Question about Brother MFC 210C All-In-One InkJet Printer
Dried out ink blockage?
Hi there, unfortunately there were a few months gap between runnin out of ink and replacing my black ink cartridge in my brother multifunctional printer. I have cleaned with cotton buds and a damp cloth and removed some dried ink from around the protruding spike. however although colour will print, the black still will not =( . please could you give me some advice on how to clean the areas I cannot easily get to on this ink channel
regards
MFC-210C color blokage new ink no color
  • 81 Answers
Hi, unless you can remove the printhead this is going to be a hard task. If you can remove the printhead, hold it over steam (using tongs) for a couple of minutes. If you cant remove it, then you could try a hot damp cloth, and hold it on the printhead till the cloth cools, repeat 4-5 times and see how this goes
Posted on May 14, 2008
Not printing in black and white from my mp 560
If the black ink injector is blocked by after market ink clogging or drying out of ink in the nozzles, get an eye dropper and put a few drops of ammonia on the ink pad below the ink cartridge. Do the deep clean from the printer control section in the software. If you do not have that feature delete and reload the printer driver from Canon.
You might have to do this on several days in succession. If the blockage is severe. It might not be repairable. If memory serves the ink holder, where the cartridges sit, is replaceable for worst case blockages or burned out injectors. You might get one cheap on Ebay. (Don't buy after market ink cartridges. They do not have the chip that sends information about the ink level to the printer. Without that feedback the printer can refuse to operate at all. )
I have one with stripped gears so all those parts work. The paper carriage will not advance to print in my old printer. But every thing else works.
Jun 23, 2014 | Canon MP560 All-In-One InkJet Printer
Why doesn't my black ink work in my Epson WorkForce 600 series after replacing the black ink cartridge?
The Epson printer may only use genuine ink cartridges which contain a chip so that you cannot fill the cartridge with ink or use non genuine ink cartridges.
OR
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Feb 01, 2013 | Office Equipment & Supplies
The black ink keeps drying up and will not print out black print
INK PROBLEM
Jan 03, 2013 | Canon Cli526 Black Cyan Magenta Yellow 3x...
Check ink cartridge on right
Yes - if they are not used they will dry up and be unusable.
Unfortunate but you need to replace them.
For future ref - IF they will not be used in 4 - 6 months
pop them out and put scotch tape on the head where ink comes out
and that should keep them good for several months..
I have done that and close to a year later - was fine.
Hope this helps :)
Sep 30, 2012 | HP Photosmart C4180 All-In-One InkJet...
Printer only won't print in black
My printer did that a few months ago. I tried everything to get it printing black but in the end I had to take the ink cartridge back and return a new one. Some ink cartridges dry out when they are being shipped if not stored in proper conditions.
Mar 14, 2010 | HP Officejet 6500 Wireless All-in-One...
Red ink not coming through
Hi, Epson usually recommend at least 6 cleans of the print head to clear any blockages. However, be warned this can use up a lot of the remaining ink, and may not resolve your issue. You may have dried ink in the magenta tank, and I would suggest replacing the ink if the first solution does not work
Aug 18, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Black Ink Cartridge error
clean the head With alcohol ,dry put it back
the head is jam !
Mar 10, 2008 | HP Officejet 4110 All-In-One InkJet...
Black ink not printing
Having had the same problem on my 425cn Brother with the black ink, I'm told that the solution is hot water. I goes something like this: remove cartridge, place in container with hot water for a while, remove allow to dry completely, replace, perform clean cycle and print test page. Apparently it's imperative to dry completely and stand cartridge upright. The warm water thins the ink, and remove (apparently) blockages. I cannot verify that this works, but will try it this weekend and let you know! If the housing that the ink cartridge can be readily removed, take that out and clean in warm water. Again dry very well before returning. Be care full that ink becomes runny and may leak out of cartridge and make a mess - so work carefully.
Feb 13, 2008 | Brother MFC-5840CN All-In-One InkJet...
What you can try is the following:
press menu then start black copy then fourtimes arrow-up button. machine will be in maintenance mode. press 7 then 6 then 4 then OK (or start bk copy). machine will refresh the tubes and ph with fresh ink and do some cleaning routines. When finished press 7 then 6 then 3 then OK (or start bk copy). Machine will do a powerpurge. Aftertaht leave the maintenance mode by pressing 9 then 9. Run a quality test print by pressing INK etc.
If you are lucky the ph part for bk will work again.
If not the ph has dried out and cant be fixed anymore. The ph needs replacing.
Dec 06, 2007 | Brother Multi-Function Center MFC-240C...
Brother MFC 210C All-In-One InkJet Printer Logo
107 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
