Question about Goodman Heating & Cooling
Pipes iceing up and not cooling house - Goodman Heating & Cooling
    Master:
    Sergeant:
  • 449 Answers
You need to call atech to come out and check your unit twomany thing to list could be wrong
Posted on Sep 03, 2010
High efficiency outside air conditioner does not cool house, seems to for a while but stops. The pipes at the air conditioner are coated with ice so seems to produce cold but does not blow that through the...
Unfortunately, the ice coating isn't normal, in fact, it is an indication that your unit is low on freon or a blockage. But could also mean a few other things.
But about the only thing you can do yourself is make sure that the fan is turning or not.
Jul 07, 2011 | Frigidaire Heating & Cooling
Thermostat replacement 2002 rendezvous
Thermostat Removal & Installation 3.4L & 3.5L Engine To Remove:
  1. Drain the coolant below the level of the thermostat.
  2. Remove the air cleaner and duct assembly.
  3. Remove the exhaust crossover pipe.
  4. Disconnect the radiator hose from the thermostat housing. gm_mv_ven_tstat.gif
  5. Remove the mounting bolts and remove the thermostat housing.
  6. Remove the housing gasket.
  7. Remove the thermostat.
  8. Clean the mating surfaces.
To Install:
  1. Install the thermostat on the engine. NOTE: Apply RTV sealer to the thermostat housing bolt threads.
  2. Install the thermostat housing and gasket with the mounting bolts. Tighten 18 ft-lb (25 Nm).
  3. Connect the radiator hose to the thermostat housing.
  4. Install the exhaust crossover pipe.
  5. Install the air cleaner and duct assembly.
  6. Fill the cooling system.
  7. Check the cooling system for leaks.
3.6L Engine To Remove:
  1. Remove the air cleaner.
  2. Remove the throttle body.
  3. Remove the heater pipes.
  5. Remove the thermostat mounting bolts and remove the thermostat.
  6. Clean the thermostat and heater pipe mating surfaces.
To Install:
  1. Place the thermostat in the housing with a new gasket.
  2. Install the thermostat and gasket on the engine with the mounting bolts. Tighten 89 in-lb (10 Nm).
  3. Install the coolant inlet pipe.
  4. Install the heater pipes.
  5. Install the throttle body.
  6. Install the air cleaner.
  7. Fill the cooling system and perform a leak test.
Dec 19, 2010 | 2002 Buick Rendezvous
Location of thermostat on 2002 olds alero 2.2
Thermostat Removal & Installation 2.2L Engine To Remove:
  1. Remove the exhaust manifold. If equipped with an automatic transmission.
  2. Drain the cooling system.
  3. Remove or disconnect the following: chevy_cav_02-04_tstat.gif
    • Thermostat housing to water pump feed pipe bolts. chevy_cav_02-04_feedpipe.gif
    • Thermostat housing to water pump feed pipe.
    • Thermostat.
To Install:
  1. Install or connect the following:
    • Thermostat.
    • Thermostat housing to water pump feed pipe bolt.
      1. Tighten bolt to 89 in lbs (10 Nm).
    • Exhaust manifold if equipped with an automatic transmission.
  2. Fill the cooling system.
2.4L Engine To Remove:
  1. Drain the cooling system.
  2. Remove the exhaust manifold heat shield.
  3. Remove the coolant inlet housing mounting bolts through the exhaust manifold.
  4. Raise and safely support the vehicle.
  5. Remove the coolant inlet housing stud from the oil pan.
  6. Remove wheel and tire assembly.
  7. Remove the engine splash shield.
  8. Remove the mounting bolts from the transaxle-to-engine block support. Remove the support.
  9. Remove the coolant housing pipe.
  10. Remove the thermostat.
  11. Clean the mating surfaces.
To Install:
  1. Install the thermostat.
  2. Install the coolant housing pipe.
  3. Install and secure the transaxle support-to-engine block mounting bolts.
  4. Install the engine splash shield.
  5. Install the wheel and tire assembly.
  6. Install the coolant inlet housing stud to the oil pan.
    • Tighten to 19 ft lb (26 Nm).
  7. Lower the vehicle.
  8. Install the coolant inlet housing bolts through the exhaust manifold.
    • Tighten the coolant inlet housing bolts to 10 ft lb (14 Nm).
  9. Install the exhaust manifold heat shield.
  10. Fill the cooling system.
  11. Inspect the system for leaks.
3.4L Engine To Remove:
  2. Remove the air cleaner.
  3. Remove exhaust crossover pipe.
  4. Disconnect the surge tank line fitting from the coolant outlet.
  5. Remove the thermostat housing to intake manifold bolts.
  6. Remove the thermostat housing outlet and thermostat.
To Install:
  1. Install the thermostat and housing outlet.
  2. Install the thermostat housing bolts.
    • Tighten the thermostat housing bolts to 18 ft lb (25 Nm).
  3. Install exhaust crossover pipe.
  4. Connect the surge tank line fitting to the coolant outlet.
    • Tighten the fittings to 15 ft lb (21 Nm).
  5. Install the air cleaner.
  7. Inspect the system for leaks
Oct 14, 2010 | Oldsmobile Alero Cars & Trucks
Where is the thermostat on a 2.2l ohc engine?
