Question about Kohler Cimarron 2-PC Elongated Toilet with EcoSmart Technology, Left-Hand T...
I just bought a new kohler cimmaron biscuit 2 peice tiolet. it is installed correctly. every so often i hear the water running for a few seconds then it shuts off like its losing water and refilling. i do not see a leak anywhere, i put food coloring in the tank and do not see it leaking out. why does it do that and what is the solution to fix it. it keeps my wife up at night. lou @ e-mail: dshurf@comcast.net
    Problem Solver:
  • 8 Answers
Check fill tube from the fill valve to the flush valve, if the end of the hose is close to the watr level it will back syphon.... recommend also putting in better inner components.. fluild master 400 a fill valve and a nice red korky flapper
Posted on Sep 03, 2010
When flushing, only a small amount of water leaves the tank, and the bowl just empties. The chain has a little slack to close, however, it does not hesitate at all. When flushing, the chain lifts the...
Try holding the handle down until the tank empties completely. If the tank leaks into the bowl during or after refill, the flapper is defective and not sealing correctly.
Jun 21, 2017 | Kohler Memoirs toilet tank with Stately...
Have brand new 3489 cimmaron 1 piece toilet. tank empties on flush but no suction empty on bowl. water only eventually leaves bowl
It may be the wax ring expanded and is restricting the flow.
If you did not install the unit FYI ..the wax ring is inserted between the toilet and the waste pipe to prevent leakage. Sometimes it moves out of place when the toilet gets installed and blocks the flow
Feb 23, 2011 | Kohler Home
Hello, I have been replacing the rubbler ball on my class 5 cimmaron yearly becomes too soft and I think is why does not flus properly. I noticed the new flush valve assembly in the new class 6 cimmaron...
I can't answer your question about the part from the #6 fitting the # 5 because I don't remember. I think it will but they were haveing trouble with the older one breaking down due to chlorine and other water treatment chemicals.I Thank you.
Jan 03, 2011 | Kohler Cimarron Comfort Height elongated...
Kohler welworth enlongated 2 piece toilet with class 5 flush. I can hear the water running intermittently - tank does not appear to be leaking into the bowl or otherwise. Otherwise, the toilet appears to...
Place a few drops of food coloring in the tank of the toilet, if it is leaking you will see the color seep into the toilet bowl within a short period of time. If you see the food color in the toilet bowl you will need to replace the flapper.
Oct 28, 2009 | Kohler Home
Toilet fill runs periodically works well but wastes water
Sounds like your flapper is leaking causing the water in the tank to lower until it triggers the fill valve. Replace the flapper (they're cheap and wear out easily).
Jul 03, 2009 | Kohler Toilet - One Piece with Ingenium...
I have a Kohler commode about 1 1/2 yrs old. When filling, it continues to fill with water going to the overflow pipe.
Does it have bll **** on it?That means a long brass rod with a ball on the end.If it does then gap it with both hands and with the hand next to the ball push down a little ways and keep doing this until the water stops running.If you have a fluidmaster brown or black the little wire on the side of you will see a little metal piece squeezed it and down and the should stop.
Mar 14, 2009 | Kohler C3-200 K-4709-96 Biscuit Elongated...
Kohler Cimmaron Toilet Flush
You might want to check the flush cylinder, to see if it has water in it. It has to be water free, that way the air in it, lets it go down easier, during fill up.
Jan 23, 2009 | Kohler Cimarron 2-PC Elongated Toilet with...
Toilet keeps flushing itself, its is a bemis toilet. its been doing it since i put sum of that bloo stuff you get although i took it out straightaway.
Replace the flapper. It seem to have been damaged. It that does not cure the problem by itself you may have to replace the flapper seat also.
Jan 15, 2009 | Home
Kohler Cimarron 2-PC Elongated Toilet with EcoSmart Technology, Left-Hand T... Logo
318 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
