Question about Coleman Powermate Premium Plus 6250W Portable Generator
We bought a Black Max with a Honda motor Model #10700DR from Sam's Club today. It is missing the fuel cap, the key for the electric start, the oil plug and the owner's manual. Where can I obtain thes items and what will be the cost. Unfortunately, it was the only generator they had with the Honda motor which is why we went ahead and bought it even missing those items. I could not find generators on the list of experts so if I am sending this to the wrong person, please forward to the correct expert. Please help! Thanks Bev
SOURCE: oil type and capacity
Use 10/30 weight oil fill till : " if it has a "dipstick" fill to middle of hash marks" if not, There in the hole for the oil filler cap their is a knotch cut out of the theads for that cap. fill to just below the top of that knotch . drain plug on bottom of crankcase
Posted on Sep 01, 2008
SOURCE: looking for manual for generator...won't start
I had the exact same problem. There a few things you need to do first.
1) Make sure the fuel line knob is turned to the Open position; this knob is located under the gas tank.
2) Turn the power switch to on : it is a little red switch located near the pull-handle on the front of the generator. It needs to be on 'I' not on 'O'
3) Turn the choke lever on: it is a little steel lever with an arrow at the tip. Move the lever in the direction the arrow is pointing.
4) Make sure you have gas left in the tank: it may have evaporated or gummed up if you did mix in a fuel stabilizer before putting it away for storage.
If none of these things work , then you carburator may be full of water and gas lines gummed up.
These Gens need to be started up at least once a month to make sure they keep working properly.
Fred
Posted on Nov 19, 2008
  • 3 Answers
SOURCE: coleman powermate 4000w commerical electric generator
Try here
http://www.arkansas-ope.com/COLEMAN_POWERMATE_GENERATOR_IPLS_LISTING.html
Posted on Nov 23, 2008
CarlGehrke
  • 169 Answers
SOURCE: need oil type for generator & motor for 5000 power mate
Unless you're in very cold locations use SAE 5W30 regular motor oil.
Posted on Dec 03, 2008
plkruger
  • 32 Answers
SOURCE: I HAVE A GENERATOR THE MOTOR SURGES ONLY WHEN LOAD ARM IS CONECTE
replace the pink plastic jet and two O-rings (center of carb) and clean out the shaft they are in with Q-tip and solvent, blow out with compressed air prior to assembly, make sure a old O-ring is not down in the hole as this is a very common mistake made by many who make repairs, one O-ring will remain in the shaft after you pull the jet out. 4 out of 6 gens that surge have this problem especially if you hear a small amount of backfiring . the bottom jet must be very clean as well if it is the newer model without the thumb screw.
Posted on Feb 04, 2009
1996 honda accord won't start. drove 40 miles each way on friday and parked car .. first 40 miles was all stop and go traffice second 40 we took freeway all the way and just paid tolls, woke up sat...
There are several things that could cause this problem. First is when was the last time you replaced the fuel filter? Next thing you need to do is open your radiator cap to see if there is oil in your coolant and also pull your oil dipstick to see if there is any white stuff on the bottom of the dipstick. If either of these things are true then you have a blown head gasket. The last thing could be a bad coil or even engine control unit (ECU). Good luck.
Jan 12, 2014 | 1996 Honda Accord
I have a 1990 mitsubishi might max it wont run smooth unless you keep your foot on the gas and keep the rpms up a little bit and it wont drive cause it stalls everytime you try to move it. ive replaced the...
You've already eliminated the spark plug & wireset, distributor cap & rotor.
Sounds like your car needs a tune-up, specifically, the PCV (positive crankcase ventilation) valve, and/of the EGR (Exhaust Gas Recirculation) valve.
Components checked/replaced during a tune-up are:
air filter
motor oil
motor oil filter
breather filter
fuel filter(s)
fuel strainer
PCV valve
EGR valve
spark plugs
spark plug wires
ECM or distributor cap & rotor
cabin air filter
transmission oil filter
transmission oil
engine coolant
check all vacuum hoses and lines
Troubleshooting the no-start condition - from the 1990 Mitsu Mighty Max Repair Manual:
