Question about Locks & Locksmithing
Have k.kahles helia 27L2 rifle scope sn#47880 cross hair ajustment quit working where to get factory repairs
SOURCE: Bushnell Sportview rifle scope wide angle 4x38 T4389 limited adjustment inconsistant results
I had the same problem but was able to solve it by shimming the scope mounts with a thin piece of plastic. Put it under the rear to raise the sighting and under the front to lower. I still plan to buy my son a better scope.
Posted on May 18, 2008
night71
  • 328 Answers
SOURCE: cross hairs are tilted to right while scope is straight
Without seeing the rifle, my guess would be that either the rings were not tight enough or the lens came loose from the shot. It is rare depending on the quality of the scope. If the lens itself moved, it will not be waterproof or fog proof because the seal on the lens is not tight. If its under warranty then it should be replaced, if not then be care full not to get it too wet. If you had a suction cup, you could try to reposition it straight again.
Posted on Nov 28, 2008
cutlassguy
  • 16 Answers
SOURCE: SIMMONS 3X9X32 BLACK RIFLE SCOPE
check to make sure it hasn't turned in the scope rings. I am sure if it is somewhat new simmions will fix as long as it falls within warranty
Posted on Dec 15, 2008
  • 75 Answers
SOURCE: cross hairs canting to the left..how do i recenter the recticle?
From your short description, it sounds like the Horozontal (the ELEVATION) reticle is canted to the left. If that IS the case then do this;
Sand bag the rifle on what you know is a level and firm surface. The rifle MUST be level itself. You can use a small level to determine this.
Without moving the rifle, look through the scope and determine if indeed the horozontal or ELEVATION reticle is indeed canted. The reticle should be LEVEL in relation to the ground and the rifle itself.
If it still appears to be canted, loosen the set screws of the scope ring caps (Not the scope mounts) and while looking through the scope, gently rotate the barrel of the scope clock wise until the Horozontal reticle appears to be now level. Re-tighten the scope ring caps and look through the scope again to make sure the Reticle is still 'level'.
You must now make sure that your scope is still 'zero'd'.
IF the issue is something other than what I have assumed from your description, please send me a msg. with more detail and I will be able to resolve whatever issue you are having. Include the 'Brand and model', plus the power of it, and the brand/model/cal. of the rifle the scope is mounted on.
Good luck. :)
Posted on Apr 28, 2009
longbow243
  • 103 Answers
SOURCE: Tasco Rifle scope repairs
Try calling Customer Service at 1-800-423-3537. They should be able to assist you with your needs.
Posted on Sep 02, 2009
Bushnell rifle scope
You will have to send it back to the factory.
Jan 11, 2014 | Optics
Cross hair broken on my B S A mil dot 4-16 x 40 scope will any gun shop be able to repair
Yes, more than likely.
The scope just needs to be disassembled and the crosshair flange repaired or replaced.
A dealer should be able to order the part or at least fit one similar enough to work.
The trick is not to allow any moisture into the scope's internal cavity during the repair.
Mar 06, 2011 | BSA 4-16X40mm Mil-Dot Rifle Scope - ...
Cross hairs wont move when trying to ajust
The cross hairs don't actually move when you adjust a scope, instead, they are contained within what is called the erector tube. When you adjust your scope you are actually moving this tube, thus the cross hairs do not move around in your field of view
Sep 19, 2010 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
I have to use reading glasses to use a simmons blazer rifle scope.....othewise the image is blurry.
You can't see the cross hairs or the whole picture is blurry? I know that the rear ring on the scope will bring the cross hairs into focus, glasses or not, and the scope itself should be clear all the way down, I can't see a thing either without glasses and it has really hampered my shooting. It ain't no fun , it's frustrating. Try turning the rear eyepiece, see what happens, hope this helps.
Feb 27, 2010 | Cabela's Cabelas Pine Ridge 3 X 9 X 40...
Cross hairs turn when adjusting power
Sounds like somebody took your scope apart and forgot something. You can remove the rear of the scope, but you might want to send it back to the factory. Some scopes are filled with nitrogen to stop them from fogging up, But maybe only the front part. Take the eye piece off, you should be able to get to the cross hair unit, it should come out in one piece, find out why it spins, might be missing a washer, I have replaced the cross hairs on scopes before with spider webs, I tried a dolls hair once, I thought it was thin enough, .002 ",, It looked like a rope inside there when I got it back together. Good luck, let us know what happens.
Feb 14, 2010 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
Adjustment Issue
the scope should all ways be fitted with the wind adjustment on the right as you look down the rifle, therefor the top ajuster is for up/down,
right ajuster is wind,,left/right, the easy way to set it up is to aim at some sand with the rifle on a stand or in a jig, shoot one round see were it hits and without moving the rifle, turn the turrets till the cross is over the point were the bullet landed, having a pall to move the turrets for you helps a lot here, the main point is dont move the rifle till the turrets have been moved first,, its that or bore sight it,,, jig the rifle up pointing at a target at say 200yds look down the bore aim the bore at the target lock down the rifle check it by looking down the bore again then set the cross up in the scope on what you see down the bore
you will need to tweek the scope a bit as you havent taken the bullet drop into the ajustment that way,,
Dec 17, 2009 | Zeiss 3-9x40mm Conquest Rifle Scope...
I have a 3-12 by 40 rifle scope made by tasco i dont have thewaranty paper work any more and the cross hairs wont adjust any more what do i do
i dont realy understand what you mean by "the cross hairs wont adjust" is it you have ran out of adjustment on the turrets? if so try packing the scope out with 35mm film under the body of the scope and reclamping it,,,or do you mean it just wont adjust?
the tesco rifle scope is a realy cheep scope its a throw away kind of thing if it brakes,,,,there only £50 or so,,,,if it was a £1500 scope its worth fixing
Nov 16, 2009 | Tasco 3-9x32 .22 Riflescope W/ Rings,...
Cross hairs canting to the left..how do i recenter the recticle?
Good luck. :)
Apr 27, 2009 | Nikon Tactical Rifle Scope 4-16X 50...
Cross hairs keep turning
I don't shoot BB guns, but I looked up your gun/scope combo. It' a $65 Chinese product. At this price level you cannot expect a decent scope or rifle. It just can't be done. The scope will not be worth fixing.
Nov 24, 2008 | Caliber Tech Force Pellet Rifle Model 34...
Locks & Locksmithing Logo
103 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
