Question about Kenmore Refrigerators
I have an kenmore cest freezer model 253.16082102 where can i get a temp controle panel .It is a panel on the door that has a quickfreeze ,up arrow down arrow,alarm reset button,and freezer temp display
SOURCE: Samsung RS2533SW freezer not cooling problem
mine did the same thing. It was the mother board.
and guess what? they don't sell that motherboard anymore.
I will never buy Samsung again!
Posted on Dec 15, 2007
tborn6
  • 700 Answers
SOURCE: SENSOR PROBLEM ON SAMASUNG SRS580DW (side by side fridge)
go ahead and take and hold in the top two button until the unit blinks and resets the controller. Please don't rate this unitl the problem is solved because i can't come back and answer any more questions then. Also if this fix's please rate this solution please. Thanks for usin FixYa
Posted on Jan 01, 2009
I was having the same problem but with the refrigerator side. I know your problem was with the freezer side but I hope this works in your situation too. I was also told to unplug the fridge for 20 minutes and that did not do a thing to reset the circuit board in my situation. Unplug the refrigerator first. In the back of the refrigerator at the bottom is a metal panel. Remove that panel and off to the right side of it should be a white looking plastic box. Unscrew that box from the fridge and open it up to get to the circuit board. Remove ALL harnesses from the circuit board and capacitor. After doing so plug them all back in and reassemble everything back together and plug in the fridge. This should reset the board and allow it to function correctly. This is advice I got from someone else and everything as of today is cooling down like it should. I hope this helps everyone else out. Best of luck.
Also since the evaporator was frozen solid at the bottom on the refrigerator side I had to leave the power off until it thawed and then had to soak up all the water that collected at the bottom of it.
Posted on Apr 20, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Kenmore model 253 71132105 freezer works fine but
MGPRICE Just have the answer right in front of you and nobody gives you a thumbs up! I did. This person was even smart enough to include their model number! thumbs up to them I just am curious why they never responded. Sea Breeze
Posted on Aug 09, 2009
woodchuck789
  • 4066 Answers
SOURCE: 253 55682402 Kenmore Side by Side Refrigerator Not
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Posted on Aug 21, 2009
Testimonial: "Thank you"
Hi, I have a kenmore elite deep chest freezer. Model 253.16582105. can't stop the beeping, even after replacing the 9 volt battery.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Mar 26, 2016 | Kenmore Refrigerators
Panel beeping and nonresponsive
Jan 30, 2016 | GE Profile Stainless Bottom-Freezer...
I have a frigidaire side by side model GLHS37EHSB7 refrigerator makes a continuing beeping sound what could be wrong?
Fridge keeps beeping: The following is for Frigidaire models but others can be addressed similarly.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
May 11, 2015 | Frigidaire Refrigerators
Refridgerator beeps
Apr 19, 2015 | Refrigerators
Got fridge freezer but no instructions. Alarm keeps going off. Front panel contriols
Apr 10, 2015 | Refrigerators
How do you get the model 370lb to stopping beeping
Mar 30, 2015 | Refrigerators
Open door 18 beeps lights flash red green fridge not cooling
Mar 14, 2015 | Refrigerators
Keeps beeping without stopping
Mar 09, 2015 | Smeg Refrigerators
What causes my Kenmore to buzz when dispenser door is closed?
Sep 14, 2014 | Kenmore Refrigerators
Flashing power light on Kenmore upright freezer
If the yellow light is flashing it may mean that the 9 volt battery is dead.
On my Kenmore there's a small battery compartment on the bottom right of the unit - under the door.
Aug 10, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Refrigerators Logo
42 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
