How do you take it out of zoom from the direct tv remote
  • 11,361 Answers
You need your original TV remote, the Direct TV remote has very limited function, mostly for turning TV on/off, volume control, may be source selection.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Sep 03, 2010
I lost my remote to my sanyo plasma and my picture is stuck in zoom. I've already bought a universal remote that has a pic. zoom button but does not work for my tv. How can i get my picture down t
push minue directly on tv and seif that works. try to see if you can get it out of that mode. you might need the origanal remote. try search on the remote control may work
May 16, 2012 | Sanyo DP42746 42 in. Plasma Television
Tv resolution issue
check zoom on either your tv remote or direct tv remote. someone has hit the zoom button . Its can be called zoom,picture, picture size. You want to get it back to normal. this can be done by hitting one of those buttons repeatedly until you see normal come up.
Apr 07, 2012 | LG Televison & Video
My emerson tv zoomed out to far lost remote
Peel Remote choose Emerson "Did TV Turn On?" Select no twice then yes. U will see Aspect button
Dec 19, 2011 | Emerson LC320EM9 32 in. LCD HDTV
My apex tv is stuck on zoom, how do i fix it?
Hello
Make a factory reset to this set. I assumes that you have its remote control wih you now, and posts this solution. If you did forget the parential pass code, just enter '6688' when the set asks for passcode. The previous set passcode will clear out, you ahve to set a new passocde in place. After resettign the pascode, just make a factory reset to the set, by entering into it menu option.
Without remote control, you can't do anything with this set. If you lost its remote control, you can buy it directly from Apex Digital. The price ofr the remote control in US or Canda is $35. In this case, please contact
APEX DIGITAL,INC,
Customer service: 2119E, Philadelphia, Ontario, CA91761
866-4APEXINC.
website: www.apexdigitalinc.com
OK
Dec 01, 2011 | Apex Digital GT2015DV 20 in. TV/DVD Combo
I have a HD Visio and I lost my TV remote, my TV is stuck on Zoom Out and I cannot play my new Nintendo WII game becasue the TV picture is to large, I went into menu and could not see anything to zoom,...
Sorry u can't fix this zoomming mode problems without the tv original remote.This tv zoomming mode function it is have it only on the tv original remote function only no where else.Try website like Remotes.com to buy the tv original remote to use.
Sep 22, 2011 | Vizio m420nv 42 in. LCD HDTV
Screen to big cant c words how do i adjust
if you are using a cable box you must go to settings on your cable box and zoom out there is an option not sure where its located on which cable box your using . If the tv is hooked directly to the cable outlet itself its a menu option on your tv there is a zoom option and some remotes also have a zoom botton.
Mar 16, 2011 | JVC AV-32F475 32" TV
My TV. When in zoom how do I get it out direct TV remote
try this, locate the slide switch, top middle of remote. slide to indicator marked TV. locate format button upper left second one down, try this button, it is the one that is most often associated with the screen aspects such as zoom , cinema,wide normal, etc. if it does not work in tv mode switch back dtv mode (slide all the way to the left) and try format again. if this does not fix your problem please re post
Dec 13, 2010 | Universal Remote Control DIRECTV Universal...
The direct tv menu guide is cut off around the edges...how do i fix?
Your TV resolution is not set to the proper screen size for viewing it properly and it probably cuts off your tv shows too and you just don't see it. Press the [FORMAT] or [ASPECT] button on the remote. The option available to remove the horizontal bars is Zoom.
Nov 04, 2010 | Panasonic VIERA TH-65PV500 65 in. Plasma...
It appears that the image on the screen is zoomed in, but I can't figure out how to "undo" that. Thank you!
If the image on screen is zoomed both in vertical and horizontal direction, your TVs power regulator inside it is faulty. [Overvoltage]. If it is zoomed in vertical direction only, that is only the height of the picture is zoomed, you can adjust it with the remote control button directly on going through menu and get in to the function menu. Normally all TV remote has a special button marked as "Zoom" which on pressing it once the picture get zoomed, again another press the picture gets wide and again an another press picture will come to normal mode. You should select normal mode to retify the problem.
Oct 16, 2010 | Panasonic CT-27SL14 27" TV
Televison & Video Logo
530 people viewed this question
Top Televison & Video Experts
Electro Med Services...
