Question about Vacuums
I need a manual for a NECCHI Model 535FASerial nember 088549 sewing machine
  • 8,197 Answers
You can find all the manuals for many different sewing machines and download them from the following web site.They do require some fee though.
http://www.sewingmanuals.com/Sewing_Machine_Manuals/Necchi.htm
Or you can go to this link to learn how to thread.
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Necchi_Sewing_Machine_Threading/Necchi_534_535_threading_Diagram.htm
Good Luck and please rate 4 thumbs up for the free answer
Posted on Sep 02, 2010
Royal Series, Necchi, Model # 80331763 bobbin does not take up thread properly. No manual unsure if i am threading it correctly.
You can get Necchi instruction manual from Necchi website: http://www.sewusa.com/Sewing_Machine_Manuals/Necchi_Sewing_Machines.htm". Makesure the needle is in the machine correctly- all the way up into the needlebar, make sure that it is threaded correctly, etc. If this all checks out ok,take the bobbin case out of the machine. There are two ears on either side ofthe bobbin case- turn the left one to the left and the right one to the right.Remove the silver ring, and inspect the piece of metal that the ring came off of(looks like a circle with the top cut off). You have to locate the hook whichis the piece that looks like a half moon inside the big round metal piece.Locate the tip of it, turn the hand wheel toward you until the needle is in thelowest position, at this point the tip of the hook should be flush with top ofthe left side of the cut off circle. Checkwhether underneath thread is looping on the fabric. If so then you've mis-threadedthe top, probably haven't raised the presser foot when threading so you can getthe upper thread into the tension. You need to thread the upper part with thepresser foot up. (You can put it down to thread the needle.)
Not picking up thread can be several issues, like bobbin is miswound, bobbincase isn't snapped in properly, you're using the wrong type bobbin, machine isout of time, needle is bent or burred, machine is dirty and in need of dustbunny eviction and a little oil but most of the time the issue is once againmisthreading: sewing machine needles have a front and a back and they have tobe placed in the needle holder correctly. In that case your manual is needed, take all the thread offthe machine (yes, spool off the spool pin, bobbin out of the bobbin case), pullthe needle plate and clean your machine thoroughly, using brush and vacuum (notcompressed air) and oiling per the instruction manual. Put it all backtogether, putting in a 80/12 needle, correctly oriented. Hang on to theneedle thread when you fetch up the bobbin thread.
Each and every seam you start is going to be done this way:
1) Pull the tail of the top and bobbin thread behind the presser foot
2) Put the work under the needle and use the hand wheel to lower the needleinto the work
3) Drop the presser foot
4) Holding the thread tails behind the foot, take a couple of stitches.
5) Drop the thread tails and sew normally. Hope this will help you. Good Luck.
Sep 12, 2011 | Vacuums
I've lost my user manual for my necchi sub22 sewing machine and can't for the life of me remember how to wind the thread onto a bobbin. Not a big issue, but it's really bugging me, because I...
You could email: spares@aeuk.co.uk and ask for a manual or call (+44)1322 291137 x 2 between 10:00 and 14:30
Or (Thanks to an article 10 months ago from Farmerbear) you could go to allyint.com
They are the sole US importer of the Necchi machines and I believe they stock replacement manuals. Their number is: 1 800 525 9987 ex 20
Jun 30, 2011 | Vacuums
How to get Brother sewing machine apart to replace spool spindle.
To be honest the best thingon such instructions is the manual which is provided along with the machines,but many people don't have it , probably because they have lost the manual orthey have got the machine as a used one and forgot to take the manual alongwith it.
Please follow the belowinstructions :-
Close to the end of theHandwheel , there is usually a spindle, at the back of the machine.
This is where you need to restthe spool on and you would notice it sitting perfectly.
In case the length of the spindleis less , then pull it up gently with your fingers.
Also there are machines these dayswhich have easy to replace facilities , so the spindles just slide intothe machine for safety norms when you put the machine away.
Therefore , all you need to do it pullit up and it would be fine.
An example of a manual forbrother's sewing machine can be found in the below link which would give you anidea of how exactly it's done.
http://bit.ly/j2BdsP
Hope this helps ..:)
Jun 11, 2011 | Vacuums
I have a Necchi model 3205 in December 2010 and For no reason the upper tension knob pop off and all the inner springs and the washers like things went accross the floor I would like to know the name off a...
Email or contact these folks and see if they can help you:
Mario Necchi Import & Export Inc.
Fax: (450) 653-6160
Saint-Bruno, Quebec, Canada
E-Mail: necchi@total.net
or
http://www.necchi-importexport.com/contact1.htm
Email for main corporate site: info@necchi.it
Thanks for choosing FixYa,
Kelly
May 17, 2011 | Vacuums
Free owners manual for Necchi 575FA sewing machine
Find the Vintage Necchi page on Facebook. Lots of FREE NECCHI MANUALS there. I will have the 575FA manual posted there in less than a week. These other answers are posted by m0r0ns who are sending you to sites that CHARGE. I guess these stoopid jerks don't know what the words FREE MANUAL mean.
If you go to the Necchi-USA website, they will refer you to a website that sells manuals because they don't want to be bothered by the old machines. Keep that in mind if you consider buying a manual from a company that washes their hands of their products when they decide they can't make enough money from selling parts and keeping free manuals for them.
Mar 22, 2011 | Vacuums
I need a users manual for a necchi 931 sewing machine
Go to the manufacturer website to find out where to obtain a manual or find a local distributor and inquire on how to get one. You probably will have to buy it.
Feb 12, 2011 | Vacuums
I have a Necchi Renaissance 2 sewing machine that I can't seem to get accessories for I live in South Yorkshire, any ideas?
You could go on line and have the parts send to you. Here a web site that will help you buy the parts.
http://www.sewingstyle.com/Necchi-Sewing-Belts.html Hope that this will help you.
Jan 25, 2011 | Vacuums
My Necchi supernova ultra mark 2 (50 year old) sewing machine's belt broke (13 inch length). I'm having trouble finding one on-line. Any idea where to get one?
I have the same machine and I see the belt has been replaced. It's a Singer belt. You might wanna try that.
Oct 03, 2010 | Vacuums
Vacuums Logo
220 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
