Question about GE Nautilus 24" Built-in Dishwasher
G.E. Nautilus dishwasher Model #GSD3135FOOWW. Very LOUD hum when in use. Fixable or is it a replacement?
SOURCE: GE Nautilus Built-In Dishwasher
This would be the motor that spins the dish washing unit in the bottom. The noise you hear might mean that the motor will need to be replaced.
Posted on Oct 04, 2008
mreid542
  • 166 Answers
SOURCE: GE Nautilus Dishwasher
if the dishwasher has not been used for a few weeks, the water in the sump that goes into the pump will evaporate causing the pump to freeze up. usually you can turn the fins inside the motor to free it up. make sure the dishwasher is not on when you do this.
Posted on Nov 20, 2008
SOURCE: Loud Humming noise every time we run the dishwasher
Hi, I had this exact same problem. In my situation it turned out to be the pump that pumps out all of the used water. It was rubbing up against the floor so that every time it turned on it made a loud vibrating sound. I just reached under the washer and put a piece of rubber between it and the floor and it solved the problem.
good luck!
I saw this post because I am considering buying the same model you have. Other than the noise problem you have, what do you think of it?
Posted on Apr 06, 2009
  • 246 Answers
SOURCE: need new dishwasher replacement door panel in
you should also look at www.applianceart.com. They have a ton of replacement panel options for the front of the dishwasher to change the appearance. Black white, stainless, but also picutres, designs, and lots of options.
Posted on Feb 04, 2010
pappapumpdaf
  • 635 Answers
SOURCE: my dishwasher is making a very loud rumbling noise
That usually comes from the main wash head being reinstalled without the white washer which provides a smooth surface for it to glide on, or it has cracked and fallen off, OR it's mounter to the head and has simply eroded.
Posted on Mar 11, 2010
My dishwasher is making a very loud rumbling noise at certain times during the wash cycle. it's a ge nautilus
Mar 11, 2010 | GE Nautilus 24" Built-in Dishwasher
good luck!
Mar 29, 2009 | Jenn-Air Dishwashers
Sep 17, 2008 | GE Nautilus 24" Built-in Dishwasher
Motor
The only reasons to replace a pump motor are very loud motor or leaking water from the seal of the pump / motor assembly. The motor comes as the pump / motor assembly, and is not real cheap and not particularly easy to replace, so you may want to consider cost of replacing the entire unit. Appliance repair locations can order for you, or you can order directly from GE over the phone. (GE answer center 800-626-2000) Make sure you have complete model number, located on the sticker on the left side of the tub just inside the door.
Sep 01, 2008 | GE Nautilus 24" Built-in Dishwasher
Nautilius not running
drain motor doesn't work, yo cn hear a little noise but maybe to hot, th motor doesn't turn.
Jun 29, 2008 | GE Nautilus 24" Built-in Dishwasher
GE NAUTILUS DISHWASHER
The pump motor may be stuck. If this is the case, as it often is with a GE dishwasher, you can break it loose (e.g. spin the impeller until it doesn't spring back any more). If it's not stuck, it may have something inside of the pump motor and it may need to be replaced.
Mar 25, 2008 | GE Nautilus 24" Built-in Dishwasher
Dec 05, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Nautilus bathroom fan blades don't turn
The motor is sized up. call someone to replace it and they should know how to remove the cover.
Nov 01, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
GE Nautilus ...
Does water drains out properly ?
May 02, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
GE Nautilus 24" Built-in Dishwasher Logo
60 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
