Question about MA Audio HK401SX Car Audio Amplifier
When the rca cords are plugged into the amp it makes a constant low note. Once the rca's are disconnected the low note stops. What would cause this?
  • 132 Answers
You have a bad ground in most cases.
Because of this the amp tries to pull ground from the RCAs which are connected to your grounded headunit chasis.
To make a solid amp ground. Find a piece of metal (not the back deck), scrape off the paint and then use 2-3 self tapping screws with washers to keep the ground from moving.
And of course plz don't forget to rate me ;)
Posted on Sep 03, 2010
Why does my nuvi reboot constantly when i plug in the power cord?
It is likely causing a spike in voltage and thus the system senses an error and makes it reboot. If it is under warranty return it.
Aug 28, 2014 | Garmin NUVI1390T Nuvi 1390t gps
My powered sub is humming
Does the humming go away if the cable is plugged in but you wiggle it? May be a bad connection on the input jack.
Mar 22, 2013 | Klipsch Audio Players & Recorders
I have a 1997 Cutlass Supreme. The low trac light comes on when coming to a stop. Also, the front passenger side (near the wheel) makes a constant "crunching" and clicking sound. I'm thinking whee
Sounds like Wheel Hub Bearing & the internal Wheel
Speed Sensor as well, if that is the type hub you have
I would suspect some attention to the brakes may be in
order ,also. Have to strip them once a year to clean off rust
& lube things
Nov 30, 2012 | 1997 Oldsmobile Cutlass Supreme
My 37" LCD takes ~ 15 min to sync and display an
Tv power supply board is this tv problems and causes 90-95% of the times.5% maybe it is the tv Tuner signal board,but very low possibility.The power supply board,that the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Feb 17, 2011 | Audiovox fpe 3207 32 in. LCD Television
Ps3 works on hdmi but not on rca jacks ???
Sometimes its a pain to re hook up the cords if you are stuck in HD mode and tryin to go back to Regular or Vise Versa, power off the ps3 press and hold the power button for 3 seconds. that will switch the video card back to default settings.
Oct 17, 2009 | Sony Playstation 3 (PS3) Console
Carver d12 subwoofer making humming sound
check your rca ground on the woof or the receiver you have a bad ground on one
Oct 09, 2009 | Electronics - Others
Amp makes a constant loud bump
try grounding the rca shield to see if it stops, if it does you have an rca ground problem in either your head unit or your amp
May 30, 2009 | Sony XM-2200GTX Car Audio Amplifier
Amp whine in boat
Try isolating the rca cords away from the power cords-sometimes they pickup and transmit engine noise through the amps if they are too close together
May 27, 2009 | Alpine PDX-4.100 Car Audio Amplifier
Audiobahn amp help...
You have a Direct Short in the System Between the Head Unit and the Amp. Check the Ground on the Amp and then Check all the Wires behind the Stereo and the Common Ground There. You could even have a Spot in the New RCA Cables that is Touching Metal Somewhere. Please Rate My Response! Thanks!
Feb 09, 2009 | AudioBahn A2002T Car Audio Amplifier
TV Problem
The first thing is to check to see if the fuse is blown,if so replace with a 5 amp fuse,fuse is located near were the power cord connects to the board,make sure set is disconnected from power.
Feb 28, 2008 | RCA F32672SB 32" TV
MA Audio HK401SX Car Audio Amplifier Logo
43 people viewed this question
Top MA Audio Car Audio & Video Experts
Mark Skinner
jamie suver
Level 1 Expert
Robert Rankin
Are you a MA Audio Car Audio and Video Expert? Answer questions, earn points and help others
