Question about Quasar HQ2101SH Air Conditioner
The compressor does not always come on, and the lights dim. Do they make a hot start that I can attach to the capacitor for this unit.
Why is it not cooling?
compressor trying to start but not starting replace capacitors.
Aug 20, 2015 | Windchaser PACR10 Portable Air Conditioner
I have a Dometic 57915.531 air conditioner in my camper. When the compressor goes on the lights go dim. Then if left on it will trip the circuit breaker. When I reset the breaker and turn the AC back on...
The compressor is not always starting...sometimes it tries but does not start...
It could be a capacitor and relay problem... or the compressor could be going bad...
Change the capacitor and start relay first and then see if that gets it going...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Aug 04, 2010 | Dometic 57915531 Air Conditioner
Hello i have Carrier Weathermaker 38tkb air conditioner unit. It's about 6 years old and when i got home today, the unit itself wasn't working. Although the blower fan in the furnace inside was blowing,...
The humming noise and dimming of the lights is an indication something in the outdoor unit is locked up or has failed.
Check the capacitor as it may have gone bad. If the capacitor is good, then you either have a failed motor, a failed compressor, or both.
Jul 07, 2010 | Heating & Cooling
Fan runs but compressor won't start. Compressor tries to come on every couple of minutes, dimming lights when it does, then stops. The other unit starts and runs just fine. The problem started just...
You could start by checking the capacitor. Then use an ohmmeter and check the fan windings. Hook one meter lead to com lead. Then hook the other meter lead to the run lead and then the start lead, reading the resistance each time. Then read from each to ground (compressor case). You could also use an ammeter to check the current draw when it starts. Hopefully it's just the capacitor.
May 31, 2010 | Dometic Rooftop RV Air Conditioner
My freezer is not working properly with clicking sound.
The clicking sound is probably the compressor relay trying to start the compressor. When the lights dim, the compressor is trying to start and hence, pulling power from the rest of the unit. If the compressor has a start capacitor, that could possibly be the problem. If not, the compressor itself should be replaced.
Mar 26, 2010 | Maytag MSD2454G Side by Side Refrigerator
My window a/c dims the lights on the same curcuit
No major service...not for the AC any way.(Read on) It is normal that lights will dim if on the same circuit with an air conditioner. When the ac is set to cool the compressor will turn on and off as it should. The compressor takes more amperage to start, that is the reason it needs a fairly large capacitor to help it out. Once it's started your lights return back to normal brightness right? Where you might have major service though is if and when you call a certified electrician to run wire for a new outlet for your ac which should always be on a circuit of it's own, but for a better reason than lights dimming...the safety of you and your family.
Jul 31, 2009 | Heating & Cooling
If everything works on the roof top unit; all the power is on and the lights dim when the compressor kicks in, so do you think it needs to be rechaged?
Probably not. Does it trip right away or after it runs a while? Check all your wiring connections at the unit including under the compressor terminal cap. Make sure your fan spins free & is lubricated. The condenser on the roof top could be dirty. A capacitor on the compressor could be weak or failing. It is possible there is a refrigerant leak that caused the compressor to run hot and start to draw high current as a result though.
Jun 28, 2009 | Dometic Rooftop RV Air Conditioner
My air con is not sending out any hot air.
chances are your compressor is locked up and drawing high amps (dimming lights) then the internal overloads inside the motor windings are opening. you should probably hear the compressor hum for a second then stop. Also if you were to touch it, it would be extremely hot. If this is what seems to be the problem, you need a new compressor or replace the whole unit.
Jun 11, 2009 | Heating & Cooling
Home unit 3 ton won't run
The small capacitor is for the fan motor the other for thecompresor .You can try conecting a booster (or hot start) in paralel to the comp.capacitor .If this doesnt work you have to replace the compresor.
Mar 29, 2009 | Heating & Cooling
PDS22SBSALSS Clicking Noise/ Temperature Control Panel
Your start relay and condenser are defective, it would appear. They are there to 'kick' the compressor into starting. They should then click off and reduce the power sent to the compressor. When they don't, you get the dimming lights. See your local library for any service information they may have on the shelf. Your issue should not be model specific. About the control panel, cycle the connectors. You may catch the problem.
Jan 23, 2008 | GE Energy Star PDS22SIS Stainless Steel...
Quasar HQ2101SH Air Conditioner Logo
24 people viewed this question
Top Quasar Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Quasar Heating and Cooling Expert? Answer questions, earn points and help others
