Question about Daewoo DSA-122L Air Conditioner
Throws or sprays lots of water out the front on a daily basis which is soaking the carpet and furniture. The window unit is over ten years old and has been running non-stop for at least 5 years.
  • Daewoo Master
  • 43,501 Answers
It sounds like that unit is getting a bit low on charge and is freezing up a bit....maybe even needs a good cleaning of the indoor coil... that would make it freeze also.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Posted on Sep 03, 2010
Wet carpet passenger side
DRAIN HOLES IN BOTTOM OF DOORS? UNDER BONNET BELOW WINDSCREEN CAN COLLECT A LOT OF STUFF
Jan 23, 2014 | Jaguar S-Type Cars & Trucks
Tip
Getting years and years out of your Window Air Cond.Unit.
The filter in the front if your unit is the life of the unit.You should check no less than once a week.Clean it under low warm running water w/soft towel.Then w/soft dry towel wipe dry gently- so not to tear the filter.If it doesn't look dirty,it still is a little,you can just wipe it down then,Before you put filter back(of course make sure unit is (OFF)Then do this: You can use a multi~surface cleaner like 409,spray a clean towel sprayed w/cleaner until it is very damp,then you're going to clean the coils Carefully;Slowly & gently follow the pattern of the coils(aluminum panel in the front same size as your filter)There should be some black on your towel & a noticeable difference in the shine of the coil panel.Once you're done w/entire panel,rinse towel clean while still damp.respray w/cleaner then to the left & one to the right you'll see what looks like copper tubes.One longw/ horseshoe shaped others running sideways ontop of the big one.Get in there &wipe all of it,top,bottom sides,as far back as uou can ''EASILY"reach,then do the same on other side.Also,In the winter cover the outside of the unit from the weather.In the summer (again unit OFF) you can spray w/a water hose the outtermost section of unit,removing leaves,debris,etc.Do checkups of unit in front (inside, part you move to control which way to blow air)for mold.Use quetips to clean around area.If you do this on a regular basis not only will your window unit stay clean and look much nicer but the unit will last years after its average est.time to replace.
on Feb 20, 2010 | Heating & Cooling
The passenger side carpet of my 1999 Chevy malibu was soaking wet. I ran the AC unit at full blast and a lot of water dripped into the road but the carpet stayed dry. I then sprayed it with water but...
If your ac is cooling without any problems, its not the evaporator that is under the dash. because
if it was you would loose a lot of freon and your ac would not cool so good.
on the other hand if the temperature on your engine got hot it would register on your gauges on
your dashboard, and that could be an indication of a ruptured heater core that also is under the dash.
but , you could also have other, things like a ruptured radiator hose, water pump,blown head gasket.
I hope this helps you. good luck!
Jun 22, 2011 | 1999 Chevrolet Malibu
My frigidaire air conditioners spit dirt all over the floor. My window unit and my through the wall unit in a sleeve both do the same thing. I called Frigidaire two years ago and they told me there were no...
1. Turn units off
2. Remove Filter
3. Spray a foaming cleaner on the coils (Dow Bathroom Cleaner)
4. Use a spray bottle filled with plain water
5. Replace Filter and Grill
May 25, 2011 | Frigidaire FAC124 wall/Window Air...
I have used my Steam Vac for carpeting, but until today, had never tried cleaning upholstery with the spin-scrub brush. I spent a miserable afternoon trying to control the spray, which seemed to go...
I can sympathize. My vac came with two handheld attachments. I have better luck with the handheld attachment that doesn't have the spin-scrub pads. To keep the water from going all over the place, you need to keep the part the you hold only about 1 inch from the surface of the upholstery; if you hold it higher it gets everywhere; if you hold it lower the spray doesn't spread out wide enough and it just makes big water droplets that roll down the upholstry.
If the vac isn't sucking up the water, it is likely you have it set up wrong. Take off the attachment; if you put your hand over the open end of the tube, do you feel suction? When you are using the handheld attachments there is a rectangular piece you remove (attached to the dirty water tank) and you stick the rectangular part from the hose in there. If you are getting suction but it's just not sucking up any water try these 1) maybe you aren't laying down enough water, spray it more heavily OR 2) you need to **** up the water right after you lay it down. Don't let it soak in for more than a few seconds.
good luck!
Aug 17, 2009 | Hoover SteamVac F5914-900 SpinScrub...
I have a bissel pro heat carpet cleaner that doesn't spray cleaner solution, everything else works, but I don't know whether it's the pump or the heat unit.I'm assuming that the pump unit must be bad since...
If you still have spray through the attachments then its the heating element. If not and your sure the belts are good ( if there intact but are a year or more old they need to be replaced ) then its probably the pump
Jun 27, 2009 | Bissell 1693 PowerSteamer Upright Vacuum
96 chevy tahoe, passenger side and rear cargo carpet is wet
sounds like the air conditioning drain for condensation is plugged
Apr 24, 2009 | 1996 Chevrolet Tahoe
No suction to retrieve water from carpet
The tank lid of your recovery tank is designed to engage two tabs to lock the front of the lid down on the seals. Look at the front corners of your recovery tank. You will see a tab extending out on each corner. These two tabs insert into the corresponding grooves in the lid. Once engaged, the lid folds down and the clip on the lid snaps into the back of the tank. When installed correctly, if you pull up on the front of the lid, it should NOT lift away from the tank. The front of the tank has a square "duct" that is removable for when the hose is inserted for furniture, etc. Make sure that this duct is replaced back into the tank when using on the carpet.
Jan 19, 2008 | Vacuums
Finding a part flyback transformer #00364085-0001
Are you saying that the TV is furniture because it isn't working or because it is such nice furnature, you want to get it fixed?
Even if you can find the flyback, a set this old has lots more in it that is overdue for failure. TV's stress their electronic parts out more comprehensively than almost anything else and I always recommend not wasting any money on one over ten years old.
But if you really want to - partstore.com sells the whole main board (313918806221) for about $170
Also might check with Module Exchange at 972-298-1212
Dec 31, 2007 | Philips 27PT6441 27" TV
Daewoo DSA-122L Air Conditioner Logo
69 people viewed this question
Top Daewoo Heating & Cooling Experts
Tim Whalen
armandog07
armandog07
Steve
Are you a Daewoo Heating and Cooling Expert? Answer questions, earn points and help others
