Question about Proform Crosswalk 3.0 XT Treadmill
I bought a used proform 345s crosswalk..it won't start but when i press the reset button it flickers on than goes back off...it doesn't have a manual
3 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: my treadmill is a proform 345s crosswalk. It
You may have a belt and deck problem. Test by the following procedure: without the power on stand on the walking belt, push the belt in the direction it normally turns, if the belt is very difficult to turn (on most treadmill) this means that you have high belt/deck friction. Apply silicone lubricant between belt and deck beginning laterally at the motor shroud to end of the rear roller on each side
The deck should be smooth without any grooves, pits, or exposed wood. The belt should have a consistent ridged feel from one side of the belt to the other (a belt can be worn out without any sensory signs of a problem). If you feel deep grooves in the deck or uneven wear on the underside of the belt, part replacement is necessary. Visually look at the underside of the belt. It should have a consistent look. Black streaks in the belt are a sign of bottom-layer wear through. Very worn belts will feel smooth in the areas you normally walk- you would think smooth is good but not in belts because the smoother the belt, the more contact area. On occasion, you may have already damaged the DC board if you have high belt/deck friction. If the belt walks freely, you have a different problem. 2. If it passes the belt/deck checks, you may have a DC board output problem. If the belt tests ok and you have a speed variation, try this test:
Set the speed to 2.5 MPH. Let the treadmill run without anyone on the belt. Check to see if the speed is constant or if there is a variation.
If there is no variation, step on the belt. If the speed slows down or speeds up, you may have an output problem on the DC board. This is the board that connects directly to the motor.
You may have a short in the motor. If you turn the machine on and have erratic speed, you could have a problem in the DC board or the motor or both. With a simple multi-meter, you can test on the continuity scale to see if you have a closed circuit between either DC motor lead and the common earth ground. You should always have an open circuit.
You may have a speed signal problem. Your controls on the upper panel send a signal to the lower electronics to help them set the appropriate speed. If there is a problem in the signal generator, the communication links, or in the feedback links, you will have erratic speed operation.
Communications test- Look on the board for a flashing signal as you increase speed on the treadmill. Most boards have a signal feedback test light. If a LED flashes, your communication is ok.
Feedback test- If your unit is equipped with an optical feedback (disk inside a sensor) you can swap the feedback unit with the incline (it is the same part on many Icon machines). If it tests ok, you don’t have a problem here. If it is a magnetic feedback unit, you can test continuity with a multi meter or replace with a new part to test. Many times passing a kitchen magnet in front of the signal will make a speed display on the console if the magnetic sensor is good.
Signal Generator- If you have a problem with the signal generator, your speed will be erratic with either a person on the machine or without a person on the machine. You may even get a speed error code from the unit.
Posted on Jun 15, 2010
  • 1156 Answers
SOURCE: Proform 345S Crosswalk owned for
unfortunately, the manual for your Proform 345S Crosswalk unit is not available anywhere online. The manufacturers of this Unit did not make it available. I went further searching and couldn't find any.
I would suggest you contact the manufacturer of your Proform 345S Crosswalk via phone or e-mail and request for the manual from them. They might give it to you or direct you to a dealer where you can get the manual.
This is the best you can do to get the manual you are requesting for.
Below are the list available manuals and models for Proform 345S Crosswalk
http://www.hammerwall.com/Manuals/ProForm/251/
Good luck..
Posted on Jun 17, 2011
Hello i have a proform crosswalk sport treadmill and when i turn the speed on it shows a reading for a couple of seconds, but doesn't come on. The incline works just fine. The motor will turn manu
adjust the REED switch see the diagram attached m clean it+test for open or faulty with DVOM, tight the connector very well,However try to RUN the software calibration and fix it. see the diagram attache too for speed sensor, adjust it and test it , clean it, and tight very well the connector.God bless you3_22_2013_4_18_58_pm.gif3_22_2013_4_19_19_pm.gif3_22_2013_4_19_33_pm.gif
Mar 22, 2013 | ProForm CrossWalk Sport Treadmill
No lights on the top panel of Treadmill Pro-Form 345s
1) replace the old batteries by new ones. clean the contacts batteries very well
2) tight the ribbon cable for keypads and clean it
3) tight the upper connector vs lower connector
4) adjust the REED switch, see the diagram clean it, test for open or faulty and tight the connector.
Jan 22, 2013 | Proform Exercise & Fitness
Proform 345s stripes on the walking belt. Powdery residue on the floor below the belt. Everything functions normally, and the belt is properly aligned.
1) this a normal problem. However you must know that you must LUBE the deck belt every 5hours aprox, in according with the use.
2) You must check the tension in deck belt aprox 3- 4"High aprox from the middle.
God bless you
Nov 14, 2012 | Proform Crosswalk 345s Treadmill Walking...
My proform 345 stops almost every time i get on it. i usually have to let it warm up 10 minutes before it runs ok. whats going on?
1) you must LUBE THIS Happen because the machine has special design for to protect the electronic system. Maybe you have NOW WORN deck belt, time to replace.
2) Lube the rollers bearing too
3) test the bearing for the main motor. and repair
God bless you
Pro-Form Crosswalk 395 - Incline goes up and down with no tread movement. Calibration doesn't work - only on display.
test the main board, with the output voltage from board for input voltage motor. If there are NOT voltage the board is faulty.replace see the block diagram, how the main boad control about 80% of the machine motion.
God bless you
Sep 29, 2012 | Proform Crosswalk 395 Treadmill
Proform crosswalk 515 control board works but belt won't move/
lube the deck belt, you have deck worn, proceed in according with the instruction manual maintenance. 2) check the drive belt and replace it if necessary and tight 3) tes the input voltage motor, if there are the motor need repair or replace 4) test the output voltage from main board, for input voltage for the main motor, if there are NOT, the board is faulty.
Try if you can RUN the software calibration for diagnose and troubleshooting.
sincerely. God bless you.
Apr 28, 2012 | Proform Crosswalk 500 Treadmill
Pro-Form Crosswalk Plus Treadbill back leg extension
iconservice.com has free pdf downloadable manuals for proform.
Nov 12, 2009 | Proform Crosswalk 500 Treadmill
Proform Crosswalk 3.0 XT Treadmill Logo
166 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
