Question about Jenn-Air WW30430P Stainless Steel Electric Double Oven
Wall ovens Our WW30403B was working inthe convection mode for 11/2 hours and the the beeping started and the F7 error came up . I pressed cancel and it did not go off, so I turned off the power as the care manual stated. What is my problem, and how do I fix it.
  • 2 more comments
  • mollerroller May 11, 2008
    I assume the membrane strip is the 11/2 semi transparent strip. I unpluged the strip, turned on the power and now the clock is blinking and cannot reset it but no error code is showing.
    No error is present
    Is there another name for the touch pad? The parts listing does not recognise that description of a part.
  • mollerroller May 12, 2008
    The clock just kept blinking a time and would not work by pressing "clock" to change it.
  • 3,037 Answers
This Usually indicates a shorted keypad. Turn off at the breaker. Unplug membrane strip connected to the clock from the clock, turn breaker on. If code comes back replace the clock, if no code you need the touchpad replaced
Let me know how this goes, thanks
Posted on May 11, 2008
  • 1 more comment
  • Benjamin Patri
    Benjamin Patri May 11, 2008
    yes, that was the membrane
    Were you able to get the clock working.
    instead of touchpad it may be control panel or something similiar or knob something etc.
  • Benjamin Patri
    Benjamin Patri May 12, 2008
    here is a list of parts for your control panel
    http://www.partadvantage.com/store/partl...
    call 1-866-678-3718 which is the website's number and they would be happy to help you get a replacement
  • Shawn Dady Jul 31, 2013
    This was extremely helpful to me. Mine was beeping F7 and I did as this said, unplugged the membrane strip connected to the clock from the membrane (I think that's what it was supposed to say), and the error did not happen again. So my control panel clock is fine, it's the keypad membrane that needs replacing for me. Thanks so much for this helpful information. Saved me a lot of money and hassle!
    Brigadier General:
  • 3,614 Answers
Is the error still there, when you cut off the power on the unit..?
  • micromaster
    micromaster May 11, 2008
    this error is something to do on the contro pad, it sometimes or usually shorted or malfunction on that area. look for some stuck keys or bad contact point into it..
    thank you
How to address F14 code? Convection oven does not start.
Hey friend, thanks for your post!
I see that your Electrolux wall oven is displaying an "F14" error code. "F14" stands for display tail missing, which means you could have an issue within your main control board or keypad. I would perform a reset on your appliance which can be done by flipping your household circuit breaker off for roughly ten minutes. If that does not correct the issue I would suggest seeking a professional to come out properly diagnose and repair your appliance. I hope this is helpful. -Matt
Aug 31, 2014 | Electrolux ICON Designer E30EW75GSS 30"...
Maytag MEW6527B Oven.Push panel buttons,no beeps or codes. Convect roast starts at temp 888 then adjusts to 550, for 11:11 time, only #'s that work. Checked Sab mode, door lock, panel lock. Circuit...
I had almost the same problem I to have a Maytag.I was not getting any readings from my panel and the oven would not work.I called up Maytag and they told me to move the oven away from the wall.Whats happens the computer board heats ( Display ) up causeing this problem.I moved the oven a little bit away from the wall and now it works great.I hope this helps you.
Apr 23, 2011 | Maytag MEW6527B Electric Single Oven
My oven beeps and show error code F7 on the panel. Help!!!
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Dec 02, 2010 | GE 27" Built-In Double Electric Convection...
I was cleaning my GE profile convection oven and after the 3 hour cycle, an error message F 1 started flashing, and the oven started beeping.
We frequently see this symptom due to a failure in the electronic range control (ERC). We repair a lot of these.
- www.fixyourboard.com
Jul 24, 2009 | GE 30" Built-In Single Electric Convection...
Amana EvenAir Convection Plus Self Cleaning Oven will not unlock.
My oven was locked and would not open. No lock light was on but the oven was clearly locked. F9 error when I hit certain buttons.
Try this. I unplugged the oven for about 5 minutes. Plugged back in. A LOCK light came on. Held down "Oven Cancel" for a few seconds. Door opened and lock light went off. No more F9 error when I hit those buttons.
Dec 03, 2008 | Amana AEW3530DD Electric Single Oven
F7 error steady beeping
short inthe key pad, thinks a button is being preesed for an extended period of time youll need to replace the keypad/ electronic control
Nov 17, 2008 | GE JKP45 Electric Double Oven
Random beeps, oven almost starts itself
The touch pad may be defective. There is a membrane behind the buttons that will cause problems like that. The only cure is to replace the touch assy.
Sep 11, 2007 | GE Profile JKP18 Electric Single Oven
Jenn-Air WW30430P Stainless Steel Electric Double Oven Logo
206 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
