Question about Apple PowerBook G4 Mac Notebook
My mac i have has been out of power for a while, when i finaly charged it up, and turned it on, it showed a folder that switched between a question mark (?) and a light blue and dark blue face that had a black split in the middle. I have no idea whats going on, any help?
  • 863 Answers
Your mac can't find the operating system. Re-install the operating system on the hard drive. Also, could mean the hard drive has given up the ghost. Get a new laptop hard drive ATA/IDE 5400 RPM 2.5" are the specs you need. It the specs say SATA, then you got the wrong hard drive.
Posted on Oct 06, 2010
My alcatel onetouch evolve died a while back and when i finaly got it charged up, it wont power on, i held down the power on button and nothing happned, can someone please help me out here? thanks for...
First is the battery ok and fully charged. try and switch it on while hooked to the charger, you may have to hold the button down for a few seconds . if it comes to life now the battery is at fault. If nothing have the switch checked out.
Dec 25, 2014 | T-Mobile Prepaid Alcatel One Touch Evolve...
Hello, my INNOV8 betery is not charging, only shoes that is charging but if i unplug the charger then the batery shows empty!!! Other thing...if finaly i get to charge the batery is drains all the power...
Looks like you will have to replace the battery if it does not hold a fully charge and it's discharging fast. 80% that your battery is going bad. hope this helps
Oct 23, 2010 | Samsung SGH-i8510 INNOV8 Cell Phone
My notebook doesn`t come on when I turn on the power switch.
Check the battery by pushing the button on the bottom, if it shows one light flashing or no lights then the battery is discharged. The problem may be with the ac adapter. Many of these connectors fail after a while and they don't charge the system, which means when the battery dies, there is no more turning on.
May 23, 2010 | Apple PowerBook G4 Mac Notebook
My SANSA e260 froze up. I can't shut it off. Has a blank screen was trying to charge it.
Make sure the player is fully charged. 1. Connect the player to your computer. 2. Make sure the computer detects the player. NOTE: If needed, switch the player to MSC mode, 1. Turn device OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the device to the PC.then connect it to the PC. Next Be sure the battery is charged 1. Leave the player connected for approximately 2 hours to charge. 2. Disconnect the player from the PC. 3. Verify if you can turn on the player. 4. Reset the player if necessary. To reset the player: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player. If that does not do it, re-seat the battery: Then try and see if it will come on with out the battery hooked to your computer, which I see you have done but did you change modes MSC to MTP . next delete the song it keeps hanging on and re-copy it back on to the player from a different folder or re-rip it from the CD and copy it into a new folder then re-copy to the player.
Feb 03, 2010 | SanDisk Sansa e260 MP3 Player
When you turn the comuter on, it just shows the
--SAFE BOOT MODE--
I am going to have you take your Mac into Safe Mode to see if we can't remove a possible folder(s) that may be affecting your Mac's start up function.
Try these steps:
• Reboot your Mac
• Upon restarting your Mac, press the Shift key.
• Hold the Shift key until you see a White Screen with Gray Apple icon and eventually a spinning gear.
• When you see the Spinning gear, release the Shift key.
• Allow the Mac to continue booting up. Also this may take a little while
(NOTE: this may take anywhere from 5 to 15 minutes to load to the Safe mode screen depending on the performance of your Mac, but if it exceeds this time, shutdown your Mac and try just once more. It may have just frozen up the first time around for you.)
• You are going to enter the Safe Mode (which looks like your main desktop environment - the only difference is certain start up items are disabled.)
• Once within the Desktop in Safe Mode
• From the Finder Menu, click Go> Go to Folder
• Type in this line: /System/Library/StartupItems
• This path, is going to take you to the System Library folder which has all of your Mac OS X StartupItems.
• Remove all of those folders to the Trash.
*Reboot your Mac normally and see if you can access your normal User desktop environment.
This should help get your iMac G4 back up
and running.
Regards,
Mactechtrainer
Jan 30, 2010 | Apple iMac G4 Desktop
Mac Ibook Power supply problem
On Mac iBooks the orange light comes on when it charges the battery. Once the battery is charged it turns green. Im guessing the other powersupply was aftermarket or broken. EIther way, if it starts out green - recognizes the battery isnt full - turns orange for a while - then turns green when the battery is full, then the computer and powersupply are working perfectly. Enjoy your iBook!
Feb 27, 2009 | Apple Computers & Internet
My PSP won't show images
was the pic file ever working
it might be tht u have a wrong format of pic file
Aug 28, 2008 | Sony PlayStation Portable (PSP) Console
When turns on shows a computer screen and red cross
Hi there
This happens because files on your card are corrupted after an unsuccessful download.
If you have a card backup at hand, put the card into a computer, format it , and restore backup.
After that the TOMTOM will restart working normally.
If you did not make a copy or backup of the original card, or you cannot reach the computer hosting the last backup.Then follow the procedure below to restore your data :
1. Uninstall the application
2. Reinstall the application
attention_25.gif We highly recommend backing up your device before continuing. questionmark_25.gif
This will preserve any maps and voices you may have purchased.
1. Connect your device to your computer.
2. Go to Computer (Vista), My Computer (XP) or your Desktop (Mac).
3. Double-click the TomTom disk drive to open your TomTom.
4. Make sure that hidden folders and files are shown. To do this:
  • Vista: Go to Organize > Folder and Search Options, click on the View tab and select the option Show hidden files and folders.
  • XP: Tools > Folder Options..., click on the View tab and select the option Show hidden files and folders.
  • Mac: With the exception of some system files, your Mac should already show all hidden files and folders on the TomTom drive.
5. Identify the map folders on the TomTom. These are named for countries or regions such as USA_and_Canada, North_America or any other country or geographical region.
6. Delete all files EXCEPT these map folder(s) and the folder titled ASR, if it exists (the ASR folder will not appear on every device).
7. Properly disconnect the TomTom from the computer and exit TomTom HOME, if it is open.
  • Vista/XP: Right-click the TomTom drive and choose Eject.
  • Mac: Drag the TomTom drive to your Trash.
8. When the TomTom boots you should see a screen with the flashing X.
Proceed to reinstall the application (below):
Apr 20, 2008 | Tomtom ONE GPS Receiver
Problem with My SanDisk Sansa m230
When you delete files on the sandisk it just moves them to an invisable folder labeled .trash inorder to free up some space you need to delete the files inside this invisable folder. if you are using windows then plug in the device and open it. go into you folder options and make sure it has show hidden files selected. If you are using a linux os then go into your view menu and select show hidden files. this should make the .trash folder appear. hope this helps.
Jan 26, 2007 | SanDisk Sansa m230 MP3 Player
Apple PowerBook G4 Mac Notebook Logo
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
