Question about Reliance Water Heater #6-50-GORT 50GAL NatGas Water Heater
When water heater is off a strong gas odor is present. checked by closing or shutting valve control assembly to off positon, where no gas ordor is present.
  • 494 Answers
You may have a leaking gas valve control. Make up a squirt bottle of soapy water (use dishwasher soap and water) and spray the On-Off-Pilot knob for leaks, as well as the pilot button. Look for bubbles forming. Also check all the gas line fittings and connectors hooked up to the water heater for leaks. If you are smelling gas, do not attempt to relight the water heater. Close the shut-off valve on the gas line and see if the gas smell goes away. If it does, you may have to replace your gas valve. Depending on the age and condition of your water heater, it may be more cost effective to replace the control or buy a new water heater. Reliance is a common brand sold at stores like Lowe's. Typically, parts like your gas valve will usually only have a 1 year warranty. Check the manufacturer decal on the tank to see what their actual warranty period is. If you find a leak on the gas line itself, you will have to turn the gas off at the natural gas meter before disassembling the line to fix it. Use a soft setting teflon based pipe dope for the pipe threads. If you are uncomfortable doing the work yourself or don't know how to proceed, then call your local gas supplier for help. Douglas
Posted on Sep 03, 2010
Gas Control Valve replacing!
Shut off the water and gas to the heater. Drain the heater. Disassemble the gas line to the heater starting at the Union and working to the gas control. Disconnect thermocouple, burner and pilot tunes from the bottom of the old gas control. The old control will screw out of the front of the heater. Grab the entire housing of the control and twist counterclockwise to remove. Perform new gas control install and connections in reverse. Remember to apply at least 4 wraps of Teflon tape on all threads before assembly. (Teflon paste may be used) Do NOT put any sealant on the thermocouple,burner tube or pilot tube connections (these are compression connections, make them fairly snug.) upon completion, fill heater, turn gas back on relite and check for water or gas leaks
Jan 03, 2014 | Rheem 42VP75FW 75 Gallon Natural Gas Water...
After hot water demand, burner stays lit, blew up Pex supply line
Thermocouple has 2 ends. One end attaches to gas control valve, other end sits inside the pilot flame.
Flame heats thermocouple, causing tiny electrical current that is detected inside the gas control valve and keeps the gas valve open so water heater can turn on when thermostat calls for heating.
If pilot goes out, then no electric current reaches gas control, and all gas to burner and pilot is shut off.
If pex line burst, that implies very high pressure, caused by closed system with check valve that stops expansion, or possible clog in the water line, or high local water pressure, or clogged factory-installed heat traps.
Put pressure gauge like BTG100 on the drain valve to check pressure, should not exceed 80psi, install pressure reducing valve on cold water line, install expansion tank on cold water line. Remove heat traps and install ordinary pex-lined di-electric nipples from hardware store.
If the water was super hot, then overheating could have caused the pipe explosion.
However the gas control thermostat is ECO protected, and if ECO (energy cut off) trips because of high heat detected inside the tank or combustion chamber, the gas control will trip off and no longer work, gas control needs to be replaced. Some newer electronic gas controls can be reset, but that type heater uses a thermopile instead of thermocouple.
Thermopile is basically a group of thermocouples, that product more electric current that is used to power electronics inside the gas control valve, which issues an error code on the gas control, and some day will send a text message each time out-of-range event occurs.
Copy following links for troubleshoot resources, including troubleshoot by type of gas control valve:
http://weaterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
http://waterheatertimer.org/Low-hot-water-pressure.html
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
Jul 12, 2012 | Bosch Aquastar 125B Gas Valve NG - Part...
I have a richmond 40 gallon powervent water heater. It seems to light, but shuts itself off after about 5 seconds. I am leaning toward the vapor sensor. I know there are reset codes, but have not been...
1) Could be the vapor sensor. That's a suspect.
2) General troubleshoot: clean burner and combustion parts, clean air intake, bleed air from gas line, check gas pressure. Color of gas flame should be clear blue, and flame should be strong, and no combustion by-product dripping back into combustion chamber. No chemicals of any kind stored in air supply. Plenty of fresh air. Water heater in hot attic needs more air. If water heater has igniter, then igniter has to be checked. Flame sensor must be positioned correctly and operational at time of combustion, or sensor will signal gas control to turn off gas. Gas control valve can be bad.
Open following link for possible illustrations and reading.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
3) Specific troubleshoot begins with identifying gas control valve and reading the service manual.
I think the Rheem/Richmond power vent has intellivent gas control
Open following link to identify gas valve and download possible service manual:
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html#intelli
4) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 04, 2011 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
New thermostat and pilot/ burner assembly, but the flames from the burner fluctuate up and down then finally shuts off What could it be?
