Question about Lexmark X6575 All-In-One InkJet Printer
I have lexmark X6570. I needed to change ink cartridge and when i opened it, the cartridges would not move. They stayed clear over on the left side. i tried to open & close the top several times, but , the cartridges would not come to the middle like they should. I proceeded to gently pull on white strip and they came over to middle for me. I pushed down on the blk ink cart. lever and took out the blk cart. and the top plastic cover for the cart. FLEW out past my face and landed on the floor along with the tiny spring. Great, i thought, now what have i done. This printer has been wonderful and i don't use it that much & it is only couple years old , if i remember correctly, but not sure. I do not use it on a daily basis and it has never given me any problems. Help!
SOURCE: Printer Problem
This did NOT solved my flashing led (15 times) also magneta led is off and when i re-install the cartridge its just a second on, and the flashing led is back 15x !! it driving me nuts..
How do you got this solved?
1) With the printer power turned off, while pressing
the Resume/Cancel button, press and hold the Power
button. (DO NOT release the buttons. The Power LED
lights in green to indicate that a function is
selectable.)
2) While holding the Power button, release the
resume/Cancel button. (DO NOT release the Power
button.)
3) While holding the Power button, press the
Resume/Cancel button 2 times, and then release both
the Power and Resume/Cancel buttons. (Each time the
Resume/Cancel button is pressed, the Alarm and
Power
LEDs light alternately, Alarm in orange and Power
in
green, starting with Alarm LED.)
4) When the Power LED lights in green, press the
Resume/Cancel button the specified number of
time(s)
setting) (THEN HIT THE POWER BUTTON >AFTER THIS< TO SET).
Time(s) LED indication Function Remarks
0 times Green (Power) Power off When the print head is
not installed, the carriage returns and locks in the
home position capped.
1 time Orange (Alarm) Service test print .
2 times Green (Power) EEPROM information print
3 times Orange (Alarm) EEPROM initialization
>>>>>>>>THIS ONE
4 times Green (Power) Waste ink counter resetting<<<<<<<<<<<<
5 times Orange (Alarm) Destination settings After
entering the destination settings mode, press the
Resume/Cancel button the specified number of time(s)
to select the destination. For detail, see
"Destination settings procedures" below.
6 times Green (Power) Print head deep cleaning
(Cleaning of both black and color)
7 times Orange (Alarm) Reserved
8 times Green (Power) CD / DVD check pattern
9 times Orange (Alarm) CD / DVD print position
correction (horizontal: X direction)
10 times Green (Power) CD / DVD print position
correction (vertical: Y direction)
11 to 13 times Orange, Green, Orange(Alarm,
Power,Alarm) Return to the menu selection
14 times Green (Power) Left margin correction Not used
in servicing.
15 times Orange (Alarm) Return to the menu selection
Time(s) LED indication Destination CD / DVD print
0 times Green (Power) No change of the destination
1 time Orange (Alarm) Japan Supported
2 times Green (Power) Korea Not supported
3 times Orange (Alarm) US Not supported
4 times Green (Power) Europe Supported
5 times Orange (Alarm) Australia Supported
Posted on Dec 28, 2007
SOURCE: Lexmark 3400 scanner/printer says COVER OPEN. IT IS NOT!
Took a bit of time but worked 1) release the 'kickstand' from the scanner by prying and squeezing it with pliers until the two prongs pop out (or crack and break) 2) detach the scanner hinges by prying/squeezing with pliers until they pop off (or crack and break). (CAUTION: read step 3 below first...don't just yank the scanner off without reading step 3) 3) Carefully unplug ribbon cable and other connector to scanner and set scanner aside. 4) remove screws at front of beige plastic part....pry at the back carefully and this will pop off....sending the screws flying if you left them loose in their little wells. Don't worry, there are only two of them that really do anything anyway. 5) Look towards the rear of the printer and you will see the circuit board and the 'hole' where you can see the sensor, and possibly your white nylon lever arm lying pathetically down in the bowels of the printer. 6) Retrieve and Carefully snap the nylon lever arm back on, and think nasty thoughts about the brainiac who designed that part. reverse the above steps. Put at least most of the screws back in, or the front panel may fall off at a later date. Take care to GENTLY plug the ribbon cable and the other scanner connector back in, making sure it's seated all the way. Try not to bend or kink the end of it, or it will be toast. Good luck, and happy lexmarking.....
