Question about Philips Magnavox 42MF521D/37 Television
I had lightning cause surge. Blew fuse and R101A next to fuse is burned. I don't know the value. Power supply board is looks like model number PLHL-T721A or PLHL-T720A. Don't see any other damage. Would love to replace the resistor, if I knew the value. (and fuse) and see if it will work... Thanks! Jerry Johnson
  • Tony Karavidas
    Tony Karavidas Dec 25, 2012
    Where can we get a schematic for this board??
    President:
  • Philips Master
  • 749 Answers
The color code is green yellow brown red brown. I believe that is 54.1k 1%
Posted on Dec 25, 2012
Arpi
  • 326 Answers
SOURCE: power supply problem busted fuse
Hello, in most of the new LCD and Plasma TV-s there are special IC-s you can not find in regular stores. Only way to solve this is to contact the Philips Service and order the IC. In most cases the only available items are the complete boards. If you need more info please advice.
Posted on Apr 22, 2007
  • 52 Answers
SOURCE: power supply board led green light blinks 3 times.
vscan is a voltage used to setup the picture for the panal. It goes to the y sus board. The problem is at the power supply or the y sus board. You can check these with a meter.
Posted on Aug 12, 2008
  • 8457 Answers
SOURCE: i have a philips 42 inch plasma that requires a
Tries websites like Shojimmy.com,Ebay.com to buy the whole refurbish power supply board.Can't find in catagories in data base in search.Ask help desk,send Email ask questions.Shopjimmy.com,Ebay.com have the most use refubish PCB for LCD,Plama tvs boards around the web.
Posted on Jul 30, 2010
bshldn
  • 736 Answers
SOURCE: I have a Philpis 42"
Appears that the only other major component is the Servkit assembly
http://www.partstore.com/Model/Royal+Philips+Electronics/Philips/42TA648BXF7.aspx?SearchTerm=True
Posted on Sep 28, 2010
SOURCE: Need info on component 3071 on power supply board - burned up.
does any body know the value of the three caps....2080,2081,2082
Posted on Jul 30, 2011
My panasonic tc-p50x5 will not come on after power outage. whats wrong?
Being in the field of electronics I can not stress this enough....POWER SURGE PROTECTION...and I am not talking about a power strip with "surge protection"...they are useless. That being said you had a surge that most likely blew out your main power board. There is a fuse on that board and if you are lucky that popped and it is an easy fix. If not, you will have to remove the board, get the numbers on it and search out a replacement. There are plenty of places online to get them but I use Allied Electronics. One thing to check while you have the tv apart is to check all boards for visible burn marks or damage from the surge.
Feb 05, 2016 | Panasonic Televison & Video
Should i change a burned resistor for a better one?
It sounds like you have other problems that're causing that resistor to get too hot, Angie. Carefully check for any other components that are also getting hot when that resistor gets hot.
Aug 11, 2014 | Philips 42PFL5603D/F7 LCD TV
NO POWER, ONLY 6 MONTHS OLD, HAD POWER OUTAGE A WEEK AGO- EVER SINCE THEN TV WILL NOT TURN ON.
if you suspect lightning or a power surge that caused the problem, if it were lightning could have effected the power supply board, or if it was lightning it could have went in on the cable or antenna connection. to narrow down the problem, check the fuse on the power supply board, if that is ok then with a volt meter check and see if there is 5V volts going to the signal board, that is the board with the antenna connection, one of the plugs that go to the board probably has writing next to the wires in the plug, if no 5V probably the power supply board bad, I almost forgot, when you take the back off look for burnt parts. if you have the 5V going to the signal board now the problem could be signal board or power supply.
Jul 07, 2014 | Vizio L32 32 in. LCD HDTV
Vcr does not take in cassette, shuts down after fewseconds
Considering both the fuse and the MOV failed from the surge, there is other damage, likely to semiconductors, in the unit.
If you have a meter available, check the components in the power supply section; diodes and discrete transistors can be checked if you have some experience. Also look for standard resistors that may have been fried; sometimes they will only have a narrow burned ring around them. Visually check electrolytic capacitors, small cylindrical cases, marked with uF values and VDC and have polarity symbols on them for any signs of bulging of the tops or chemical deposits on the board & around their bases.
You didn't include make and model numbers so any closer 'guesses' aren't really possible.
Always include these and if you are lucky, a tech with direct knowledge of that specific unit may see it.
Jun 22, 2012 | Televison & Video
TV wont turn on has no power
Hi Scott,
Here are some basic steps that will help you fixing the problem.
