Question about Rheem Water Heaters
Pilot will light, burner lights stays on for a while probably till it reachers temp then pilot goes out, its a rheem gaurdian 40 gal
  • 494 Answers
This covers just the basics on no burner flame or pilot outage issues on standard tank gas water heaters and does not pertain to tankless or instantaneous heaters. As always, safety first; if you do not understand what you are doing, do not attempt to make repairs on your own. This is just a guide to help you figure out what may be wrong.
1) Let's take care of the obvious things first. If you have a propane gas water heater, make sure you are not out of gas! Go to the tank, lift the lid, look at the % gauge. If it's pointing at 5% or less, you may be empty or about to run out of gas. If it says you have plenty of gas, make sure the gauge is not sticking and bang the lid down. If the gauge drops down to 5% or less, order a gas delivery.
2) Remove the panel on the water heater to view the burner. Is the pilot still lit? Yes, then make sure the control knob is in the "ON" position. Also make sure the temp dial is not on "Vacation" setting or set at a very low temp setting. Typical dial settings are at medium "arrow" selection or "A" selection.
3) Is the pilot flame out? If you smell gas, do not attempt to light. Turn gas off at shut off valve on gasline to water heater and call your gas co. Otherwise, follow the manufacturer's lighting instructions on the water heater to relight. Pilot still won't light? Then you may have a dirty pilot orifice that needs cleaned. Or if you were out of gas and just got filled, you may have air in the lines and lighting the pilot will take longer than normal to light. It's best to have the gasman light this when he is there to fill your tank. It's also possible you have a control that is locked out or defective, which will require a serviceman to repair or replace the control.
Let's say you get the pilot flame lit. When you release the button, does it stay lit? No, then you might not have held the button down long enough, Try again. Still goes out? Is the pilot flame a strong blue color and actually making the thermocouple red hot? If so, and it won't stay lit, replace the thermocouple. Or is it a lazy yellow flame? If so, it may have burn't the tip off the thermocouple and it will need to be replaced. This condition is caused by a dirty pilot orifice, which will need to be cleaned with a broach to prevent it from ruining the new thermocouple you install.
4) Ok, let's say you relight the pilot and get the main burner to light as well, but later they both go out again. This only happens, of course, after the service tech has left. With it still off, get a flashlight and look inside the access panel in the area above the main burner? Do you see a lot of black soot build-up? If so, this make be causing your problem. Have your water heater serviced. If no soot, then check for blockage in your vent. Look for a bird nest or even a dead bird. Your vent cap is either going through your roof or through a wall to the outside. You'll need a ladder to check either. If it has bends and elbows, check those out for blockage too.
5) No blockage? Sometimes a vent is installed wrong (like under an eave) or you are getting a strong down draft. Make sure your vent cap is still attached on top of your vent too. Strong winds can blow out the pilot flame.
6) Here's another test you can do, if the pilot and burner shut down. Relight it as you did before and with the burner lit, reinstall the access panel. Now light a match at the draft diverter (standard water heaters have these on top which connect the water heater to the venting) Blow out the match near the edge of the draft diverter and watch where the smoke goes. (Shining a flashlight there also helps you see the smoke better) If it gets pulled into the draft diverter, it's working properly, pulling outside air in. If the smoke gets pushed out, you have a drafting problem. To make matters worse, you are also allowing carbon monoxide into the home. Have your water heater serviced immediately. I also recommend having a carbon monoxide detector located on every level in houses that have gas or oil appliances.
These are just a few ideas to help you figure out your common lighting issues. There are other issues that I did not cover, which may require a repairman. I hope you find these useful. If you still have concerns, please ask away! That's why we are here! Douglas
Posted on Sep 03, 2010
New gas water heater pilot light will not ignite
Hi .. if this is a brand new heater, then you probably need to have the gas line bled. This means getting all the air out of the gas line feeding the burner. This can be done by constantly trying to light the burner or poilot . or it can be bled down by a HVAC tech.
Apr 09, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
My Rheem 40 gal. LPG water heater has sat for two years. When I attempt to light the pilot manually, it goes out after I release the push button valve knob?
The pilots have to warm up, hold that button down for a min, then let it go, it should stay on. Then crank up the pressure, it should light. If you are worried about it, call your gas man, he will check it out. Hope this helps.
Mar 31, 2010 | Water RHEEM 40 Gallon FVR PROP PWR Heater...
Pilot light won't stay lit in gas water heater
If this heater was manufactured after 2003 it has a FVIR filter. It is usually located on the bottom of the heater and this is where it draws air into the combustion chamber. Check to see if it is clogged with dust or lint.
because the heater probably has a sensor, it is not getting enough air and shutting off. hope this helped.
Mar 17, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Heater burns sooty
change your thermo couple if the pilot light will not stay lit
Jan 26, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Pilot light on water heater wont stay lit
The thermocouple has failed. It is the temp probe that goes from the pilot lite burner area to the control valve. Go to your local plumbng repair shop and buy one. Most appliance parts stores have them also. Take the old one with you and they will hook you up with an exact replacement. They are not that hard to change. Usually a nut or 2 screws in the temp bulb area at the burner end and a nut that threads into the control valve.
Make sure before you install the new one that the area where it mates to the gas valve is clean. Should be about a 20 min job including clean up with replacement parts in hand.
Jan 23, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
No hot water
You have a bad thermocouple. 20 dollar or less part.
Sep 25, 2009 | Rheem 40 GAL Propane Water Heater 6YR...
Lp waterheater won't stay burning
check the pressure comming into the burner thru the gas valve, it has to have at keast 2,bs if not you might have to change the regulator
Jun 25, 2009 | Rheem 40 GAL Propane Water Heater 6YR...
No Hot Water in morning
Remove the cover then the access cover, then you can see inside,
the pilot light is probably out.
If out turn the gas off, then get a long match, grill lighter,or piece of paper ready to light, you should be able to see the little thin
gas line that runs inside the tank and see where it connects to,that is where you need to light, now that you see where to light, turn gas knob to pilot, and press down and at the same time light the pilot.
( blow into the pilot area before putting match inside to make sure no gas has built up inside) Hold down the knob for a minute then release, if pilot goes out try again and hold down longer, if you hold it for 3mins and it does not stay lite, the thermocouple is bad and you will have to replace it.
Apr 14, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Water Heaters Logo
193 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
