Question about Casio Exilim EX-Z55 Digital Camera
Zoom lens part of the body is stuck at half way erect and camera won't turn on...all this happened after i dropped it
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Sep 03, 2010
My nikon lens af-s DX NIKKOR is stuck won't turn
The lens and housing will probably need to be replaced, but I would take it to a camera repair shop and have it checked to rule out other problems before proceeding with repairs.
Jul 03, 2012 | Nikon D40 Digital Camera with G-II 18-55mm...
My Nikon 50-300mm f4.5 lens is stuck at 50mm and will not zoom
There could be several reasons for this. It could have been dropped or damaged in some way, the lubricant may have dried, or something else might have happened. Take the lens to a good camera store and have them do a CLA (clean-lube-adjust) on it.
Nov 25, 2011 | Cameras
I dropped the camera and the zoom lens got off line. It won't close or go back in the camera. It looks stuck and I tried pushing it in but I'm afraid that I might push hard that it'll break...
The lens may be fixable but most likely will need to be replaced.
If the lens is stuck straight or won't come out at all it needs to be replaced.
If the lens is stuck at an angle then you may be able to snap it back to the center by pressing the edge of the lens back towards center while holding on the outer ring of the lens.
Hope this helps!
Thomas Drayton
Owner, www Darntoothysam com Digital Camera Repair
Jul 21, 2011 | Canon PowerShot SD1200 IS / Digital IXUS...
Lens stuck out
The lens has probably got something in the retraction mechanism that is stopping it retracting. This can be something as simple as sand or grit or as a result of a drop or knock. In most cases the camera will need to be stripped apart to remove the lens assy before it can be repaired. This is best left to a professional camera repair shop.
Jan 22, 2010 | Casio Exilim EX-Z77 Digital Camera
Zoom Lens stuck out, won,t close. Says camera problem #E45
that error code indicates the the Lens of teh camera is already defective., In most cases if the lens is stuckout or stuckin camera will not stay On or It will not Turn On at all. For this case you need to call Tech support to send you camera for repair toll free 1 800 235 6325 extension 12
Nov 12, 2009 | Kodak EasyShare V530 Digital Camera
My digital Sony camera fell down Lens got stuck
    As in short answer you have to replace the optical lens assymbly.Because due to heavy jurk its motor called sledge motor stsrt malfunctioning and it can not be changed component level. For this please contact any SONY SERVICE CENTRE nearby to you.
Hope you will understand.
Thanks for using FIXYA!
Apr 28, 2009 | Sony Cyber-shot DSC-H7 Digital Camera
Sony Cybershot Camera DSC-S650 won't stay on.
that happen to my camera, exactly same thing. and i figured out when i dropped it the zoom out zoom in lens was bent and stuck part way in camera. My brother was playing around and moved lens and it started to work again. If lens looks a little crooked try moving it or putting it straight. Hope it helps
Nov 08, 2007 | Sony Cyber-shot DSC-S600 Digital Camera
Frozen lens and shutter
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Sep 06, 2007 | Canon PowerShot A510 Digital Camera
Out of focus
Sounds like the camera is trying to focus if you hear sound when pressing the shutter halfway down or zooming. If the noise is a scraping or grinding sound, you might have debris stuck between the cracks of the lens and the camera body. This happened to me after i dropped my canon sd550 on the beach just once and it never recovered. Next to water sand has got to be one of a camera's worse enemy. Also, the lens might be cocked a bit which would prevent the camera from focusing and zooming smoothly. Try gently adjusting the the lens. Sometimes the slightest imperfection in the lens will throw everything off. Good luck!
Apr 11, 2007 | Kodak EasyShare Z760 Digital Camera
Digi camare
The lens on your camera has become stuck due to being dropped, contamination such as sand, or a malfunction within the lens. If gently manipulating the lens itself does not free it then you will need to get it professionally repaired or replace the camera. David Millier Advance Camera Repair
Feb 07, 2007 | Fuji FinePix F401 Digital Camera
Casio Exilim EX-Z55 Digital Camera Logo
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
