Question about Sony Playstation 3 (PS3) Console
No sound thru tv using hdmi cabl - Sony Playstation 3 (PS3) Console
  • 158 Answers
My ps3 has no audio thru hdmi also, but its because its set thru audio settings to output only from my optical cable check your audio setting
Posted on Sep 03, 2010
I'm trying to connect a Samsung HD LCD tv to a Denon AVR1508 receiver using HDMI cable so that the TV sound comes thru the receiver/speakers. which jack do I use (on both the tv and the receiver,
connect the hdmi to the tv (hdmi input 1) and to the receiver (hdmi output) you must make sure that the receiver input settings are assigned correctly. Then hook up all of your devices to the receiver. remember that the 1508 dosent do hdmi upconversion, so if you have any devices that are NOT hdmi, you need to run rca cables from the output of you receiver to the input of your tv. If you have any digital inputs coming out of your devices, i would recommend using them. your 1508 has two inputs that are assignable.
If all of your devices are hooked up to your receiver, and its hooked up to your tv properly, just turn down the sound on your tv, and turn up the volume on your denon!
Dec 04, 2011 | Denon AVR-1508 Receiver
I can get picture with hdmi connected but no sound. Do i have to connect the optical digital audio cable from PC to TV to get sound? Actually the video and sound go to stereo receiver first, video passes...
If your video card supports audio over hdmi in that case you need to find the s/pdif port on you motherboard and the port on your video card (usually right next to and sli or xfire bridge) then you can send the sound thru the hdmi. if not you will have to connect your optical audio cable or a 3.5mm audio out to rca left and right out to your receiver for audio. what video card and mother board are you using? if you know this i can tell you exactly where the ports are for the spdif cable to video card and mobo.
Mar 15, 2011 | Computers & Internet
I have the phillips system. i didnt get a manual with mine. so im hooking it up with out one. ok i have a cable running off of my hdmi cable and ps3 on hdmi. i took my ps3 off and pluged the blueray up to...
I don't recommend doing things without a manual when one is available...
http://www.p4c.philips.com/files/h/hts5580w_f7/hts5580w_f7_dfu_aen.pdf
Think about where you TV audio originates. Unless you have an antenna on your TV, everything IT hears comes from an external audio device like a cable/sat box which almost certainly has a digital audio output and/or HDMI.
I would recommend you carefully utilize your limited connections this way:
Using Page 10 as a guide.
IF your TV has 2 HDMI's or one HDMI AND one Component input:
Cable box (Component Out and Analog Stereo RCA) or HDMI Out to corresponding TV In's if available.
Cable Box coaxial audio to the HTS (3). This way the best broadcast TV multichannel audio goes to the best electronics and speakers.
HTS HDMI Out (9) to TV Component In (if available), otherwise use Component Out (7). I recommend saving the highest quality video delivery path for your native BD because broadcast Hi-Def video is always bandwidth compromised while BD is the best video available today.
Composite Video Out (6) to Composite Video In on TV for HTS management functions.
You still have both Aux In (4) pairs).
Jan 25, 2011 | Philips HTS5580W/F7 Theater System
Xbox 360 working thru HDMI working fine. Now no sound & weird pic
it is prolly an internal problem. have to tried connecting the componet cables?
Mar 03, 2010 | Microsoft Xbox 360 Console
Yamaha Receiver RX-V463
Do not use HDMI thru your receiver. Go directly from the Cable box to the TV. Connect coaxial digital or optical to your receiver. Your receiver uses HDMI version 1.1 or 1.2, which is riddled with issues. If you want to read about them, Google HDMI Problems and you can read for hours. Long of the short of it is; Don't pass HDMI thru your receiver, use the receiver for audio only. Hope this answers the question. Sorry for the bad news! I'm in the industry and have been dealing with these issues for a couple years now.
Dec 16, 2009 | Yamaha RX-V463 Receiver
Flat screen to dvd connection help!
It depends on the TV.
On my Phillips TV this is switchable via the TV setup menu, and you get no sound with HDMI unless you change that setting.
The reason it's switchable is that the HDMI input is usually common with one of the component-video inputs (AV3 on mine). (cost saving move)
Thus if the menu is set to hdmi, then the audio goes thru hdmi. If it's set to 'component' then it goes thru the RCA patch cable.
Oct 07, 2009 | Televison & Video
Dish network VIP722 DVR - cant get sound to pass thru TV
HDMI is digital sound. I don't know why it's not passing through. You could run a set of audio cables to the surround sound. The not a noticable difference in my opinion.
Mar 15, 2009 | Televison & Video
No sound
I had the same problem on 3/21/09...I found it was the PS3 settings. I had to go into the visual settings (not sound) and change the linear sound to optic digital...but I also had to purchase a digital optical cable...plug everything into your tv instead of the receiver and then hook up the digital optical cable from your tv to the receiver. A it will work and b it is a better sound quality than that of the HDMI cable.
Mar 14, 2009 | Yamaha HTR-6130 Receiver
AUDIO
This TV ONLY transfer audio OUT to a ANALOG SYSTEM THRU AND ANALOG SIGNAL. That is, TV will play sound fine in your surround system but any digital (HDMI) wont sound.
Mar 11, 2008 | JVC HD-56FN97 56" Television
Sony Playstation 3 (PS3) Console Logo
55 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
