Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
Dishwasher want drain .what steps should i take to unstop the drain lines
    President:
  • 1,197 Answers
There's a few things you can look into that won't cost you any money.
First, manually remove as much water as possible and then check the sump area for paper or any other large object clogging the drain. A cup or so of water in the sump area of your dishwasher is normal and it is there to prevent the seals from drying out. The dishwasher will pump this old water out before beginning to wash.
Make sure the door is properly latched as the pump will not drain if the door is not latched properly.
Check the belt, drain line, air gap, drain valve and solenoid assembly, the motor, and the pump. If your dishwasher uses a belt to drive the pump, and it has broken or come off the pulley, replace it.
If you have recently installed a garbage disposer in your home, make sure that the drain plug on the disposer has been removed. It's just a little plastic piece that blocks the hole where you hook the dishwasher drain hose. If your dishwasher drains through the garbage disposer, you need to run the garbage disposer before you run the dishwasher to make sure that the drain is clear.
There is a drain hose between the drain valve or pump and the garbage disposal or drain line. If an obstruction has blocked this, then your dishwasher won't drain. The drain hose is connected by clamps to the drain valve and the disposer or drain pipe. Remove it and visually inspect it for a clog or a kink. Try to remove any debris. If it is in good condition, just put it back on, and if not, purchase a new one to install.
If you don't have an air gap in the drain line, at least use a high drain loop. Making a large loop about 18" off the ground with the drain line can prevent any back flow into the dishwasher from the sink.
If you have one, the air gap will be located on top of the sink. The air gap is there to prevent any siphoning of standing water from the sink. When your dishwasher drains, the air gap diaphragm will form a seal and allow the water to drain properly. If the diaphragm in the air gap is faulty, it’s possible that water can leak onto the cabinet and into the sink area. When this happens, then the air gap must be replaced.
Like the inlet valve, there is also a drain valve on most models. When no power goes to the drain valve it remains closed and prevents water from leaving the machine. When the valve receives power during the drain cycle, the solenoid opens and allows the water to leave the machine. If your drain hose is attached directly to the pump, you don't have a drain valve. The motor simply reverses and the pump sends the water in the opposite direction, which is out of the machine.
If the motor doesn’t turn or work properly, the dishwasher may not drain. Make sure you have power to the unit. If you notice that the motor hums but won't turn, it could be seized, and you probably need to replace it.
if you need to buy any parts, I have had alot of help from http://www.apwagner.com
Small objects can sometimes get stuck in the pump. When this occurs, you’ll need to open the pump and remove any debris buildup. The dishwasher pump is usually mounted directly to the motor and runs off the motor as well. The pump is also attached to the bottom of your dishwasher and pushes the water from the dishwasher.
Posted on Sep 03, 2010
Water leak in my range rover on driver side floor had drain unstop from sunroof what else could it be
You unclogged the sunroof drain line - that is good. Are you sure that the line didn't pull up thru the floorboard. Many vehicles run the drain line down the drives side window pillar and out thru the floorboard. If the hose shrinks with age (as some do), they can pull up into the cabin and leak on the floor.
Nov 09, 2015 | Rover Cars & Trucks
How do I unstop drain line
Hi John, you may have a clog on the inside of the unit. look for a screen or a port of some sort in the bottom of your unit it may have debri stuck over or inside. Hope this helps.-Bill
Jan 19, 2015 | Dishwashers
How do I unstop my dishwasher?
Turn the breaker off for five minutes and the turn back on. Start the dishwasher and see if it will drain. Sometimes power bumps can mess with the control board. Otherwise it could be the control board or the pump.
Apr 24, 2014 | General Electric Dishwashers
The hose detached from the garbage disposal. I re-attached it and now the water can't pump out of the bottom of the dishwasher
You have a clogged drain, remove the sink trap and use a plumber's snake to unstop the clog. Reattach the trap under the sink and disposal should drain. The pressure from the dishwasher pump more than likely caused the drain to slip loose, it's a drain, and it should not have any backpressure.
Jul 08, 2012 | Whirlpool Dishwashers
Samsung dmt800rhs errorcode se
I had this issue; previous owners of our house installed new garbage disposal, but did not punch out the plastic stopper on the disposal where the drain hose connects.
May 12, 2012 | Samsung DMT800RHS Dishwasher
How do i unstop drain?
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Aug 29, 2010 | Kenmore 24 in. 15932 Built-in Dishwasher
I am having problems with A/C condensation leaking inside with flooding the front and back floor of Car
check your drain hose for blockage, if it's clogged up the condensation will leak into the floor
Jul 19, 2010 | 2004 Mazda RX-8
Will not drain, pump runs, how to unstop it
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Thank you !!
Jul 13, 2010 | Hotpoint 24 in. HDA3400G Built-in...
Drain hole stopped up in freezer and we cant get it unstopped and it is leaking down in to frige. do you know how we can get it unstopped?
pull back panel in freezer, take hair dryer and melt ice around drain hole until it starts to drain may take sometime usually 20 30 mins pour hot water in drain pan to verify that it is draining
Jan 03, 2010 | Roper Refrigerators
How do I unstop my pump?
Short of removing it and placing on back. No other way.
Jul 09, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
130 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
