Question about Dryers
HOW CAN I EXTEND THE DRYING TIME? MAXIMUM DRYING TIME I HAVE MANAGED TO GET IS AN HOUR AND A HALF AND IT IS NOT ENOUGH TIME TO DRY MY TOWELS. ALSO HOW DO I CHECK AIRWAYS? THE RED INDICATOR LIGHT HAS COME ON.
    Problem Solver:
  • 12 Answers
On your heat setting you should see less dry, normal dry and more dry. put the setting on more dry and that should take care of the problem. and for the airways. first check your lent trap and if that doesn't do it, check your exhaust hose from dryer to the outside and if that is clear you may have to remove rear cover and clean out. i hope this help.
rwpfn@aol.com
Posted on Sep 03, 2010
Gas Dryer does not dry clothes. The dryer on highest setting will dry for over an hour and items such as towels,jeans nad the like are not dry
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Jun 28, 2011 | Whirlpool Dryers
I've recently purchased a FirgidAir laundry dryer (Model FCED3000ES ELE). The company installed drying time is 45 min that doesn't dry load well. I want to extend drying time to 1hr. Could you...
If you are looking to increase the time, the dryer comes with additional wheels for the timer. The one with the least number of posts is the longest time. I forget if it has two or three posts. You just remove the timer from inside the coin box and slip off the 45 minute wheel, and slide on the 1 hour wheel, and then put the timer back. Very simplet.
Jun 14, 2011 | Frigidaire FCED3000ES Dryer
I have jst purchased this washer today, however the dryer takes ages,,,,,,their seems to be water going in when its drying, clothes come out hot, but still as damp as when i put them into dry.
Hi, this is normal for a washer dryer, water isn't actually going in, it is condensating and then being pumped away.
when you use the dryer program your are only meant to put half the washing load or less in at a time if there is too much wet washing in the machine it will take forever to dry as it cant get rid of the amount of condensation quick enough so some of it is reabsorbed into the clothes and so it goes on.
so the trick is only to put in a maximum of half the full washing load.
Hope this helps.
Feb 11, 2011 | Hotpoint Ariston WD440G Front Load...
Do the Fisher Paykel Dryers DGGX1 take twice the drying time of a normal (Kenmore) dryer to dry cloths? I put in a load of towels and after an hour and a half they still weren't dry. My other dryer would...
make sure there is no lint build up inside the round housing where your lint trap goes. the holes in the housing sometimes plug up and you can't see it. one screw at the bottom and rotae slightly to remove. also make sure vent is clear
Jun 26, 2010 | Fisher and Paykel DGGX1 Electric Dryer
Takes 4 hours to dry a load of towels. plenty of heat - just not drying
How damp are the towels? More moisture= more time to dry
Is the dryer full to the top with towels? There needs to be enough space to allow for air flow in and out.
Also check exhaust vent to make sure it is not blocked.
Oct 09, 2009 | Whirlpool GEW9250 Electric Dryer
Blinking AD
AD is auto dry you may need to clean the sensor or you may have a fauilty one ...Auto Dry Loads dried using the Towels, Heavy Duty, Normal, Perm Press, and Delicates cycles will dry automatically at the selected temperature to the desired dryness level. The dryer uses sensing bars to sense the moisture level of the load as it tumbles through heated air. Auto Dry cycles save time and energy and protect fabrics. The estimated drying time will be displayed for about 5 minutes, then the outside of the display will light up in a circular track to indicate the drying time is automatically being determined by the sensors. When the load has reached the selected dryness level, it will continue to tumble, unheated, during a Cool Down period. This helps reduce wrinkling and makes items easier to handle during unloading. The estimated Cool Down time will be displayed. Drying time varies depending on size and dampness of load and fabric type. If the load is too small or almost dry, the sensing bars may not detect enough moisture to continue the cycle and the cycle may end after a few minutes. Select a Timed Dry setting to dry such loads. Room temperature and humidity, type of installation and electrical voltage or gas pressure can also affect drying time. For cycle selection turn the knob on the front of the dryer control panel. The light will illuminate next to the cycle selected. The following is a brief description for what cycles should be chosen for certain items and materials to be dried.
Sep 18, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Hello: I have a Maytag, do not know model # as I inherited the 5 year old model when I purchased a condo and it is now 7 years old. The front of it states Maytag - Dependable Use, Heavy Dtuty - Large...
I ALWAYS START WITH VENTING WHEN CALLED WITH LONG DRYING TIMES BUT I HAVE SEEN WHERE ONLY HALF OF THE HEATING ELEMENT IS WORKING, WHICH IS PRETTY RARE. A NORMAL LOAD WOULD BE WHATEVER THE WASHER HAD IN IT WHICH WOULD BE LOOSLY FILLED TO THE TOP ROW OF HOLES IN THE WASHER TUB. THE ONLY OTHER QUESTION I WOULD ASK IS IF THE WASHER SEEMS TO BE SPINNING OUT PROPERLY AND IF THE CLOTHES ARE GOING INTO THE DRYER TOO WET.
Jan 10, 2009 | Maytag LSE7806A Top Load Stacked...
LGE59777S Not drying
There is a little sensor that tells the dryer when to heat and when not to heat. that sensor is bad. If you take the back of the dryer off you will see it. It is about the size of a half dollar and has 2 wires that plug into it. While you have it apart make sure that the dryer vent on the back of the dryer is not plugged with lint. Major cause for fires in dryers.
Jan 04, 2009 | LG DLE5977 Electric Dryer
Dryer either doesn't dry or burns my clothes
ck air flow out vent at back try drying load with vent hose disconnected ..if drys ok ck vent from inside to outside for restrictions
Dec 21, 2008 | Dryers
Bad smell
washers and dryers dont make smells themselves its a problem with something u might be putting in it. if u tend to add alot more detergent then usual to your towels then they never completely rinse the water out and will have a mildew smell
Feb 18, 2007 | Whirlpool GEW9250P Electric Dryer
Dryers Logo
71 people viewed this question
Top Dryers Experts
