Televison & Video Logo
Posted on May 11, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Moxi DVR During a storm last night our power went out for about 5 seconds. Since then, we cannot get the volume to work on our tv (that has a Moxi DVR hooked up to it) unless we are playing a DVD.
Anonymous
Level 3:
President:
  • Master 2,712 Answers
  • Posted on May 11, 2008
Anonymous
Master
Level 3:
President:
Answers
2712
Questions
22
Helped
1063511
Points
7105
You will probably want to get the audio module checked by a professional. It could be something as simply as a blown capacitor/resistor, but if you are not familiar with this, best get a professional to diagnose/repair the set.
Try this first:
Unplug the tv from the mains and remove all cables. Wait for about 10 mins. Now plug the TV back into the mains, while holding the power button ON. See if this resolves the issue.
I would also recommend investing in a surge protector/spike buster if have frequent storms in your area.
  • Anonymous May 31, 2008
    This thread has gone 14 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
    IrishDruid
Panasonic tv hdmi inputs not working
It appears that during the storm there may have been an electrical surge that damaged the electronics of your tv. If the tuner is working fine then the affected area (board) is the one that has the HDMI input sources.
Onkyo tx-sr604 help
You said you tried hooking the HDMI up directly from the TV to each component, and that worked. How is it usually hooked up - through some kind of switch? I'm not completely understanding your setup here.
Tv went out last night during a storm. TV was only thing effected. not tv will not turn back on. red led light blinks 14 times when try to turn on
hi, normally that because the power supply unit cannot supply the required voltages for various components on the TV , from back-light inverter to logic board etc...
Regards
Rob
www.gewizrepairs.co.uk
Maganavox flat screen tv no pic, red light blink codes...
Those blinks are fault codes. To know more visit the site linked here. http://electronicshelponline.blogspot.com/
Boston Acoustics TVee Soundbar loses the cable remote training.
get rid of that moxi before it starts on fire.
have charter send out a scientfic atlanta hd dvr, with an hdmi port on it as well. the functionality and reliablity of these boxes greatly exceed moxi. moxi is a power sucking, fire hazard, problem waiting to happen. the only thing it has that is good is the guide format. but you may feel that graphics on a tv guide outweigh the funcitonality of the device. the big square in the front of the moxi was supposed to be a dvd burner, the box has no hdmi, and has a modem in it that is disabled. so its got a bunch of junk on it that isnt and cant be used. if you dont clean the vents on the back of the box monthly it will surely fail.
senior catv tech/supervisor
ALL OF US INSTALLERS DESPISE PAUL ALLEN FOR INVENTING THAT PEICE OF ****.
4helpful
Sharp Aquos 46" HDMI problem
I have a similar problem. The Sharp TV aquos appears to be shutting down my blue ray player and dvd recorder when connected via HDMI. They work fine and never close down when I connect them via the rca cables either single video connection or a composite 3 cable rca lead. I have 3 HDMI inputs on the tv and the problem occurs on all 3. Any suggestions?
TV won't work after storm
ok lets try this hit the power button on the DVD player some go into stand by mode and when power is interrupted you have to push the button manually also reset the surge protector next get a lamp that you know works and unplug the tv and plug the lamp into the socket where the TV was plugged into turn on the lamp, does it turn on? yes then something wrong with TV again may have been in stand by mode plug back in and try pushing the power switch on make sure the TV if it has a remote is on the right im put to get a picture say like a satellite or cable or DVD player. hope this helps.
Tv dead after storm
you could open it and look to see if the fuse is blown
Moxi box hook up to to an HDMI input
You need the dvi to hdmi cable or the 3 colored component cables.
No Picture, Menu screens or anything video - Sound still working!
Yes... Look for F851 and replace it with a slow blow 3.15A fuse per Toshiba. Bill
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