Posted on May 04, 2008
SOURCE: Refill cartridge for lexmark X6570
please note that I am not an expert, in this field just an attorney and that is why I am putting my full disclaimer right here at the top---That i am not an expert but only speaking from experience.
Earlier this morning, I just pulled the cartridges to check the Lexmark print (X6570) cartridge numbers (41&42). When I typed these numbers in on inksell.com to retrieve the price and other information for these cartridges, they did not have any refill kits or anything of that nature for these specific cartridges.
To answer your question about why the printer is not detecting that your cartridge is full is probably because the cartridge has a chip in it that essentially disables it once the original manufacturer ink is empty. tHEY [Lexmark & Dell] do not want outside competition In other words, the printer manufacturers make the bulk of the money on selling new cartridges (for a fortune) . To make matters worse, they always seem to be half empty even though they are ‘brand-new’ ink cartridges The bottom line is that the faster you can go through a printer cartridge, they can sell many more of the cartridges that they are charging us a fortune for.
Needless to say, I am just going to go and get me another HP printer. My advice would be to check to see if ink-refill kits (see sites like inksell.com) are available for any future printers that u purchase.
Posted on Nov 08, 2008
SOURCE: epson stylus cx8400 cannot recognize ink cartridges
I had the same problem except it would not recognize any of the ink cartridges. I kept hitting the OK button over and over again with the same cartridges in place not removing them at all and it finally recognized them. Decided to go to maintenance on the printer to do a test, and it went right back to not recognizing the cartridges. So i pressed the OK button over and over again until it finally recognized all the cartridges again, but this time i did not try and go into the maintenance to do a test run. Plugged it up to the computer and it has been working ever since. So press the OK button until it recognizes the cartridges, and run no tests on it is what my solution was for the problem. Really is a pain but it works now.
Posted on Apr 06, 2009
  • 232 Answers
SOURCE: ink cartridges cannot be recognized in canon printer
Hello!
Remove the cartridges and gently wipe the cartridge contacts with a dry cloth, then put them back in. Then, hold the "resume" button for 10 seconds for each cartridge, that should reset them.
If that doesn't work, one of your cartridges (sadly) needs to be replaced.
Posted on Apr 11, 2010
Why isn't my lexmark x6570 printing in color even though there's still color ink in the cartridge?
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Sep 01, 2011 | Lexmark X6570 InkJet Printer
Have 5400- needs new black ink. How do I get to the instructions on this
You can purchase cartridges online from www.lexmark.com. Lexmark cartridges are also available in some large office supply stores.
To replace a cartridge on your printer, please follow the steps below:
1. Make sure the printer is on.
2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
3. Remove your used cartridge.
4. Firmly insert your new cartridge.
5. Close the printer cover. Your printer will then ask you to align the cartridges.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
Jul 27, 2011 | Lexmark X6570 InkJet Printer
Cannot find the ink cartriges on my x6570
  2. Lift the scanner unit.
    The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
  3. Press down on the cartridge carrier latch to raise the cartridge carrier lid.
  4. Remove the used print cartridge.
  5. If you are removing both cartridges, repeat step 3 and step 4 for the second cartridge.
You can download the manual from
http://support.lexmark.com/index?page=downloadFile&actp=CONTENT&productCode=LEXMARK_X6570&id=DR4580&segment=DOWNLOAD&userlocale=EN_US&locale=en
Please rate this solution. Thanks.
Oct 12, 2009 | Lexmark X6570 InkJet Printer
In need refillable ink Cartridge for Lexmark X6570 Printer
if you go to ebay there aare usually cartridges cheap enough
in Uk there is wilkinson that sell cheap cartridges and filling ink sets
Aso to be found in tesco
the computer shops have also chep alternatives ( non original cartridges )
Sep 23, 2009 | Brother HL-2040 Laser Printer
Where is the ink cartridge location on the Lexmark 6570
Please go to the Lexmark website, www.lexmark.com >Technical Support.
Do a Product search for the X6570. That will bring you to another search screen Enter this item number ENUS32244 and you will get back a detailed discription of the cartridge change process.
Don
Jul 09, 2009 | Lexmark X6570 InkJet Printer
Lexmark X6570 refill cartridge
Lexmark has High Yield inks for that product that will give you a better cost per page.
Sep 11, 2008 | Lexmark X6570 InkJet Printer
Sep 05, 2008 | Lexmark X6570 InkJet Printer
Lexmark X6575 All-In-One InkJet Printer Logo
48 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
