Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Whirlpool Gold icemaker not working Model GD5SHAXLB02
Ice maker stopped working.. I noticed that ice was fully formed and appeared to be ready to drop but never did. I haven't heard water filling up either. I read other posts about the "arm" but our model doesn't have the "arm".
  • 3 more comments
  • tlander5 May 13, 2008
    I took out the ice maker and found that the little white dial had a piece broken off of it. I'm wondering what that little dial is called and if you think that it would fix the problem if replaced. I also noticed that the coating on the ice tray (where the water freezes) is coming off. I'm thinking maybe I need to replace the entire unit. What do you think?
  • egm1211 Mar 01, 2009
    Our icemaker is freezing the ice but not dropping it and the coating of the ice tray (where the ice freezes) is also coming off. We will take it out and get the ice out and it will work maybe once or twice and then stop again.
  • mrjmcc247 Apr 13, 2009
    My Whirlpool Black-side-by-side icemaker STOP working Mar-13-09=Mo:GD5SHAXLB02. Same problem(s) :
    Water will not go to the icemaker--
    But, I get water to the water dispenser?!?
    What is the problem(s)??? Help!!
    email me back:, jay
    mrjmcc247@yahoo,com
    Thanks,
  • donnascouten Apr 15, 2009
    I get water to the water dispenser but not to the icemaker?????? Please email me back.
    donnascouten@yahoo.com
  • canddiWOW Apr 24, 2009
    I have 2 door Whirlpool Gold 25.6 cu. ft. Model GS6NBEXRL00 Stainless Steel fridge, the ice maker creates ice, however when we press crushed or cubed on door, it will not dispense any ice. I can hear a very light noise as it's responding but will not dispense the ice? Any suggestions on what is wrong or what I can do myself to avoid paying Sears the ludicrous fixture charges? Water dispenser works fine. Any help will be appreciated
    Genius:
  • 1,073 Answers
Problem with the heater or the thermastat of the ice maker
Posted on May 11, 2008
Whirlpool Gold icemaker won't make ice
Try this and add tap water to the empty ice maker. Turn it on if off and if after the water freezes the ice maker cycles dumping the ice into ice bucket and if the ice maker does not refill with water on its own you will need to replace the=> 2188746 Water Inlet Valve
If the ice maker does nothing then replace the=>
2198597 Ice Maker Assembly
Thanks John Tripp Appliance 911
Feb 16, 2014 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
I have a Whirlpool gold french door model # GI5FSAXBY02. The icemaker stopped making ice -please advise. Thanks. Charles Mara chrlsmara@yahoo.com or cjmara@cox.net
Could you double check your model number. I am unableto pull that model number up. You mentioned that your ice makehas stoppedworking. This could be several things, like water control valve,defective ice maker, defective ice maker thermostat and more. Let me know,Thanks, SeaBreeze b8e6bdd.jpgWHIRLPOOL PRODUCT MANUALS
Sep 26, 2010 | Whirlpool Refrigerators
Icemaker on side by side not working
Change out your ice maker. If your icemaker has worked for 6 years, you got lucky! They normally have to be changed out every couple of years. We have an unlimited inventory of appliance parts for Whirlpool, so please call us to send your parts out and we'll get them out right away!
Sep 17, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Whirlpool Gold Refrigerator (GS5SHAXNLOO) Ice maker not running, some ice in maker melted together
I have the same model. This has happened to me several times (usually when the door was kept ajar without notice).
Simply open the door, take a common hairdryer and blow at high speed (hottest also) all around the area of where you can feel the ice in the tray, but hasn't dumped yet. It will usually take about 5-8 minutes of consistently moving back and forth around that area. What has happened is the lines bringing water to the trays have frozen over. When you "thaw" them out, the ice made will dump in about 45 minutes. When you hear the ice fall, you will know it's in working order again. I have NOT heard this is a "flawed" icemaker, only that it is hypersensitive to freezing lines when a door is left ajar. In your case, to prevent this from happening again. If you shut the icemaker off again, make SURE you turn off the source of the water feed BEFORE you turn off the ice maker. By doing this, the lines will empty as it makes it's last tray of water. Try that - very confident it will fix your problem!
May 29, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold Ice Maker not filling
If your water valve is good and your filter is not in need of replacing then you probable need a new icemaker, yes.
May 12, 2009 | Whirlpool ED2FHEXN Side by Side...
ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
Mar 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice Maker not working
Start by cleaning the condenser with a brush and a shop vac. Then get some nickleguard ice machine cleaner and wash the units plate's down going by package directions, then retry before calling a tech. It may start working but if it does not then it may save you some money by having the unit clean before the tech gets there. Ice machines are not a DIY repair. Sowwy
Mar 01, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold Conquest IceMaker
HAVE YOU CHECKED YOUR WATER VALVE LOCATED AT THE BACK BOTTOM RIGHT OF THE APPLIANCE THAT MIGHT BE THE CAUSE OF THE ICE MAKER NOT WORKING.LET ME KNOW IF YOU REQUIR FURTHER ASSISTANCE.GOODLUCK.MOHAMED
Sep 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Icemaker not making ice
The same thing happened to my Whirlpool gold. Defrost it for 24 hours and the ice maker now works.
Apr 12, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
949 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