Priority Action Part Type -- Cause
1 Inspect Battery -- Battery Discharged or Faulty.
2 Inspect Battery Cable -- Corroded, Broken, Shorted or Poorly Connected Battery Cable.
3 Inspect Distributor Cap -- Distributor Cap Cracked or Burned.
3 Inspect Fuel Filter -- Clogged or Dirty Fuel Filter.
5 Inspect Ignition Coil -- Faulty Ignition Coil.
6 Inspect Wireset -- Worn, Damaged or Faulty Spark Plug Wire(s).
7 Inspect Spark Plug -- Incorrectly Gapped or Fouled Spark Plug(s).
8 Inspect Starter -- Starter Motor Faulty.
9 Inspect Fuel Pump -- Low Fuel Pressure.
10 Inspect Solenoid Switch -- Faulty Starter Solenoid Switch.
11 Inspect Fuel Pump Relay -- Faulty Fuel Pump Relay.
12 Inspect Fuel Injector Pressure Regulator -- Faulty Fuel Injector Pressure Regulator.
13 Inspect Ignition Switch -- Improperly Connected or Faulty Ignition Switch.
14 Inspect Starter Drive -- Faulty Starter Drive.
15 Inspect Fuel Injector -- Dirty or Worn Fuel Injectors.
16 Inspect Fuel Pump Strainer -- Clogged or Dirty Fuel Pump Strainerat.
17 Inspect Engine Control Computer -- Incorrect Operating Information Being Delivered and Sent From The EEC.
18 Inspect Fuel Tank -- Fuel Tank Empty.
19 Inspect Carburetor -- Carburetor Flooded or Faulty Choke.
20 Inspect Distributor -- Worn, Loose, or Incorrectly Installed Distributor.
Aug 17, 2011 | 1993 Mitsubishi Mighty Max
I have an Model: GR3055-014684 Grill from sams club and their was no assembaly instuctions or manual. Can i down load them and where do i go to get them.
Apparently, you're not the only customer who purchase this Hybrid Grill, got home, only to discover the Owner's / Assembly Manual was missing. On the Sam's Club website they list a number 888-837-1380 to call if you have any questions, parts missing, etc. I could not find any on-line manuals for this imported grill. Sadly, you may have to wait until later this week, to assemble the grill. Or go back to Sam's Club and ask them to copy a manual from the display model grill.
Hope this helped you.
Jun 19, 2011 | Grilling
Honda GX 160 under 30 hrs from new, is running poorly
try removing the float bowl on the carburator and cleaning, sounds like needle valve is partially stopped up
Aug 02, 2010 | Honda Horizontal OHV Engine for Non Pumps ...
Honda Orthia 1996 GX Automatic. Car don't start. Start the car today (after a few weeks of been parked), start without problems, I leave it runing and when I come back to check it wasnt runing anymore...
check engine light? check oil level, low oil possible engine damage.is there gas in tank?guages can lie, add a gallon if not sure. when key is turned on, not all the way to start, can you hear the fuel pump, an electric motor sound? have someone listen above the tank with trunk open or listen under tank. past this, check if spark plugs are working, remove a plug, put wire back on, rest plug on metal to ground, turn motor and check for spark. please rate answer.
Jun 10, 2010 | 1996 Honda Civic
The oil dipstick is on the left side. What is the blsck screw cap on the right side?
Is this a cap?
Might it be the clutch adjuster?
It might be worth while for you to join the Honda Riders Club ... costs about $30.00 or so. Google it ... With the membership, you now have access to the service manual for your particular bike. You can download and print it as well.
You may want to look at www.archive.org for this information. For the price of the membershihp, you will get it nearly instantly at Honda.
Good luck to you
a
Oct 12, 2009 | 2005 Honda CRF 250 R
New Karcher pressure washer won't start
replace the fuel carburetor filter and, or, your fuel tank filter
Aug 31, 2009 | Karcher 2500 PSI Pressure Washer
Honda civic 96 will not start have check all electrical and pump
check the oil and make sure it's NOT black, Check air filter, oil filter, and gas filter, check engine fuse, see if spark plugs are ok, check starter, check alternator and belt. if problem still persists please contact me at jhowe67@yahoo.com
Jun 24, 2009 | 1996 Honda Civic
Where can I find an owners manual for a Black Max 8125/ Honda GX390 OHV generator? I searched Honda's site but not there, no black max site. My lawn guy pulled a wire off and I need to see where it is...
low oil sensor will not cause the motor not starting.
most likely is th ground wire.
you can try to attach that wire to any surface and try to start it. of it start, then you have to dis-assemble the head and find out where the wire should be attached.
if not, the wire is attached to a hot side. either way you have to dis-assemble the head.
http://www.honda-engines.com/engines_owners_manuals/ownersmanuals/gx390.htm
here is the site for the manual.
Apr 07, 2009 | Electrical Supplies
Coleman Powermate Premium Plus 6250W Portable Generator Logo
100 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
