if you need more help with this or if i have missed the problem post a reply
Apr 06, 2009 | Kensington Electronics - Others
Avanquest Fix-It Utilities 9 Professional for PC  Logo
120 people viewed this question
Top Avanquest Computers & Internet Experts
Alun Cox
Chris Larocque
Are you an Avanquest Computer and Internet Expert? Answer questions, earn points and help others
