Question about GE WDSR2080D Top Load Washer
My wdsr2080d will not drain - GE WDSR2080D Top Load Washer
  • GE Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Sep 03, 2010
GE Washer will not agitate but it will spin
Put old coupler back on transmission shaft. Can you now turn coupler? You should not be able to. If you can, grooves in coupler are stripped out. Replace coupler. Part # WH49X10042
Sep 13, 2017 | GE WDSR2080D Top Load Washer
Top load washer WLSE4000GOWW is not draining?
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 08, 2010 | GE WDSR2080D Top Load Washer
Washer won't drain
HI, Try these
  1. Inspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch (some models)
  4. Inspect the water pump
  5. Inspect the drive belt (belt drive only)
  6. Inspect the motor coupler
pls rate my suggestion.....
Jul 20, 2009 | GE WDSR2080D Top Load Washer
My GE WDSR2080D washer won't spin or drain.
The crappy designed mexicanical lid switch device has faile, jump it out. Remove the front panel and then you can get the top off to access this problematic lid switch.
Jun 14, 2009 | GE WDSR2080D Top Load Washer
GE Mod WDSR2080D5WW won't drain
The last one I repaired had a 2 quarters in the pump.
Remove the hoses and inspect the pump for coinage.
Feb 03, 2009 | GE WDSR2080D Top Load Washer
Washer will not drain
ck pump for obstruction ..remove front by pressing clips along top edge with putty knife front will lift off pump lower right side
Jul 19, 2008 | GE WDSR2080D Top Load Washer
GE Top Load washing machine not draining
  • to me it sound as if waterpump is not working
Apr 09, 2008 | GE WDSR2080D Top Load Washer
Washer
relay switch between timing circuit and spin cycle is faulty
Apr 03, 2008 | GE WDSR2080D Top Load Washer
Will agitate, but will not spin
hover gemini. mod.A6516-010 will agitate but will not spin.thanks .henry
Jan 01, 2008 | GE WDSR2080D Top Load Washer
GE WDSR2080D Top Load Washer Logo
82 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
