Question about Mitsubishi Televison & Video
When you press the power button to turn it on, the green light blinks repeatedly. Sometimes it will make it to the blue welcome screen but will turn off seconds later.
    Genius:
  • 1,622 Answers
Power supply board just die.It can be dead at anytimes.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Thanks and take care
Posted on Sep 02, 2010
PDP-4340HD keeps turning off.
Continuous blinks of standby light indicates a fault in the IIC data bus. The main board is likely to be faulty. If you wish to know more Check this link.
Feb 03, 2013 | Pioneer PureVision PDP-4340HD 43 in....
Sony Bravia KLV-40X250A power indicator blinks once but screen is black
um u should turn your tv off for like 10 minutes , i think yourr tv is a internet tv so let it cool sometimes sony internet tvs freeze with black screen so try it out.
good luck :)
Aug 06, 2012 | Televison & Video
I have a Mitsubishi Model WS-65511 the green light on the front was flahing (would not stop) I replaced the 7 Capacitors as was suggested. The light flashed for a while then stopped and turned green
I think I advised you before (on this page you will find a "make a comment button" which allows follow up questions and answers without posting another question.
Green power light now comes on and goes out in few seconds:
On front of set (not the remote) press and hold when that happens both the menu and input buttons for at least 5 seconds and release both.
Power light will blink a 2 digit code like 2 blinks, 2 blinks, pause and repeat that several times---this is an error code---let me know what code you find.
Note: if you have unplugged the set it clears the error codes and you have to plug back and try to turn set on--let it fail and repeat the self check.
SD TECH
Apr 22, 2012 | Mitsubishi WS-65511 65" Rear Projection...
I have the vs 60719
This set was made around 2001 and should have the self check feature. Unplug set and then plug back in and try to turn set on----if green power light comes on for a few seconds and goes off--ON the front of the set press and hold menu and input buttons together for several seconds and then release--------------power light should blink a two digit error code and repeat it several times.
1 blinks, 2 blinks a pause and then repeats(1,2 is no error found.)
Let me know what you find and comment here.
Nov 17, 2011 | Mitsubishi VS-60719 60" Rear Projection...
Orange light flashes 5 times then green flashes once then repeat Can't get printer to do anything else. Have unpluged it for ten minutes no luck Have removed print head and replaced it, no luck....
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.For printer
Mar 22, 2011 | Canon BubbleJet i560 InkJet Printer
I push power button and my 1080 series 42 in. mitsubishi big screen shuts right back off.
Most of these sets have a self check feature:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device”(device sometimes is called input) and “menu” buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
Let me know what you find and I will tell you what it means.
If this information helped you rate this solution as I do this here for free.
SD TECH
Dec 14, 2009 | Mitsubishi Televison & Video
The middle light keeps flashing 7 times then stops then repeats. the other button to change the paper type. i dont think its a ink issue possibly a paper one.
This mean multiple ink tanks of the same color installed or Ink tank in a wrong position.Check your ink tanks.This ink tanks has a memory chip.Sometimes this chip fails.
If the green light blinks with a orange 7 times this mean the waste ink tank is full.Follow this:
1. Turn off printer
Nov 04, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Supertooth one user manual
Charge your Supertooth one via the car charger or by attaching a usb/mini usb cable to your computer usb port. Need to charge for 4-10 hrs. Indicator light glows red (needs charging), orange (charging) or green (charged)
Power on: Press green button for 1 second. Indicator light blinks blue. A beep will be heard
Power off: Press green button for 1 second. Indicator light turns red. A beep will be heard
To pair with your mobile phone:
1. Press green button on Supertooth for 5 secs until indicator light blinks red/blue 2. Access bluetooth menu on your phone. Turn bluetooth on. Execute a bluetooth search. 3. Select ST ONE from list 4. When phone requests password enter 0000 and press OK 5. The handsfree kit is now ready for use 6. Clip Supertooth on sun visor of your car so that the microphone and control buttons are directed towards you.
To make a call: Dial number on phone. Supertooth will automatically connect. Indicator light is steady blue during call
To end a call: Press red button for 1 second
To answer a call: Press green button for 1 second. The bluetooth indicator will turn a steady blue.
To increase/decrease volume. Press volume buttons repeatedly up or down. They are situated between red and green buttons.
Hope this helps.
Nov 22, 2008 | Cell Phones
Blinking Green Light on Mitsubishi DLP 52525
The 52525 is definitely going to either:
1. have the caps on the FMT/DM board replaced (not something I'd recommend you do yourself)
2. have the electrical chassis rebuilt (as sometimes, you can replace the caps and still have the problem).
wait time: 4-8 weeks
cost to rebuild: $400-$500
cost for labor: $200-$400
Oct 13, 2008 | Mitsubishi WD-52627 52" Television
Open Questions:
Televison & Video Logo
55 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
