Question about Samsung PREMIUM NOTEBOOK X360-34G SYST1.2G 3GB 120GB 13.3IN 1YR
My Samsung notebook has been sitting unused for about 9 months. Today I charged the battery and turned it on. It is making a buzzing sound and seems to heat up near the front of the keyboard. What is wrong?
  • Samsung Master
  • 32,281 Answers
If the buzzing sound is near the vents then the fan could be faulty (not spinning) and the CPU is heating up. When the CPU overheats then it will shut down (ie thermal overload) and won't boot up again until it has cooled down. If this is the problem and the fan is not replaces the CPU will eventually fail
Posted on Sep 02, 2010
Testimonial: "Yes, the buzzing sound is near the vents, and it makes sense that the fan is failing... "
It wont start! replaced the battery just today it is hooked up my right, but i get nothing but lights and gages. it wont even turn over to start. it makes a buzzing sound but nothing happens
The buzzing sound is coming from the relay on the system .
The problem you have is caused by either a low charge on the battery, corroded battery connections, or a faulty battery cable. You may have a new battery but it may be well down on power. Get a battery charger, disconnect the new battery and charge the battery slowly for 12 hours or so and retry. Also make sure your cable connections at the battery are perfectly clean and free of corrosion and are firmly clamped to the battery terminals.
Feb 25, 2016 | 2002 Dodge Caravan
Tip
Notebook Battery Tips
<span> <p><b>Instructions:</b><br /> <p><br /> <ul> <li>New battery pack must be fully charged before use.</li> <li>New battery pack needs to be fully charged and discharged (cycled) a few times before it can condition to full capacity.</li> <li>Rechargeable batteries undergo self-discharging when left unused. Always store a battery pack in a fully charged stage for storage.</li> <li>Fully drain and fully recharge your battery pack every few month.</li> <li>Turn down the LCD brightness of your portable device.</li> <li>Use built-in power management on your portable device.</li> <li>Turn off LCD or other unnecessary accessories when not in use.</li> <li>Set screen saver blank to 1 to 2 minutes of your notebook</li> <li>Add more RAM if you have extra RAM expansion slot, it will reduce the usage of hard drive and it is power exhaustive.</li> <li>Close unused software in your notebook.</li> <li>Remove unused PC Cards or USB devices from your notebook.</li> <li>Don't watch DVD or play graphics intensive video games.</li> <li>Don't short circuit terminal or store your battery pack with metal parts.</li> <li>Don't drop or mutilate the battery pack.</li> <li>Don't expose to moisture or water.</li> <li>It is normal to get warm when charging or normal use. If it is getting too hot, there may be a problem with the device and qualified personnel should check it.</li></ul></span>
on Nov 03, 2010 | Computers & Internet
Champ 3303i battery not charging
The battery or charger may be defective
Mar 29, 2017 | Cell Phones
Battery wont charge unused for 3 months
make sure fuse has not blown on plug. that all connections are tight and battery properly connected it will take quit along time to recharge.
hope this helps
Aug 17, 2010 | Samsung NC10-14GW Notebook
I have a Yamaha Vstar Classic-650. When i try to start it all i get is a buzzing sound. The bike has been sitting for a few months, but I have always been able to start it up from except for now... can...
The buzzing is caused by a flat battery. or dirty corroded battery terminals.
If the battery is a few years old and has been sitting for a while it often pays to get a new one.
Running a less than perfect battery and or jump starting may cause other problems as it may overstress the charging system.
Jun 06, 2010 | 2007 Yamaha V Star Classic
Engine wont turn over at start
Hi, Do you have an alarm & Immobiliser fitted on your bike as these drain the battery on your bike very quickly? If so i would recommend removing your battery and fully charging it with a decent amp-age charger. If you have your garage attached to your house then i would definitely recommend purchasing a trickle charger and when not using your bike keep this plugged into the mains and you should not have this problem again. all motorbike shops sell these chargers If after this the battery goes flat again i would suggest purchasing a new battery. This is a common fault as most motorbikes sit in the garage through the winter months and if not kept on charge will deteriorate. Hope this helps.
Apr 09, 2010 | 2006 Yamaha V Star 1100 Custom
Buzzing sound on samsung
it sounds that u have a color wheel problem my friend
Jan 19, 2010 | Samsung DLP HL-P5663W 56" TV
My car has been sitting unused for 2 months and it won't start even when I have tried to jump-start it. when there is not another car hooked up to it it doesn't do anything and then I am trying to jump...
Try charging the battery first. Hook up to another vehicle and let them sit connected for about 10 minutes. Afterwards, then try starting it. If that makes any difference at all...keep charging. If theres no difference, replace the battery.
Jan 09, 2010 | 1995 Subaru Legacy
Dead battery making a clicking sound
take the battery out of the veh and see if it will charge overnight on a charger, if not then the bat just ran its course I doubt it is 11 years old. Bats last anywhere from 3 to 5 years then they die if it does charge then your alternator needs to be replaced as it charges the battery when you drive, low voltage may cause the buzzing, tellin gyou there is a problem.
Mar 21, 2009 | 2000 Toyota Tacoma PreRunner
Verticle lines on screen
This is a very easy fix. Your cable box is not grounded correctly. To fix this you need a AC Plug adapter. This will change your TV ac plug from a 3 wire to a 2 wire. This may sound funny, but trust me on this. I have fix a lot of TV in NY doing just this.24001fc.jpg
Sep 10, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Samsung PREMIUM NOTEBOOK X360-34G SYST1.2G 3GB 120GB 13.3IN 1YR  Logo
74 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
