Question about Sony Cyber-Shot DSC-P100 Digital Camera
Lense Will Not Retract
When I turn off the power the lense will not retract. When I turn it on again, the message on the LCD screen says to "Turn the Power off and on again" which I have tried. It keeps trying to close, but appears to be stuck.
  • Shorcos May 11, 2008
    I had already accepted the first solution (bumping the camera lightly against the palm of my hand) which was also your first suggestion. I guess since I had already accepted the first solution, I was not given an opportunity to rate the second solution. If there is a way to rate it, let me know.
    Genius:
  • 3,422 Answers
try this out it worked for most of them who had a similar problem like urs:
Gently tap it twice at the end of the camera to ur plam and it will work again.
just tap it very lightly against the bottom of the camera holding it upright
Goodluck,
Please don't forget to rate the solution
Posted on May 11, 2008
  • 3,037 Answers
There is most likely a small object such as a piece of sand stuck in the lens area or a gear is broken.
Two things to try.
1. Gently bump the camera on the side to dislodge the piece of material.
2. Open it up and find the area and see what is causing the problem.
usually option 1 works but option 2 or taking it to a repair shop for them to do it is the only other option. The pieces are very small and hard to deal with for an unexperienced person.
Please let me know if you have any questions on anything I have said or if you need further help, thank you and good luck
  • Benjamin Patri
    Benjamin Patri May 11, 2008
    hi, was there any problem with my solution since you did not rate it?
    Please let me know, I enjoy all feedback that I get.
  • Benjamin Patri
    well, the only way to rate it is to unrate the first one I believe, and since you didn't rate mine, I get no credit towards the solution even though I posted a solution first. so thank you and have a good night
Lens won't retract
According to Sony, storing the camera lens-down in a warm area for an extended period (a week) can help re-lubricate the retractor drive in cases like this.
This camera seems to have a predisposition to lens retraction problems. Try some gentle nudging, Even a small piece of debris can jam the mechanism, so it might just need a little push or pull.
Apr 16, 2008 | Sony Cyber-Shot DSC-W5 Digital Camera
S630 won't turn on
Openings the lense is the last thing you want to try. If you dropped your camera, you may have to. If you did not drop your camera, some dirt somhow got on the sides of the lense and they prevent your lense from closing or opening 100%
Try this first
turn it on and the same time pull the lense out. Your lense may not be open all the way out. OR
Clean the side (outside) of the lense. While turning your camera OFF, push on the lense in NOT too hard. Try that a few times, If the lense retracted 100% or near 100%, just push the lense in a little harder untill it is 100% retrected. Turn it on, It may work now.
Good luck!!!!!!!!!!
Good Luck!!!!!!!
Jun 11, 2009 | Samsung S630 Digital Camera
DSC_W110 model problem
You definitely have some dirt on the outside of your lense. You need to keep it clean by holding cloth on the outside of the lense. Turn the camera off. If the lense does not retract fully, while turning it off, press on the lense (up and down motion with the lense motion) very softly for a few times. The lense should retract 100% inn. If not %100 retreacted, but almost 100% retracted push the lense a little harder in until it retracts all the way in exactly the normal position. That should take care of your problem. Good luck
Jun 09, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Sony cyber shot dsc-n2
There could be two things causing this problem.
1- some dirt somehow got on the outside of side of the lense. So the lense could not fully retract or open out. As a result you can take any picture. If the lense comes out even a little bit, try to pull it out NOT too hard a few times. If it does not retract, turn the camera off and push the lense in (up and down) NOT too hard foe a few times. If the camera opened up 100% or retracted 100%, your camera should be back to normal.
2- If you dropped the camera, some mechanical part of the lense is broken or dislocated or the cable may have come loose. In this case you need to take out the lense from the camera and inpect it for broken pieces or loose cable. clean the outside of the lense and push the lense in and out a few times. Put the lense back on and your camera would be back to normal.
Good luck!!!!!!
May 14, 2009 | Sony Cyber-shot DSC-N2 Digital Camera
In camera or video mode it says turn the power off and on again
The problem is
1- some dirt somehow got on the outside of the lense. After it was retracted fully in, it prevents the camera from opening again. When you turn it on, if it opens a little bit, try to pull it out NOT too hard and let go a few times. If it opened, clear the outside of the lense. Your camera should be back to normal.
If the lense does not retract, but goes up and down when you turn it on or off, Clean the sides of the lense and while turning the camera off push the lense in NOT too hard for a few times. If it retrected 100% or most of the way inn, push the in a little harder untill it is 100% retracted in. Now your camera should be back to normal. 2- If you droped the camera, you probably damaged or dislocated a mechanical part of the lense. You may have to take out the lense by unscrewing it and inspect it for damaged parts or disconnected cable. Make sure clean the lense and test it by moving it in and out a few times, before puting it back on the camera.
Good luck!!!!!!!
Apr 14, 2009 | Sony Cyber-shot DSC-N2 Digital Camera
Beeps repeatedly, lense won't retract...won't take pictures?
Hi Jeanice21, I just posted the same problem a few minutes ago with my SD400. I followed a few steps of the suggested solutions and here's what worked for me.
1) take apart the front and back by unscrewing the six screws holding the camera together
2) on the left of the flash, there are two little retangular holes with grooved dials in them
3) using a little flat head screwdriver, push up or down to turn the grooves while power up in the movie or capture mode
4) the lens retracted at this point and my camera started working again. Good luck!
Dec 28, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
Sony cyber-shotdsc-w50 lense won,t retract when switching power off. when switching on screen message displays turn power off and on again
you must reset the lens this means taking the camera apart and reseting the lens.call 423-790-1480 and I'll explain whats envolved.
Sep 24, 2008 | Cameras
Dsc w7
While turning in off softely press the lense in and out a couple of times. The lense would retract. If not fully, but most of the way, push the lense a little harder in until completely retract. If you turn it on, I should work fine. The reason the lense does not retract is most likely some dust in there somewhere. If it did not help, you would have to open the lense and clean it and close the lense.
I hope it helps,
Jul 13, 2008 | Sony Cyber-Shot DSC-W7 Digital Camera
Lens stuck
Solution:
The Lense is obviously jammed some how.
Suggestion:
Send the product back to the manufacturer and see if they can repair the product or send you a new one.
Dec 18, 2007 | Sony Cyber-Shot DSC-W1 Digital Camera
Sony Cyber-Shot DSC-P100 Digital Camera Logo
106 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
john cordey
john cordey
Are you a Sony Camera Expert? Answer questions, earn points and help others
