Question about Sony DCR-HC32E DV Digital Camcorder
Touch screen dosnot work when I push the key on the monitor and only recording and display
    Scholar:
  • 95 Answers
If you still have an image in the LCD but the touchscreen doesn't work, you most likely have a bad LCD flex cable. This would need to be repaired by an experienced technician.
www.austintelstarservices.com
Posted on Sep 03, 2010
How to turn on
What?............Oh, okay.............I was going to watch this Disney movie though..........
JUST KIDDING!
http://www.asus.com/ph/Notebooks_Ultrabooks/ASUS_VivoBook_X202E/
1) Laptop OFF, monitor OFF, attach a VGA monitor to the VGA port, on the laptop.
(Right side, all the way to the back)
Or you can use the HDMI port, and use an HDTV.
The HDMI port is on the Left side.
Turn the monitor/TV on.
Turn the laptop on.
Does a display show on the external monitor/TV?
No?
Hold the Fn key down, and tap once on the F8 key.
The F8 key is the Display Toggle-Over key.
Go to what you are using as an external monitor. VGA monitor, or HDTV. Hold the Fn key down, and tap the F8 key until you get what you want.
Have a display on the external Monitor/TV?
Problem is NOT the graphics chipset.
Problem is the Video Cable, or LCD/Touch screen.
Post back in a Comment, as to the results of the external monitor test.
Regards,
joecoolvette
F8 key is display toggle over
Apr 25, 2013 | ASUS VivoBook X202E-CT033H Touch Laptop, 1...
Where can i find a display screen for my acer liqiud mini e310? all what i find when i search is touch screens and i want the display one!
I'm assuming you want to hook up an external monitor? If that is the case than any with a VGA hook up, which is most monitors will work. You simply plug in the VGA cable from the netbooks vga port to the port on the monitor. You will need to from the FN key + one of the F# keys that says LCD or has a monitor icon. You can toggle to netbook only, netbook + external mirrored, external only. You can also configure it for extended display and use both displays at the same time.
Monitor Link
Jan 26, 2013 | Acer Computers & Internet
My screen doesnt work. it stays black when i turn the laptop on
If the laptop sounds like it is running and you have no display you can try to plug in an external monitor to it. (any computer monitor will work, just plug the data cable in to the blue VGA receptacle on the back or side of your laptop). Turn on your laptop and look at your function keys on the keyboard. One will have a monitor symbol (maybe F4). Push that function key to switch to external monitor. If it displays on the monitor then you know your computer is okay and that the problem is with your LCD screen. If there is no display then most likely you have a bad video chip on the motherboard and will have to replace the board.
Apr 07, 2011 | Acer Computers & Internet
I have purchased an AOC 22" monitor to connect to my laptop >>>>>i have connected it but it does not display. What is wrong.
Depending on the laptop. Most have a key on the keyboard to toggle external display. Usually, you have to hold the function key [FN] then push the external display toggle.
Feb 23, 2010 | Computers & Internet
Screen not working
It could be the 'back light' is burned out.
Or
Press Fn and F5 simultaneously to make sure the display
priority is not set for the built-in screen.
Or
Press the 'brightness up' key a few times.
Display problems
Here are some typical display problems and their solutions:
The screen is blank.
Display Auto Off may have gone into effect. Press any key to
activate the screen.
You may have activated the instant password feature by pressing
Fn and F1 simultaneously. If you have registered a password, press
any key, type the password and press Enter. If no password is
registered, press any key. The screen reactivates and allows you to
continue working.
If you are using the built-in screen, make sure the display priority is
not set for an external monitor. To do this, press Fn and F5
simultaneously (once). If this does not correct the problem, press Fn
and F5 simultaneously again to return the display priority to its
previous setting.
HINT: Holding the Fn key and pressing the F5 key several times will
advance you through the display options.
If you are using an external monitor:
❖ Check that the monitor is turned on.
❖ Check that the monitor’s power cord/cable is firmly plugged in.
-- Try adjusting the contrast and brightness controls on the
external monitor
Aug 07, 2009 | Toshiba Satellite L305-S5907 Laptop
Monitor flashes on then goes black.
I think you have the display shut off. the button on the bottom left will shut screen off. It will come on for a few seconds if you touch the screen, but will shut off again. just push the display button again and it should stay on.
Apr 02, 2009 | ViewSonic OptiQuest Monitor
Westinghouse L1916HW Monitor On-Screen Display keys malfunction
Hi!! I have a Westinghouse L1916HW 19" DVI LCD 2ms Widescreen Monitor and it turns itself off . Sometimes it works without problem for long time or just for 15 mins, and after turn on it several times the problem disappears. Now,when it is working without the problem, sometimes the volume menu appear on the screen without touch the monitor and if you try to close it, appear again.. I am using it with Windows 7. I need help. Now, I have a router wireless close to it, Can it affect the monitor?
Dec 14, 2008 | Computers & Internet
Connecting a Compaq nx6310 laptop to a bigger monitor
Should be Function Key and F4 (or a similar FKEY will show a monitor screen)
Press 1x to push image to ext. monitor
Press 2x to have dual display
Push 3x to just have laptop screen
Dec 08, 2008 | HP Compaq WF1907 Monitor
Monitor is connected to laptop jack and displays "no signal"
You have to activate the video out of the laptop.
Two ways to do this depending on how you want to use the monitor.
To use the monitor by itself laptops have shortcut keys.
Usually they involve using the Fn key and one of the F keys (Usually F3-F4-F5) KEy will either show two screens or say CRT-LCD
Pushing both keys at once will switch you to both screens, pushed again will just run the monito, Pushed again will return you to the laptop screen.
If you want to use the monitor as an extension of the monitor to be able to drag windos over to it then go to your display properties from the control panel and activate the monitor in the settings box. You'll have to click the monitor first then activate it as a extension and adjust the resolution here.
Fran
Oct 16, 2008 | Acer AL1916W 19" LCD Monitor
Sony DCR-HC32E DV Digital Camcorder Logo
81 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
