Blown crossover need replacement - Audio Players & Recorders
    Sergeant:
  • 357 Answers
...OK, firstly crossovers are normally in the speaker encloures themselves so this should not really be in this catagory and secondly, give us some more info. Amplifier brand and model number. Speaker Brand and model number, any ratings of watts or ohmage...
It's like sayin "light blown, need a new one"
Posted on Sep 03, 2010
My infinity overture 3 crossover does not work anymore (both sides of the crossover do not have any output. If I bypass it the speakers do work (obviously without the filtering) My question is how do I...
This is a 3-way speaker; specifically which speakers do you hear something from and which speakers do you hear nothing from? If the woofer amplifer is blown, for example, you will hear nothing from the woofers, but will hear sound from the midrange speakers and the tweeter.
Feb 14, 2011 | Infinity Overture 3 Speaker
Alesis Monitor One crossover assembly removal?
The question is WHY would you replace the crossover network?
They seldom go bad... Usually the speakers aree blown before the crossover fails.
Jan 29, 2010 | Alesis Music
My peavey ul 115 bass bin will only work through its bi amp input. Why is this ?. The other one works fine but when I switch speakers I have the same problem. Can you help please ?..Thank you.
The bi-amp jacks bypass the internal crossover. You need to look at the crossover section and see if an internal protection fuse has blown or if hte crossover itself is smoked.
Dan
Mar 04, 2009 | Audio Players & Recorders
The tweeters in my yamaha NS-515F have blown. Any ideas where i can purchase suitable replacements?
http://www.partsexpress.com is a popular source for loudspeaker components.
Also, are you sure the tweeter's blown, and not a crossover component?
www.mouser.com carries many electronic components that could be used in crossovers.
Dec 02, 2008 | Yamaha NS-515F Speaker
Blown crossover
Sounds like the crossover is smoked. Unusual, but it happens. Just call a Peavey service center for the part number and you should be able to order direct from Peavey. If you have problems getting the number, let me know and I'll try and get it for you.
Dan
Aug 18, 2008 | Audio Players & Recorders
Blown crossover in a Peavey Pro-Sub 15" speaker cab. Can this be repaired? If not, where can I get a new crossover? I went to Peavey's web site and this particular crossover isn't on there.
Yes it can be repaired. Your best bet is to locate an authorized Peavey service center and order the crossover from there. Most will sell the replacement crossover directly. The cost of the individual parts will not be significantly less than the entire module. Are you sure that it is the crossover that is smoked? It is unusual for the crossovers to go bad. What is the symtom of the speaker failure?
Dan
Lost woofer in one cabinet.
I'm not familiar with your specific model, but some of these have fuses for the woofers. Check for a blown safety fuse. Also, verify that the connections to the crossover board are in good shape. These crossovers are not that complex and don't usually fail. Keep us posted on what you find.
Dan
May 29, 2008 | Recoton Advent Advent Calypso Main /...
Bypassing the 150 watt blown amp with passive crossover
I'm purchasing 2 infinity 3-way passive crossovers on eBay with the same crossover freqs as my two overture 3's with blown amps. For 19.99 each, it's worth a try. Good luck to you!
Jan 06, 2008 | Infinity Overture 2 Speaker
Solution
Sounds like you have shorted output transistors or IC'S There is one test is to disconnect all the speakers and see if they still blow. If they do then you need to have the amp fixed or replaced. If they dont blow try connecting up each speaker till the unit blows the fuse asjust maybe you blew out a crossover or a speaker or two?? If you have an active type crossover then I would check that device as well. Good Luck
Apr 22, 2006 | AudioBahn A8000T Car Audio Amplifier
35 people viewed this question
 Grubhead
Grubhead
