Question about Honda Mmd 5000 Watt Generator W/ Engine Ngk 6000H
My engine is overheating seriously, what is responsible?
  • 11,896 Answers
Plugged air filter, plugged exhaust or oil is old or not light enough wait.
Posted on Sep 02, 2010
1200 BAKKIE OVERHEATED, WATER PUMP IS THE CULPRET, NOW SHE WONT START, WHAT COULD BE WRONG
Depends how hot it became depends on the damage caused - overheating is a very broad term that is often used when "cooked" would be more appropriate.
Mild overheating can burn the oil from cylinders robbing them of compression but seriously cooking an engine can destroy rubber components, weaken valve springs, melt pistons and create serious distortion of metal components.
Only a back to basics systematic approach can estimate the damage...
Sep 06, 2017 | Cars & Trucks
They have change the piston on my car and its doesn't crank and it shows the engine service light that has a spanner in orange please help
The repair and your current problem might not be related and perhaps not even the spanner light is related.
If the repair was only a short time ago you should give the repairer a call in the first instance in case the problem is related.
An engine piston does not develop a hole for no reason. Pistons are strong and reliable and something else must have happened, something fairly serious, to have caused a hole.
Either the ingress of foreign matter due to bad or incorrect maintenance, something within the engine broke or maybe serious overheating within the cylinder occurred.
Replacing the piston without discovering what caused the trouble in the first place (and curing it) would be a very bad repair.
If it was serious overheating that caused the hole, the overheating could have been caused by preignition or a faulty engine management system and in that case your present problem might be connected to the original cause, though your current problem could be a faulty starter motor or immobiliser.
To discover the exact meaning of the spanner light you should read your vehicle handbook.
Apr 08, 2016 | 2007 Opel Zafira 1.6
What can cause my gauge to rise to hot but it does not over heat.on a 2000dodge grand caravan sport.
How do you know it is not overheating. It may very well be overheating but it has not blown a tube or gasket yet to have that tell tale sign of steam coming form the engine compartment. Careful about driving with an overheated car as you can do some serious and expensive damage to your engine.
Mar 24, 2015 | Cars & Trucks
What may be the reason for my e36 bmw not starting since the radiator has cracked
It depends a lot on what caused the radiator to crack and what happened afterwards.
If the radiator cracked due to frost damage then mechanical damage to engine components is a possibility. One of the consequences of a frozen radiator can be serious overheating as the flow of coolant is prevented.
The consequences of overheating however it was caused can be engine damage from the head gasket to serious damage of engine components and a few basic checks could indicate if the engine is still mechanically sound.
A large quantity of coolant being lost suddenly can find its way into the ignition system preventing the spark.
Feb 17, 2015 | BMW Cars & Trucks
I'm Ibrahim, My 2002 model Toyota Avalon is overheating seriously and constantly. The radiator was changed to double cell and still new and has been flushed, the fan is working but temp gauge
The vehicle apparently has never been tested to find the problem
Need a better shop
Could be a head gasket,timing belt,blocked converter
Many possiblilites
Dec 04, 2014 | Toyota Cars & Trucks
Nissan engines problems
A flashing light is a serious issue. Get the trouble codes reads and post so we can help you. Stop driving it. You're causing further damage to the catalytic converter--a VERY expensive part.
Flashing check engine light is serious Ricks Free Auto Repair Advice
Nov 04, 2017 | 2006 Nissan Navara 2.5
Took out the thermostat, replaced the radiator, the water is circulating in the radiator but it is still running hot. what do i do next?
Overheating can seriously damage a car's engine if left unchecked. Although overheating simply means that a car's engine temperature exceeds normal operating temperatures, the causes of overheating are varied. What follows is a brief list of some of the most common causes of engine overheating.
    Faulty Radiator
  1. A car that overheats will often have a faulty radiator. A radiator is responsible for cooling hot engine coolant that picks up heat from inside a car's running engine. A radiator "radiates" the heat from engine coolant out into the outside air. A faulty radiator loses its "radiating" effects and allows engine coolant to become overheated, thus rendering it ineffective at adequately cooling and engine.
  2. Faulty Water Pump
  3. A faulty or malfunctioning water pump prevents adequate engine coolant flow and can cause a car to overheat. A water pump serves to pressurize and propel engine coolant throughout a car's engine and radiator to increase the heat-reducing capabilities of engine coolant. A faulty water pump loses its ability to adequately pump and propel engine coolant, and can cause a car to overheat.
  4. Coolant System Leaks
  5. A leaky engine coolant system reduces the level of circulating engine coolant, which increases engine temperature and leads to engine overheating. Radiators, water pumps, and coolant system hoses and seals--all of these coolant system parts can develop leaks, which can result in low coolant levels and engine overheating.
  6. Faulty Thermostat
  7. A car thermostat regulates the flow of engine coolant. A thermostat is a heat-sensitive valve that opens when a car engine reaches a set operating temperature and closes when a car engine is cold and warming up. If a thermostat gets stuck in the closed position, coolant will be prevented from reaching the engine, which will quickly lead to engine overheating and potential engine damage.
  8. Low Engine Oil Level
  9. Engine oil, in addition to lubricating an engine's internal parts, helps to keep engine operating temperatures reduced by eliminating friction within the engine. If engine oil levels are low, friction and heat build up inside an engine, a condition that causes increased engine operating temperatures and can lead to engine overheating.
Jan 15, 2011 | 1998 Isuzu Rodeo
My high engine temperature light is keep coming on like the car is over overheating
then most likely you must assume it is overheating, not to pay attention to this light risks serious engine damage, have it checked by a shop ASAP
Oct 27, 2009 | 2000 Jaguar S-Type
My STS ( 180000 miles) is overheating in traffic
Dude KravCar i seriously want to thank you for helping me fix my car!!@! i have a 1995 Oldsmobile Aurora Northstar 4.0 V8 and i came across your response to someone who was having an overheating problem with their Northstar Engine.....you commented for them to remove and inspect one of the purge lines to bleed out the air........ now after countless hours in my garage and wrongful diagnosis from a repair shop i finnaly have my engine running back fine after reading your response......thanx dude
Aug 06, 2009 | 1998 Cadillac Seville
'94 olds 88 error code 'hot...a/c disabled' -- Car shuts off
That is likely a ground problem.I had the same issue a few days ago with a customers car.See my response to another individual who has the same problem.It also did away with the hot ac-disabled problem and no more stalling.This might not solve your problem but I would seriously try it.
Jun 25, 2009 | 1995 Oldsmobile Ninety Eight
Honda Mmd 5000 Watt Generator W/  Engine Ngk 6000H Logo
107 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