Removal & Installation 2.2L VIN 4 To Remove:
  2. Remove the lower radiator hose from thermostat housing.
  3. Remove the thermostat housing bolts and outlet.
  4. Remove the thermostat.
  5. Clean the mating surfaces.
To Install:
  2. Install the thermostat housing and bolts.
  3. Install the coolant housing bolts. Tighten bolts to 14 Nm (10 ft. lbs.).
  4. Install the lower radiator hose to thermostat housing.
  5. Fill the cooling system.
  6. Inspect for leaks.
2.2L VIN F To Remove:
    • Thermostat.
To Install:
    • Thermostat.
    • Thermostat housing to water pump feed pipe bolt. Tighten bolt to 10 Nm (18 in. lbs.).
    • Exhaust manifold. If equipped with an automatic transmission.
2.4L VIN T To Remove:
  3. Remove the coolant inlet housing bolts.
  4. Lift vehicle.
  6. Remove the wheel.
  7. Remove the right engine splash shield.
  8. Remove the transaxle-to-engine block brace bolts and brace.
  9. Remove the radiator outlet pipe.
To Install:
  2. Install the thermostat.
  3. Install the radiator outlet pipe.
  4. Install the transaxle-to-engine block brace and install bolts.
  5. Install the right engine splash shield.
  6. Install the wheel.
  8. Install the exhaust manifold heat shield and bolt.
  9. Tighten the exhaust manifold heat shield bolts to 14 Nm (10 ft. lbs.).
Sep 09, 2010 | 2003 Pontiac Sunfire
How to change the thermostat
Alero, Grand Am 1999-2005 Thermostat - Removal & Installation 2.2L Engine
  1. If equipped with an automatic transaxle, remove the exhaust manifold, as outlined in this section.
  3. Remove the thermostat housing to water pump feed pipe bolts.
  4. Remove the thermostat housing to water pump feed pipe.
    Fig. Thermostat mounting-2.2L engine
  5. Remove the thermostat.
To install:
  2. Install the thermostat housing to water pump feed pipe.
  3. Install the thermostat housing to water pump feed pipe bolt. Tighten the thermostat housing to water pump feed pipe bolt to 89 inch lbs. (10 Nm).
  4. If equipped with an automatic transaxle, install the exhaust manifold, as outlined in this section.
3.1L Engines
  1. Disconnect the negative battery cable.
  2. Drain the cooling system to a level below the thermostat housing.
  3. Remove the air cleaner assembly.
  4. Disconnect the surge tank line from the thermostat housing.
  5. Remove thermostat housing-to-intake manifold attaching bolt and nut, then remove the housing.
  6. Remove the thermostat.
To install:
  1. Clean all gasket surfaces completely.
  2. Insert the thermostat in the intake manifold.
  3. Attach the thermostat housing to the intake manifold.
  4. Install the mounting bolt and nut. Tighten to 18 ft. lbs. (25 Nm).
  5. Install the air cleaner assembly.
  6. Connect the surge tank line to thermostat housing.
  7. Refill the cooling system.
  8. Connect the negative battery cable, remove the radiator cap, then start the engine. Allow the engine to run with radiator cap removed, until the upper radiator hose becomes hot (thermostat open). With the engine idling, add coolant to the radiator until the level is up to the bottom of the filler neck.
  9. Install the radiator cap, making sure the arrows line up with the overflow tube.
3.4L Engine
  7. Clean the mating surfaces.
To install:
  2. Install the thermostat housing bolts. Tighten the thermostat housing bolts to 18 ft. lbs. (25 Nm).
  4. Connect the surge tank line fitting to the coolant outlet. Tighten the fittings to 15 ft. lbs. (21 Nm).
  7. Inspect the system for leaks.
Hope this help (remember comment and rated this).
Apr 04, 2010 | 1999 Oldsmobile Alero
Seems to be working but not cooling the house very fast. There is a build up of ice on the unit's copper pipes from the unit to the house...is that usual and how can I get it to function properly?
shut down the cooling. the system should not ice up. The system needs either ref : low charge or a clean filter lack of air flow. The unit must be defrosted prior to any attempt to charge or clean the system. You can just run the blower in the fan on position to defrost the unit.
Aug 13, 2009 | Heating & Cooling
AIR IS NOT WORKING. hAVE SYSTEM SET AT 72 AND STILL SHOWS 85 DEGRESS IN HOUSE. PIPES AT THE TOP OF UNIT SEEMED TO BE FROZE
There are two things that make a central air conditioner freeze up, they are poor air flow, that means check your air filter, and your system is low on refrigerant, and that will take a serviceman to fill on refrigerant. For the time being set your thermostat cool/heat switch to off, and turn your fan switch to on. This will thaw out your cooling unit, and when the ice is gone you can switch the heat/cool switch to cool to resume cooling until you have figured out which problem you have.
Jun 24, 2009 | Heating & Cooling
Re: Kenmore Top Freezer formed ice, main refrigerator area is not cooling Kenmore Top Freezer (Main refrigerator area) is not cooling; This trouble shooting has happened for the past year. Main...
not easy to diagnose. the basic fault is that the defrost system has packed up.
check that there is continuity thro the defrost heater. there may also be a thermal fuse in series with the heater so check that also.
if those ok, then points to a fault in the main module
Jun 22, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Heating & Cooling Logo
14 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
