I need to clean the evaporator coil in my in ground source heat pump inside our house. there is very little space, I would have to remove the air filter and this would give me about 1.5 inches of space, simply not enough space to clean the coil. Is there a way to do this cleaning short of removing the air duct or cut a hole in it. Thanks so much in advance.
  • 455 Answers
Hello I feel your pain,no access.If the floor getting wet is NOT a problem you can blast it with a hose from the front side if there is more room it will wash through.I have taped a wire brush to a stick and CAREFULLY scrape up & down to remove lint.Otherwise I have made an access hole in the duct and patched it closed before, but it is SHARP and is to be done with care.
Posted on Sep 03, 2010
Can Heat Pumps be contaminated by Dust.
That makes a little sense to me.. the air is heated or cooled as it's blown through cooling and heating coils. The filters might have blocked the dust on the intake side, but the exhaust into each room wouldn't be protected, and the coils are on that side.
I'm not in heating and cooling.
Nov 02, 2015 | Heating & Cooling
Boiler doesn't fire up. 25 years old Amana outdoor boiler model #3612M-A Mfg # P68191-1F,It had leak in pump housing and replaced, replaced igniter ,but no fire, no leak in system ,pump are keep running...
How a Central Air Conditioning System Works
Facts:
  • The typical central air conditioning system is a split system, with an outdoor air conditioning, or "compressor bearing unit" and an indoor coil, which is usually installed on top of the furnace in the home.
  • Using electricity as its power source, the compressor pumps refrigerant through the system to gather heat and moisture from indoors and remove it from the home.
  • Heat and moisture are removed from the home when warm air from inside the home is blown over the cooled indoor coil. The heat in the air transfers to the coil, thereby "cooling" the air.
  • The heat that has transferred to the coil is then "pumped" to the exterior of the home, while the cooled air is pumped back inside, helping to maintain a comfortable indoor temperature.
  • Central air conditioning can also be provided through a package unit or a heat pump.
Benefits:
  • Indoor comfort during warm weather - Central air conditioning helps keep your home cool and reduces humidity levels.
  • Cleaner air - As your central air conditioning system draws air out of various rooms in the house through return air ducts, the air is pulled through an air filter, which removes airborne particles such as dust and lint. Sophisticated filters may remove microscopic pollutants, as well. The filtered air is then routed to air supply ductwork that carries it back to rooms.
  • Quieter operation - Because the compressor bearing unit is located outside the home, the indoor noise level from its operation is much lower than that of a free-standing air conditioning unit.
ed.
Sep 10, 2008 | Amana Heating & Cooling
Tip
A Great Tip For Saving Money
While everyone usually remembers to change their AC and Heater filters, no one thinks about cleaning the heating or cooling outdoor coil. If you have an outdoor unit for heating or cooling, those coils need to be clean too!!
The principle of an HVAC unit is to remove heat or cold from your home to make sure you have a comfortable temperature inside.
If you have a gas furnace, your good to go in the winter. Make sure you change your filter every month and you should be able to keep your home at an nice temperature for you and your family. BUT, if you have an air conditioning unit hooked up to cool your house in the spring and summer, you need to do a little maintenance every spring to make sure you get the most out of your unit and save money. The same principle works for a heat pump, so i'll break it down for each unit.
1. An air conditioning unit that has a gas heater works just like it sounds. In the winter, your thermostat will tell the heater to turn on. You will have your burner running until the fan switch in the heat exchanger gets to the right temperature to turn the fan on. This is so you don't have cold air circulating through the house. Cooling on the other hand works a little different. If your thermostat calls for cooling, your fan will turn on right away and your condensing unit outside will turn on. What you AC is doing is removing heat inside the house and putting it somewhere else. That;s where your condensing unit comes in. The heat you removed inside the house is transferred outside where it is compressed and cooled through the use of the outdoor fan.
Now, imagine if this outdoor unit has dirty coil. You are no longer able to remove the heat from the house because it's not able to be removed because of a dirty coil. This means a huge loss in cooling capacity, higher running amperage on the compressor, and your electric bill being alot larger than it needs to be. I'll have the solution after I address the heat pump.
2. Now, the heat pump. It is basically an air conditioning unit that can reverse. In the summer, the outdoor unit will blow hot because of the heat it removed in the house. In the winter, the outdoor unit will be blowing cold because it is using the heat outdoors to add heat into your house. While this sounds weird, it's engineering at it's best. In the winter, heat is able to be removed from very low temperatures and your able to transfer heat into the house because you have a compressor in your unit. It does what it says. It takes a low pressure-low temperature refrigerant and compresses it into a high pressure-high temperature refrigerant.
