Question about Groove Tubes Power Back 5,250-Watt Portable Generator #GT5250-WK
Low oil. Do I fill through opening where dip stick is located?
  • 45 Answers
Yes that is where you fill the oil from be sure notto overfill
Posted on Sep 09, 2010
How much oil do I put in my car 19 00 cc
1. Turn off engine ,
2. Take of oil cap on engine
3. Put in a little oil in oil filler hole of engine.
4. then pull out the oil dip stick from engine
5. and clean the dip stick on a rag.
6. Put dip stick back in engine
7. pull out again and check the level showing on the dip Stick
8. If level is too low on dip stick and is not at full level go back to step 1
These steps ensures you avoid over filling the engine with oil
Tip for beginners
The 4 litre oil bottle is way too much oil for an engine to handle.
If you have a full 4 litre oil plastic bottle square shape . hold the bottle on its side to pour the oil out slowly and smoothly.
Jun 04, 2016 | 2005 Mitsubishi Carisma 1.6
How to tell the motor oil is filled on the dip stick
The dip stick has markings on it showing the level it should be at.
Jan 04, 2016 | 1997 Cadillac Eldorado
Oil can indicator remains on while driving
If it drives OK and doesn't start knocking. Replace the oil sender unit.
Apr 28, 2015 | Nissan Cars & Trucks
Oil dipstick tube broke
look on dip stick you should see cross hatched area with add oil or oil full mark.if you wipe oil dip stick with a clean paper towel and dip stick look dry no sign of oil add little oil at a time see if oil level reach add oil mark or the full mark.if oil is low. low oil light will turn on if bulb is blowed but if dip stick look dry oil level could be low,add little bit at a time dont over fill.
Feb 16, 2012 | Cars & Trucks
Transmission warning light coming on,possible problems are low oil pressure or no oil pressure how do i check which one it is and fix it? Thankyou
If you have an Automatic transmission. Lift the hood. Locate the Transmission dip stick. Start the engine and let the engine warm up some. then check the fliud level on the dip stick. On a Manual Transmission, locate the transmission under the vehicle and the fill plug (upper) and drain plug (lower) on the transmission. Remove the fill plug (upper) and see if fluid runs out. If no fluid runs out, add recommeded transission fluid until the fluid starts running out, the replace fill plug..
Jan 25, 2011 | Ford F Cars & Trucks
HOW DO YOU CHECK THE OIL LEVEL IN A 1981 HONDA 1100GL
There is a dip stick located on the right side of the engine about 4 inches to the front of the oil fill cap.
Make sure you are on level ground. Unscrew the dip stick and wipe it off. Replace the dip stick and then remove again. Check the oil level and replace. If you need to add oil, remove the filler cap and add oil 1 to 2 ounces at a time. Check the oil dip stick to ensure that your oil level is correct.
NOTE: warm up your bike before performing the above checks.
Regards,
Oz
If you find this helpful, please vote on it. Thank You.
Oct 19, 2010 | 1981 Honda GL 1100 Innerstate Gold Wing
Transmission dipstick location
the dip stick is located in engine compartment if you stand in front of car with hood open the dip stick is to your left on side of trany, if this car is stick shift and not automatic then theres no dip stick its checked from side of trany by removing a plug and fill until oil runs out a little a lift would be the way to check it, the car must be level
NOTE; some models have a tube with dip stick and some a cap that unscrews on top of trany and when checking fluid you dont screw in just stick in hole to check level when done then screw back in and tighten,heres a diagram to help you find it.c083006.gif
Aug 25, 2010 | 1991 Honda Civic
How do I add oil? Where is the oil fill located?
LOOK UNDER THE HOOD LOOK ON FRONT VALVE COVER THATS WHERE OIL FILL CAP LOCATED.YOU HAVE A OIL LEVEL DIP STICK BELOW THE FRONT VALVE COVER.LOOK ON THE OIL LEVEL DIP STICK WHEN ADDING OIL DONT OVER FILL THE FULL MARK LINE ON OIL DIP STICK THAT WHERE YOUR OIL LEVEL SHOULD BE DONT GO PASS THE FULL MARK.
Aug 12, 2010 | 2005 Chrysler Town & Country
The dip stick housing is missing on my 1992 Pontiac Bonniville. Where on the engine is the dip stick located?
The housing actually sits in front of the engine under the oil fill cap. It sits pretty close and low to the engine so it looks as if there is no housing. See image:
Aug 05, 2009 | 1992 Pontiac Bonneville
2002 Trooper has trans leak low on floiud do I fill at rear
NO NO NO...IF ITS AUTOMATIC IT WILL HAVE A DIP STICK LIKE AN OIL DIP STICK. LOOK FOR IT THEN PULL IT OUT AND ADD. MAKE SURE THAT ITS LOW BY READING THE STICK EITHER IT WILL SAY COLD OR HOT. IF ITS BELOW COLD OR THE LINE THEN YOU WOULD NEED TO ADD. BUT REMEMBER IN ORDER TO HAVE ACCURACY ON READING THE DIP STICK U MUST HAVE THE CAR RUNNING IN PARK.
Dec 21, 2008 | 1998 Isuzu Rodeo
Groove Tubes Power Back 5,250-Watt Portable Generator #GT5250-WK Logo
168 people viewed this question
Top Groove Tubes Electrical Supplies Experts
Jim Parker
Jim Parker
 steve
steve
Bill Boyd
Are you a Groove Tubes Electrical Supply Expert? Answer questions, earn points and help others
