I have an ancient 50 inch plasma TV (model 50PF9986), vintage around 2004. I use the AV1 input as the source for everything. No matter what I do with the menus to select that input the set insists on reverting to channel 1 whenever it's restarted. Sometimes when I try to change this I'm asked for a 4 digit PIN by the system, something I never had. I don't mind too much but everyone else who uses the system hates having to re-choose the input source every time one turns it on. Help.
  • fmartino105 Sep 03, 2010
    thanks a lot for the user's manual. I never got one when I bought the TV and have recently been unable to find one. It explained a number of things I've been wanting to clarify(including the PIN issue) but unfortunately didn't solve my problem. I'll try to state it more clearly: whatever source I choose whenever I turn the system off and restart later the TV insists on going back to looking for a signal from channel 1, even though the only signal source in my configuration is AV1. Isn't there some way to tell it to start up looking at AV1 rather than channel 1?
  • 11,896 Answers
Go to the menu, go to tuner or channel settings. Find the autoprogram option. With your device connected to Av1, select the autoprogram option and let it run completely through. It will add all available channels and store them in the tv's memory.
Posted on Sep 19, 2010
  • 666 Answers
The 4 digit pin should be by default 0000 this should allow you to go into your configuration and make sure you save any settings changed also it may be the remote power source used to store the software mechanics and channel programming is fried thus preventing you from changing and saving setting each time it is turned off
hope this helps
Robb
Posted on Sep 08, 2010
  • 12,061 Answers
Http://www.retrevo.com/pdf/23128bh835/19/Features+menu/
Features menu above, below is a pay for link for the service manual, below that is your user manual.
http://www.service-manual.net/ashop/catalogue.php?cat=211&exp=&resultpage=16&shop=1
http://www.retrevo.com/support/Philips-50PF9986-TVs-manual/id/565ag120/t/2/
OK please find manuals above, what you need to know is in these manuals above...
Posted on Sep 03, 2010
Will not turn on I have already replaced the Samsung plasma TV pn60e530a3fxza pwr supply
Samsung Plasma TV - Won't turn on - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have Samsung 50" plasma tv model HP-S5053. The unit would not power on and blue light was out. Tried a different power source which did not change result. Samsung TV LN52A650A1FXZA won't turn on, keeps clicking
Jun 11, 2015
Samsung TV won't turn on
Jun 11, 2015
Samsung LCD TV LN32A330 power won't turn on
Jun 11, 2015
TV won't turn on
Jun 10, 2015
More results from www.cnet.com
Samsung 50 inch plasma wont turn on - YouTube
? 0:59
https://www.youtube.com/watch?v=Uo-SazF_G9Y
Jan 9, 2014 - Uploaded by 8Jallin
Samsung 50 inch plasma wont turn on. 8Jallin ... Up next.samsung plasma tv not working, wouldn't turn on, FIXED, repair, diy - Duration: 14:56.
Feb 09, 2016 | Samsung Televison & Video
Getting" no signal" no matter what source av1,av2,hdmi1,etc. I put it on. Its a 42 inch coby lcd tv everything is hooked up right but still " no signal" what do i do?
most likely your Input/Output PCB. will need complete model/serial# to isolate part number, then try someone like Shopjimmy.com for part listing & price.
Apr 30, 2014 | Televison & Video
My p.s3 will not work on my 42 inch plasma t.v.i used to use an hdmi cable to watch it now im using a.v cords how do i reset or fix the settings it was on before?
Go to the main menu of your tv then try to select for the video input, you will see there the inputs tv or av1,av2, hdmi1,hdmi2 etc. try to choose the av1 or av2.
May 14, 2011 | Televison & Video
Trying to connect to LG 60 inch plasma. no output
Hi.
You need to connect the Bose using the Optical Audio output from TV to Bose main unit (kind of square shaped connector), and not using the RCA inputs on TV.
The picture below is an LG back panel, the optical audio connector is at the lower side of I/O connections at the back of TV, on some model the location of connector may be different.
Dec 26, 2009 | Bose Cinemate Digital Home Theater System...
Samsung Plasma 52 inch flatscreen vintage 2004 - black line
Hi my name is Roety,
I can help you with your issue ,
If the line is present on all inputs, and effects the TV menu you most likely need a new screen.
You can try changing buffers, reseating cables.
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Nov 09, 2009 | Samsung HPN5039 50 in. Plasma HDTV
How do i hookup vcr to tv
The best way to hook up your VCR is to use the AV jacks (Red, White, and yellow). Plug into AV1 or Video 1 on the back of the TV. Then, plug into Red, White, and Yellow output jack on the back of the VCR. After everything is hooked up, turn your TV channel to AV1 or Video 1 to watch from the VCR.
To record, you'll have to plug your cable box or satellite box to the AV inputs ( Red, White, and Yellow) in the back of the VCR. ( The only thing is it wouldn't be in HD )
Nov 04, 2009 | Zenith Z50PX2D 50 in. Plasma HDTV
VP50HDTV10A
hi i have a 50" plasma HP50TV10A and just show half of the tv picture horizontal
Jun 18, 2009 | Vizio VP50 10A 50 in. Plasma TV
50" Vizio Plasma reads "No Signal" on all inputs?
Well, your TV is still under warranty. That's the good part.
The only thing I can recommend without voiding the warranty is leaving the TV unplugged for 30min. That way, the TV can reset itself and hopefully correct the problem.
If that doesn't solve the problem, it's time to use the VIZIO warranty.
Here's contact info if you need it.
Technical Support
Toll-Free: 877.698.4946
(877 MY V I Z I O)
Technical Assistance Emails:
techsupport@vizio.com
Customer Service
Toll-Free:888.849.4623
(888 VIZIO CE)
Jun 17, 2009 | Vizio VP50 10A 50 in. Plasma TV
Vizio 50'' Plasma AV1 & 2 Ports Unresponsive
Put off the TV Using the remote .Then unplug the TV 's power line from power source.Allow this for Just Over one minute .Then plug back the powerline and your TV should be okay.
i had the same problem with wii and this fixed it .
Nov 26, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Open Questions:
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
Electro Med Services...