You replaced the gas control valve thermostat, and the burner assembly.
You bled air out of gas line.
Assuming the gas control valve is functioning correctly, the last things would be gas pressure, air intake, and vent draft. If gas control valve is electronic, check outlet with circuit analyzer and make sure ground is connected.
Also if water heater is located in hot attic, or tight house, these things can cause water heater not to function.
Open following links for some resources and illustrations:
Aug 20, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Noise in the water heater valve. How do I fix it?
Valve is not identified.
Cold water shut-off valve, TP valve, check valve, mixing valve, drain valve are the usual suspects associated with electric water heater.
Gas water heater has additional valves: gas shut off valve and gas control valve thermostat.
Check valve, TP valve and mixing valve probably need replacement.
If drain valve is leaking, put garden hose cap over end.
Shut off valve probably has a bit of blockage, or is not completely open. Try closing and then opening shut-off valve all the way, and if problem persists, replace or clean out valve.
What kind of noise? Are you sure the noise is from a valve or is it inside the tank caused by sediment build-up inside of tank?
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
http://waterheatertimer.org/How-to-replace-TP-valve.html
http://waterheatertimer.org/images/Water-heater-with-mixing-valve-300.jpg
Jul 04, 2011 | RTO Bradford White M-1-20U6SS 19 Gallon...
Basemnt flooded water heater wont stay lit ever since, taken out burner assembly severl times now stays on long enough to heat water then shuts down soon after.replaced thermocoupler and have to lite...
Sounds like the air intake is clogged, and pilot and burner tubes are dirty.
All manufacturers say that flooded water heater should be replaced and not repaired.
You can clean air intake and burner assembly, and then next step would be to replace burner assembly and replace gas valve thermostat to see if functionality returns.
Expense of replacing parts is about half the cost of new gas water heater from box store, and still no guarantee that old heater will work.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
Jun 22, 2011 | Water Heaters
I have a Reliance 501 Gas that is leaking water from the bottom. How do I shut the water off and how do I turn off the gas
There should be a valve on the cold water supply entering the top of your heater. This may be a gate or globe valve with a circular handle on it. If you have this type of valve then turn handle clockwise,to the right to close it. You can check output on hot side of faucet to see if valve is working. There may be a ball valve with a straight handle on it. To shut this off push or oull handle till it is at right angle to valve. As a last resort you may have to shut off water supply to house.
On the gas start out bt shuting gas off at control knob on top of gas valve. It should be marked on off and pilot. Turn to off. Now check on incoming gas line for valve to shut gas off before it gets to gas valve. This valve should have a raised flat section that you can close with a adjustable wrench.Turn till it is at right angle to pipe and you should be done. Turn to right to shut it off. Hope this helps you. Thanks
Dec 23, 2010 | Reliance Natural Gas Water Heater Control
How to change bad thermocouple on reliance gas hot waterheater reliance 606
it is important to turn off
the gas supply to the water heater at the manual gas shut-off
valve. This valve is typically located beside the water heater.
Note the position of the shut-off valve in the open/on position
then proceed to turn it off.
2. On the lower front of the water heater locate the combination
gas control valve/thermostat. Depress and hold
the lock tab located under the gas control knob on the right.
Rotate the gas control knob on the combination gas control
valve/thermostat clockwise until "OFF" aligns with the mark on
the front of the gas valve. Once the gas supply has been shutoff,
remove outer door. 3. Using a 1/4" nut driver or socket loosen the two screws securing
the manifold door assembly until they are free. Do not
totally remove the screws and plastic retainer washers from
the manifold door. The screws and retainer washers will be
needed to reattach the manifold door. 4. In this step, the thermocouple, manifold tube, pilot tube and
igniter wire will be disconnected from the combination gas
control valve/thermostat. Using a 7/16" wrench
disconnect the thermocouple (left-hand thread) and pilot tube
(right-hand thread). Using a 3/4" wrench disconnect the manifold
tube (right-hand thread). Carefully pull the igniter wire from
the igniter button.
5. Grasp the manifold tube and push down slightly to free the
manifold tube, pilot tube, and thermocouple from the combination
gas control valve/thermostat. when installation is complete and gas is back on, You should be able to relight the pilot and the functionality of your gas hot water heater should be restored.
Nov 27, 2010 | Reliance Natural Gas Water Heater Control
Rheem/GE power vent water heater, pilot lites, but not the main
I would check to see if the switch on the blower pressure sensor is closing...When T-stat calls for flame, the circuit starts the blower, then the blower pressure sensor switch closes to allow the main gas valve to be powered.
Jul 08, 2009 | Water Heaters
Reliance Water Heater #6-50-GORT 50GAL NatGas Water Heater Logo
99 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
rickb63
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
