Question about Cell Phones
I need to know how to program the memory buttons on my Nortel Jazz 4200, I can't find my manual or remember how to do it...
Hit save
Enter Number
Hit save
Select memory spot
Took me 6 months to find this answer.
Posted on Feb 16, 2013
  • 4 Answers
Found manual - works as described, extra tip from manual -
"Tip: if you need to insert a pause between numbers, press the Redial key. For example, you might want to insert a pause if you have to wait for a dial tone or if you need to have a pause to access your office voice mail." and "You can change a number for an Autodial key by following the same steps for programming."
Extra note for <Flash> and <Hold> buttons
Flash is for call waiting service - press <Flash> when on a call and want to switch to incoming call or make new call.
Hold is for placing call on hold (turn off mic) - press <Hold> when on a call to mute (press again to take off hold), hang-up if need to switch to other receiver (pick-up to take off hold)
Posted on Jun 09, 2015
  • craig Jun 09, 2015
    "You can program one number up to 16 digits for each Autodial key appearing on the telephone."
When I press memory buttons on one particular telephone in our office they all dial reception. How do I fix this?
PDF]Telephone Features Programming Guide - Avaya Support
https://downloads.avaya.com/css/P8/documents/100142941 AvayaNORTEL NETWORKS is a trademark of Nortel Networks. ... All other trademarks and registered trademarks are the property of their ... One-line and two-line displays . ...Memory buttons . ... Call anomalies for telephones without line buttons . .... Select how you dial your calls . ... Receive a busy signal on an internal call .
Norstar How to program phone how to program voice mail ...
www.phonserv.com/1_PDF_user_guide_meridian_norstar_phone_syste...
Nortel Networks Meridian Norstar How to program voice mail phone feature codes ...Modular ICS KSU must be programmed with an M7310 or a M7324 telephone. ... Lift handset, press Voice Call key or press the Feature button, then press 66 2. .... At the LOG: prompt, enter your mailbox#(extension #. and your password all ...
[PDF]N QRTEL NORSTAR
Jan 18, 2016 | NorStar M7324 Telephone
Not the normal voicemail problems
Before you can do anything you need a M7310. Programming a Nortel voice mail requires M7310. It uses the 3 soft keys under the display to program it. You can get one cheap on EBAY. Next you need to find out what type of Voice Mail System in connected to your Nortel phone system. Below is a link to a Older StarTalk manual. You may have a StarTalk, StarTalk Flash, or a Call Pilot.
http://www.myuserguides.com/Nortel_Norstar_Startalk.pdf#page=15&zoom=auto,-69,407
Below is a link that tells how to reset the System Manager Password.
Reset Admin Password Norstar Meridian and Nortel BCM Help Guides
The default code and password for System Admin is F983 and 1020000 or 1021111. The photo below shows a system admin programming tree. Hope this helps
Charlie
Apr 10, 2015 | Nortel Norstar M7208 Telephone
Norstsar M7208 Corded phone cannot use handsfree feature
Your problem is in the phone system programming. I would need to know how old your main cabinet is in order to tell you how to fix it. On most Nortel systems you use "Feature Key" **266344 (Feature **CONFIG) . You will need to program from a M7310 phone because you need the 3 soft keys under the display which the M7208 does not have. The top 4 keys on the phone are used for programming (2 LEFT & 2 RIGHT) . I'm referring to the 2 vertical rows of keys (5 LEFT & 5 RIGHT). Upper left key is up a menu, upper right key is SELECT, lower left is BACK, and the lower right is NEXT. I believe you need to find the CAPABILITIES menu for your station/extension and use the next button to look for the handsfree setting use the key under the display to change it. The manuals are at http://wedophones.com/Manuals/Nortel/
Aug 30, 2014 | Nortel Norstar M7208 Telephone
Where can I find operating instructions for a Jazz 4400 telephone. I want to change the speed dialing to 10 digit but can't find the original instructions.
Jazz 4400- Programming an Autodial key: 1) Lift handset wait for dial tone 2) Press SAVE key 3) Dial the number you wish to save 4) Press SAVE key again 5) Press the Autodial key that you want to save number to. // Notes: The number can be up to 16 digits. If you need to add a pause (for PBX system) press REDIAL key. //
Jazz 4400 has 10 Autodial keys each can store 2 numbers for a total of 20 saved numbers. Press SHIFT key before Autodial key to access second number. Their is a HOTLINE key to store one frequent or emergency number programmed same as Autodial.
Aug 20, 2014 | Nortel Jazz Plus 4400 Speakerphone -...
How do you transfer a call on a Nortel t7208?
This is usually programmed as one of the 'soft' buttons down the right hand side of the device - subject to the programming of your phone / and the system.
Usually the T7208 is connected to the BCM range of PBX systems - in which case, to transfer a call, you'd use Feature 70. You could, of course, program this into one of the buttons yourself, so you only have to press one button to do so.
Hope this is of use to you. :)
Oct 29, 2013 | Nortel Lands Phones
Deleting contacts from phone
How can I delete stored phone numbers, or changed the saved phone numbers on Nortel Jazz 4400?
Feb 14, 2013 | Nortel Jazz Plus 4400 Speakerphone -...
Need to know how to retrieve voice mail on Nortel M7310 telephone.
Feature 981. Then enter password, default is 0000.
To program a button to do this, 1. Press Feature * 3 2. Push the button you want to program
3. Press the Feature button then enter the Feature Code 981.
May 13, 2011 | Nortel Meridian M7208 Corded Phone
I have a Jazz dv 165 camra. my card is full but I
The kluge solution is to do your memory card housekeeping while you have the card attached to your computer for download.
Jul 26, 2010 | Cameras
How do I change the number on a speed dial
You can program a memory button with a new number or
feature.
External autodial:
1. Press (Feature), ( * ), (#1).
2. Press a memory button.
3. Dial the external number.
4. Press OK to store the number.
5. Label your new button.
Internal autodial:
1. Press (Feature), ( * ), (#2).
3. Dial the extension number.
How to erase memory buttons:
3. Press OK to erase the button.
Alternatively, you can download the Nortel T7316 Quick Reference Card from IdacomUSA, your solution for Nortel Repair and Refurbishing.
Feb 11, 2010 | NorStar T7316E Corded Phone
Need a handset for my Nortel jazz 6000 phone.
You can try to order on this SITE, look on the link if the availability of the handset replacement was on he list.
Hope this helps
Nov 29, 2009 | Lands Phones
Cell Phones Logo
145 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
