Question about Dell Inspiron 9400 Notebook
When i turn on my laptop, the screen comes on then slowly fades to a black screen. I have it plugged into a monitor and it works fine. Is it possible that all i have to do is replace the screen?
    Problem Solver:
  • 12 Answers
Yes or just have yours fixed.It will probably be cheaper.
Posted on Sep 03, 2010
My balls have dropped of and I have adopted a penguin.
Posted on May 05, 2011
On the computer there should be a monitor button, have you tryed pressing this. Dont remember but maybe you have to hold down the FN key or something.
Posted on Sep 04, 2010
My Hp notebook screen is black,sometimes it fades in and out black to grey then to black.how can i fix it
Connect your laptop to an external monitor and switch to monitor. If the external monitor shows the desktop, then the complaint is in the lcd/led display unit means the screen. Replace the screen. If the external monitor also shows the complaint, then it is normally due the mch(media controller hub) . It comes as separate card unit in some models and onboard for some other models.Only an experienced technician can solve that issue. In some rare cases it is due to a corrupted BIOS. Reply if this helped you.
Sep 15, 2014 | HP G70-467cl Notebook Pc Lcd Back Cover -...
Laptop lcd
Replace the LCD, it's faulty.
Apr 02, 2012 | Dell Studio 15 Laptop
Have a Acer x223w monitor and it fades to white and then fade to black. I looked at the caps and nothing look blown on both boards. When I turn on the monitor the acer pops up and no signal look fine. But...
Have you verified that the problem is indeed your monitor and not the video card on your PC? i would start by connecting the monitor to a laptop or another PC to verify that the same issue occurs no matter what the source. Once you've verified that, you're likely dealing with a monitor that requires repair or replacement. Hopefully it's under warranty. Hope this helps a bit.
Aug 13, 2011 | Acer 22" X223w LCD Monitor
My monitor comes on for about three seconds when I turn the computer or the monitor off/on and then it fades to black. It looks like the computer is booting up fine when I can briefly see the screen but...
Connect the monitor to the "video-output" port on your laptop, to see if the monitor is working correctly.
You make have to tell the laptop to send the video-output to "both" the internal LCD screen and the external monitor.
If it works, then your monitor is OK.
Restart your computer, and keep tapping the F8 key, until you get a menu of startup items. Choose the 'VGA' startup option, to select the "minimal" device-drivers for your video-card. With the "minimal" drivers, your monitor should still be working.
May 31, 2010 | Computers & Internet
Screen fading to black
Get your monitor repaired by a professional technician. Its due to the picture tube getting bad. these are initial stages, so maybe it can be repaired. Later you'll only have the option to buy one...
Jan 09, 2010 | Computers & Internet
I have an acer p241w and half the screen is faded almost to black right side barely visible eventually turns all black. I turn monitor off and right side comes back on but left side is faded to almost...
HELLO I CAN HELP WITH YOUR ACER THE PROPLEM YOU GOT IS THAT CONDENTSATION HAS GOTTEN IN TO YOUR PC OR LAPTOP AND HAS GOT ONE OF THE CERCITS WET TRY THIS PUT YOUR PC OR LAPTOP IN TO YOUR AIRING COBORD FOR 24 HOURS AND THAT SHOULD RESOLVE YOUR SCREEN PROPLEM
Jul 14, 2009 | Acer Computers & Internet
Black screen after returning from florida
plug in > if charge light comes on and screen black proceed.... if no charge light comes on on laptop your charger's not working
plug into external monitor > if the external monitor works fine with laptop then your LCD is not working, you can look for the Function key (should be bottom left) and the monitor button (probably f7) and switch back and forth... this should tell you if the lcd works or not.
Apr 20, 2009 | Gateway MX6027 PC Notebook
Monitor stuck on black, menu buttons not responding
It's sort of a solution, but I work in a computer shop and got this screen in yesterday. I looked at it closely and it's actually the backlight that died. I pulled it apart and found that three of the 820uF/20V capacitors had swollen up. If you replace them then you should be fine, but I went for a different approach and took the inverter board from a laptop and put the in the screen and used an external power supply. It's a bit dark but it works fine now.
Aug 08, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Laptop screen will not come on
What you do is when you switch on your laptop, Try to press F2 to go into BIOS or do anything so that your computer won't boot into windows. My question is incase you're in BIOS setup...can you see anything on screen ??? if no then try to look more seriosly that anything???? if no then last test is to plug external monitor..incase nothing on external monitor also then you've problem with your notebook maybe motherboard or screen problem.
Goodluck,takecare.
May 08, 2008 | HP Compaq Presario V2000 Notebook
Dell inspiron 8500 notebook monitor died
replace screen easy to pop put and in buy the part u need on ebay ok when your ready ill walk u throw it all mark me as fix ya then add me to yahoo mssg nick_helpap ok
Jan 28, 2008 | Dell Inspiron 8500 Notebook
Dell Inspiron 9400 Notebook Logo
279 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