Now, getting to the coils of both units. You need to clean the outdoor coil on both units every spring to make sure you have a clean coil. In the long run, this will allow the unit to expell the heat gained from the house and in the long run will add life to your compressor and save you money.
On the heat pump, you'll also need to clean the coil every fall. This is because if you don't, you could have a problem with freezing your outdoor coil. If you can't remove the heat from indoors, you will slowly turn your outdoor coil into an icemaker!!
So, based on what you have, turn the power off to your outdoor unit. Spray very good with a degreaser such as simple green and let it sit for about a half an hour. Then, grab your hose and wash out the coil. You'll be amazed what comes out. Let it sit for a coup0le hours to dry out, then turn the unit on.
This will not only extend the life of your compressor, it will also save you money in the long run!!
on May 11, 2010 | Heating & Cooling
What is the function of evaporator?
The evaporator absorbs the heat from the conditioned space and boils the refrigerant to a gas, so it can be pumped back to the compressor. The compressor cannot pump liquid. The evaporator is also the cold coil heat exchanger that the cold air comes from when blown by a fan.
Aug 29, 2013 | Heating & Cooling
Lennox 10HPB36-10P is blowing luke warm air.
What coil is getting cold? In cooling the evaporator coil should be getting cold not the outdoor condensing coil. Verify you have the tstat setup for heat pump, verify you have a proper refrigerant charge.
Apr 19, 2017 | Heating & Cooling
I have a ruud model no. ubhc-17j11nfd and i am having a problem with my heat. when the heat does come on, the thermostat says it is on auxilary heat. i am getting no suction from inside the house but the...
If you haven`t changed your furnace filter do so. If there still isn`t any air flow then the evaporator coil is plugged with dirt and needs cleaned. It is inside your furnace where the pipes from the outside unit connects. As far as the auxilary heat, this is normal when the house temperature drops to far below the thermostat set point and they will turn off when the house is close to temperature and lets the heat pump take over.
Feb 02, 2011 | Ruud UBHC Air Conditioner
Have Rheem 5 ton heat pump with stacked coils poor cool.
If your sure on the psi your low on freon or your evaporator is restricted discharge psi would realy help.you will get best performance with a clean unit or pay expensive utility bill . Tom
Jun 18, 2009 | Ruud Central System Air Conditioner
Recharge air condition
If you have solid ice build up on the "big" pipe (suction line) and very little air coming out of the vents, it's more an air flow problem; Inside fan not working, dirty coil inside (evaporator) or block filter. Open the cabinet inside and take a look there first.
This should be easy to fix; if the filter is dirty, replace it. should be done every month anyway.
If the coil is dirty, depending on access there's a 50/50 chance you can clean it you're self. If you can't you will have to call a technician who will pump all the freon in the outside unit, disconnect the coil, clean it & reinstall it, that should run you $200 to $300
You say there is a little air coming out so the fan is probably working, but if not, you will to find out why the fan is not running. That's electrical, could as easy as the thermostat is not turning the fan on to replacing the fan it self.
It is possible to have frost coming back if you are undercharge (low on freon) But the conditions have to be just right. A Journeyman mechanical carrying an EPA license working under A license contractor is the minimum you need to be able to buy freon since the 90's. that's legal of coarse.
To charge a system you also need a set of gauges and you need to know the working pressure of the system depending of the freon inside.
I think you only have a block filter or a dirty evaporator, possibly a collapse duct.
Good luck
Benge
May 27, 2009 | DeLonghi Trane 5t Rooftop Air Conditioner...
Amana heat/air conditioning pump
You are going to have to increase the amount of heat absorbed by the evaporator coil on the indoor section of your system. First change the filter. Second turn the power off to the outdoor section and leave the indoor fan running until all the ice on the evaporator coil has thawed this could take a few hours. Third you need to verify that you are getting adequate airflow across the indoor evaporator coil and the outdoor condenser coil both fans should be spinning at full speed and airflow should be unobstructed by dirty coil fins or debris Hopefully after you've done this you will have cold air blowing inside and the larger of the two lines entering the unit outside will be cool to the touch but not frozen or even frosted regardless of run time and the small one should be the slightly warm but not hot. If the larger line continues to freeze then it could indicate a number of problems but essentially your condensers cooling capacity is outrunning your evaporator coils ability to absorb heat from air stream circulating in your home.Hope it works out for you GL!
Jun 10, 2008 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
23 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
