Question about Memorex MLT1912 19 in. LCD TV
When I plug in the 12v ac cord standby light indicator is red. Once I press standby button, blue screen appears then shuts off within seconds.
  • 11,361 Answers
More likely to have bad backlight inverter board, post picture if you can, you can check the fuse on it to see if it is OK.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Sep 03, 2010
Morning, it flashes red light six times
From the manual:
Press the (ON/STANDBY) switch to turn on the projector. If
the power is not turned on, disconnect the AC power cord, then
confirm the ON/STANDBY lamp is turned off. After about 10
seconds, reconnect the AC power cord and turn on the power
again. If the indicators still light up, the electrical system has a
problem. Consult with qualified Sony personnel.
Jul 08, 2016 | Sony VPL-VW95ES Full HD 3D Home Cinema...
Tip
How to reset Canon BJC-2000 printer ?
1: Remove the Cartridge 2: Unplug the AC Power Cord
3: Close Front access panel
3: Hold down the RESUME/RESET button and plug in the AC power cord
4: Release RESUME/RESET after plugging in the AC Power cord.
5: Press the RESUME/RESET once within 5 seconds and release the RESUME/RESET .
6: Press and HOLD RESUME/RESET for two seconds or more and release it.
7: Press and HOLD RESUME/RESET for two seconds or more and release it.
8: Unplug AC Power Cord to set data.
This will help.Good Luck
on Mar 10, 2010 | Office Equipment & Supplies
Tip
How to reset Canon BJC-2100 printer ?
My coby lcd tv won't work for my ps3 what wires would I need to make it work
You will need an HDMI cable. Please follow the below instructions.
Instructions
  1. Before you begin installation:
    • Turn OFF the PS3TM system using the [MAIN POWER] switch (in the back)
    • Unplug the AC power cord from the electrical outlet
    • Turn OFF and unplug the TV
  2. Connect one end of the HDMI cable into the [HDMI OUT] port on the back of the PS3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor. ps3_8_hdmiconnecttv.gif
  3. Plug in the AC power cord by connecting one end of the AC power cord into the [AC IN] port on the back of the PS3 system and the other end into an electrical outlet. ps3_11_connectacpower.gif
  4. Press the [MAIN POWER] switch on the rear of the system. A red light should appear on the front of the system indicating power is available.
  5. Turn on the PS3 by pressing the touch-sensitive [On/Off button] on the system front. The red light will turn green, indicating the PS3 is now turned on.
    Note: The blue light will also appear on the front of the system if you have a disc inserted.
  6. Plug in the TV and turn the power on. The PS3 should detect the HDMI display device automatically. When prompted, "Do you want to output video and audio using HDMI?", select YES and press the icn_btnx_color.gifbutton. (You may need to press the PS button on the center of the SIXAXISTM controller to enable the controller first).
  7. The next screen will ask, "Do you want to automatically switch to the optimal setting?" Select YES and press the icn_btnx_color.gifbutton.
  8. On the next screen, the PS3 will display the maximum resolution capable on the display (i.e., 1080p). The screen will display, "Do you accept the setting?" You will have 30 seconds to confirm your answer.2 Select YES and press the icn_btnx_color.gifbutton to save your settings. You have now completed the HDMI installation.
Dec 01, 2014 | Televison & Video
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
I am getting 'Service Error 5200' on my Canon i990 printer and the orange light blinks 8 times.
1: Remove Cartridge
3: Hold down the RESUME button
4: Release RESUME after plugging in the AC Power cord.
5: Press the RESUME once within 5 seconds and release the RESUME .
6: Press and HOLD RESUME for two seconds or more and release it.
7: Press and HOLD RESUME for two seconds or more and release it.
Jul 06, 2011 | Canon I990 InkJet Photo Printer
Basically i plugged in the ac adapter to it, pressed the power button and the power light comes on for 2-3 seconds then the power light shuts off. lcd screen never turned on or show anything, fan never...
>>> Please leave feedback so I can continue helping You & Others
The middle blue led is the charging indicator, sounds like you have (at least) a bad battery, remove it, plug in AC and try again, if no good, remove the HD and repeat, if no good, remove/replace the ram and repeat, if still no good, your mainboard is cooked.
Thanks,
Adam.
Feb 19, 2011 | HP Pavilion DV9429US Notebook
How do i get the red light that says LOCK, off, on my Digital set top box ? (CG5660-M)
hello Enter the Supper password "1998" when the screen appear "Enter unlock Code"
If super password failed to work pls do as follows:-
(a) press "Standby" button on the remote contorl, then unplug the power cord (within 2 sec.) of the set top box IMMEDIATELY;
(b) After 3 sec. plug in the power cord to the STB again;
(c) Repeat step (a) & (b) until the STB enter the "First Time Installation" screen. Then the box will proceed channel search again.
regards
shaun
Feb 27, 2010 | Televison & Video
LC-32SB24U LCD HDTV... Brand new, just out of box. Turn on, goes to language menu for about 1 second max,too fast to adjust, then screen goes black and little green led power light starts to blink. And...
Good Day, texxastam;
Do this:
1. UNPLUG TV
2. HOLD IN VOLUME DOWN &INPUT buttons on TV
3. Plug in the TV. (the TV will turn itself on).
4. A blue "K" should now be showing on the TV screen, release the buttons.
5. Press and release the VOLUME DOWN & CHANNEL DOWN buttons simultaneously on the TV. (A blue service menu will appear on the screen).
6. Using the remote, press the DOWN SELECT button once. (The highlighted line should read INDUSTRY INT (+CAUSE) OFF
7. Using the remote, press VOLUME UP once (OFF changes to ON).
8. Press ENTER. After a few seconds the screen turns green and shows - Industry INIT success - at the top of the screen.
9. Unplug the AC cord for 10 seconds then plug back in.
Good Luck, big IRISH.
PS; I did not make this up... it's from SHARP> again good luck...you may have to do this several times....too...get the timming down.
Aug 07, 2008 | Sharp Televison & Video
Memorex MLT1912 19 in. LCD TV Logo
157 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