I'm assuming that your unit is dead set without an standby LED light and your outlet is live.1.Power cord - check the cord it might be opened (no continuity).This is due to frequent bending,pulling. 2. Power switch - check for dry joints, open contact. 3.Check the internal fuse- sometimes the fuse fail because of the power surge, replacing with new one will cure the problem, If this is the case I would advice you to use surge protector/AVR (Automatic Voltage Regulator). However if the fuse blew again this is an indication that you have a shorted parts in the power supply, you may visit the linkhttp://www.fixya.com/support/r8053361-fuse_keeps_blowing for more info. If no reaction and still the unit didn't power up then you have an open parts on the power supply.
4.If you see that the fuse is intact , don't attempt to touch anything because there some fatalcomponents stored electricity enough to hurt you with a simple mistake only. I would advice you to look for a professional to troubleshoot the power supply. If you want to repair it yourself make sure that you have necessary tools and test instrument. First check bad solder joints(re-solder all cold solder), leaky electrolytic capacitor(sometimes it has bulged at the top but not all, you better have a capacitor checker), open/shorted regulator transistor/IC(mounted in heat sink), open fusible resistor (caused by shorted regulator Transistor/IC), shorted zener diode.
You may also replace the power supply board, check it online like ebay.com and shojimmy.com.
Also, check if your unit is under warranty before opening the back panel, it will void the warranty. Avail it because the manufacturer of your unit will fix it for free or a little charge only.
Hope I helped you.
Have a nice day!
Thanks for using fixya.
Aug 18, 2011 | Proscan Televison & Video
During a thunder storm our polaroid tv went out..we have changed the fuse but it still isn't working..any other suggestions?
Call your homeowners' insurance agent. Seriously, if the set is worth more than your insurance deductible, you will want an expert evaluation on whether the set can be profitably repaired so you can make a claim if necessary.
Was the first fuse blown? Did the second fuse blow? If the answer to both questions is yes, then you have a fried power supply switching transistor - at a minimum. You might even see cracked or burned parts on the board that has the fuse on it (look at the parts on or near the finned metal radiators). Lightning typically damages a number of parts. You may find it cheaper to replace the entire power supply board, and hope the rest of the set isn't damaged.
If both fuses are good, that could be worse news, because that implies lightning got in through the antenna/cable input and zapped the main circuit board. This is the second-most expensive part of the set after the LCD panel.
A suggestion for "next time": if a TV set blows a fuse, get the problem fixed first before risking a new fuse on it. It's rare that a power surge blows the fuse without also breaking something else. The fuse is intended to minimize damage and prevent fire in case something in the TV shorts out or the surge protection components are unable to handle a high energy pulse on the power line. It's not guaranteed to protect the set from damage.
Oct 24, 2010 | Polaroid TLA-04011C 40 in. LCD TV
I have a Mikomi model number 15LCD250. FS601 is blow open circuit, it is a 1206 Surface Mount Fuse with a 5 marked on it in green. Any idea of the value / surge or anti-surge ?
try to look for the caution sign printed in the main board beside the ac supply it is printed there the exact value of fuse. is it totally burned if totally burned you have a shorted parts before replacing it try to locate other defective parts.
Oct 13, 2010 | Televison & Video
LIGHTNING STRUCK THE ELECTRICAL POLE DOWN THE STREET. THERE WAS A POWER SURGE AND WHEN THE POWER RESUME THE TV DID NOT COME ON
Now ur tv LED power light indication on the front LCD panel flashes?Yes,than the power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay,com to buy a refurbish power supply board for the replacement.
Jul 13, 2010 | Toshiba 37AV502U 37 in. LCD HDTV
Have a Toshiba MW24F11 combo tv. Near lightning strike through surge suppressor. Will not turn on. 6.3 amp fuse blown; replace, blew again. Next step, or start looking for replacement. Set is 25...
power surges generally damage diodes and capacitors causing the fuse to blow, any reputable tv shop can repair for a fraction of replacing this set.
Sep 15, 2008 | Televison & Video
No screen on dimension 3100
you have a serious problem. probably the board as a result of lightning or electrical surge.
unplug and open box. look carefully for small burn spots any where on board and cards.
dis connect power supply from board.
diconnect your hard drive from power supply and board.
reconnect everything and plug in and try again.
sometimes it will reset itself and start up again if nothing serious.
Jun 27, 2008 | Dell Dimension 3100 PC Desktop
Philips Magnavox 42MF521D/37 Television Logo
891 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
