Question about Dishwashers
Asko 1755 dishwasher. The pump keeps running and the fault lights indicate high water level. Problem appears to have been a clogged filter, which is now remedied and all water removed. How do I reset the machine?
5 Suggested Answers
  • 59 Answers
SOURCE: Asko dishwasher 1475 indicates high water level
The "High Water Level" in the machine can be triggered not only by the Styrofoam operated switch in the safety tray under the machine's tub, but also by the Overfill Pressure Switch pictured here
My previous post describes the erratic behavior this switch can cause. It seemed almost at random, the "High Water Level" condition would occur in whatever cycle I used.
It is easily located at the end of a small rubber hose visible when the kick panel and service covers are removed. Look just above where the electrical power terminal block is. The switch is held in place by the clip protruding from the top (as shown in the picture above). The sides of the clip need to be pressed towards the center to release the switch. I simply rotated the switch until the clip was turned to the longer side of the rectangular hole it clips in to. It then just fell out.
This pressure switch triggers the drain pump when too much water enters the machine, but it can malfunction and will keep the drain pump running "forever" until you turn off the breaker. Unfortunately, until the problem is rectified, the dishwasher "remembers" what it was doing when you disconnected the power and when you re apply power, the drain pump will again start draining your already empty dishwasher.
I pulled the connectors attached to the spade terminals on the switch back a bit and then forward as far as they would go ensuring all the wires had continuity from the terminal to the opposite end of the wire it was attached to. When I re applied the power, the empty dry dishwasher attempted to start up where it left off in the cycle it was on, but the "High Water Level" conditioned cleared. Pressing and holding the single button opposite the light left on canceled the cycle and the machine went into standby as it should.
I hope this helps someone else. Until I "Googled" the part number printed on the switch, I didn't know what triggered the "overfill" or "High Water Level" condition.
Part number on the part was 8058475. I also found out the small hose attached is part number 8058500. The small hose is not as readily available as the pressure switch, so extra care should be used when handling it.
Posted on Dec 03, 2007
  • 52 Answers
SOURCE: Dishwasher fault
F1 Water heating fault, selected temperature not reached within 60 minutes · Incoming water temperature too cool
· Heating element burned out
· Thermostat defective
Posted on Jan 29, 2008
  • 5 Answers
SOURCE: asko 1805 - all idnicator lamps blinking
Searched some more on this site and found the following from a guest (thanks). It solved my problem, the base where all the electrics and plumbing is located had a pool of water. I had to pull the unit out as I could not access this area from the front.
This is a common problem with the Asko1805. The machine is equipped with overfill protection. Water has leaked through to the bottom pan and has triggered the overflow shutoff float. You must get the water out of the bottom of the dishwasher. Unscrew the kickplate and the metal cover to access the bottom of the machine where the pumps and motors reside. Use a sponge to slop up the water in the pan. Blow dry the bottom. The machine will reset itself as soon as the water is gone.
Posted on Apr 18, 2009
SOURCE: Asko 1755 dishwasher. The pump
My Asko Model 1585, Type DW 95.4 Circulation pump just died. I have the following parts available (All in working condition):
* 8057931-05 Control Board (this is the replacement part AFTER the recall)
* 8057083 Drain Pump
* 8057085 Fan circulation module (the one in the dishwasher door)
* 8057077 Heating Element
Photos and motor/coil/element resistance values available on request. I have no prices listed as I am still trying to determine their value. I am an old Boy Scout & NOT out to screw anybody.
Posted on Nov 13, 2011
I have a 1776 Asko model & it doesn't finish its cycle-code mesage f-2 keeps appearing. Can you help me out.
Hi
F2 is a drain error and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Sep 18, 2011 | Asko 1375 Dishwasher
I have a dishwasher AEG BM335 super cleaning system. I got a message: F2, and machine stoppet washing, all red lights are on. What can I do? Is any hope for repairing? My name: Arna...
Hi
F2 error in your Asko dishwasher indicates that the water is not draining or is unable to drain and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 02, 2011 | Asko D1706 Built-in Dishwasher
Dishwasher runs part way thru cycle then f2 cumes up all lights come on and draim pumps runs all the time even with door open
F2 signifies high water level. Check the drain pump and drain hose, make sure they are not clogged. Check the operation of the water inlet valve.
Feb 23, 2011 | Asko D1776 Built-in Dishwasher
I have an F2 error and the fan or dryer keeps running...i understand that this means a high water level and i have already checked the screens and filters. but how do i turn off the dryer so i may safely...
Hello, Welcome to FixYa. Sorry you have had to wait so long for a reply, it seems there are only a limited number of techs here familiar with Asko. Anyway, yes F2 normally would indicate a hi water level detected...normally. The difefrence in your case being the fact of the condensor/dry fan running. This is a red flag. In these scenario's 99% of the time the control is at fault. If you remove the door and control panel and visually inspect the control you will most certainly see burnt circuits on the control. If you have not already found the problem or hired a tech to look at the dishwasher, let me know and I'll guide you in what to do and to look for in more detail. I'll watch for a reply, Macmarkus :)
Aug 13, 2010 | Asko D1776 Built-in Dishwasher
F2 error message after dishwasher backed up when draining. Asko brand.
Hi
Thanks for using FixYa. Error F2 in your Asko Dishwasher means high water level. This error occurs due to plugged/bad water pump and/or a bad inlet valve. If the water pump and/or water inlet valve are bad it should be replaced to resolve this issue. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 26, 2010 | Dishwashers
What is the F 2 error and how do you fix it? the fan or dryer keeps running.
Hello there:
The dreaded f2 error is a high water level fault that is due to the drainage system either being clogged up in the piping system or the pump screen is clogged or there is a obstruction in the pump itself or the pump has failed .
So what you will need to do is to first make sure that all of the filters or screens are cleaned refer to your owners manual for the location and then inspect the entire drainage system going to the pump and from the pump to the water outlet from the machine this could also involve removing the pump itself and inspecting ok
Hopefully this is very helpful for you
Best regards michael
Jan 07, 2010 | Asko D1776 Built-in Dishwasher
Fault indicator on Asko D-3250 (heavy wash/ too much water has en
the float switch must be stuck the up position or water inside the pan or a bad float switch..
hope it helps.... if NOT let me know more about your problem...
Sep 25, 2009 | Asko 24 in. D3250 Built-in Dishwasher
MY DISHWASHER DON'T WORK THE FAULT CODE IS f. wHAT
The F2 problem in Asko dishwasher is due to the high water level condition.The reason is bad water pump or a defective water inlet valve. you should try replacing this and your problem will be fixed.
Sep 10, 2009 | Asko Dishwashers
Miele dishwasher G2870 scm. There is an F14 fault. I have cleaned the arms removed the waste basket from the bottom of the dishwasher and removed the two parts one with the large metal ball to expose the...
F14 on your model of dishwasher is indicating a blockage, poor water pressure or could be a fault with the pump pressure level switch or circulation pump.
Filter and non return valve is cleaned of any blockages and if the fault persists have it service..
hope this help.
Apr 23, 2008 | Dishwashers
F4 Fault indication
F4 is a water inlet fault. It doesn't make sense if you have this fault indication with water flowing into the unit. Does the dishwasher drain properly? Usual suspects for an F4 indication would be a clogged inlet line, water supply turned off, bad fill valve, or a control board failure. Let me know if this helps, or give me a little more information on what you have done to correct so far.
Jul 09, 2007 | Asko 24 in. D3350 Dishwasher
Dishwashers Logo
127 people viewed this question
Top Dishwashers Experts
Owen Barnes
