Question about Refrigerators
I just bought a used refridgerator and it seems to make a buzzing, rattling noise at times then stops. Then it will start again later. The girl I bought it from said the coils may need cleaned or it may need adjusted. I have no idea what that means but my husband is upset that I bought this fridge, even though it is alot better then the one we had. Thanks so much for any information you can give to guide me.
    Genius:
  • 1,456 Answers
Hi there
The noise is a very annoying thing in refrigerators but to stop these please do the following.
Pull the refrigerator away from the wall and unplug it.
Find the condenser coils on the refrigerator and clean them. These coils disperse heat, so cleaning them improves the effectiveness of the refrigerator which helps to stop the refrigerator from buzzing. To locate the coils, you will need to check your refrigerator owner's manual as they may be rear mounted or floor mounted coils.
Remove the dust build up on the condenser coils with a vacuum cleaner or condenser brush. If there is a large amount of build up on the refrigerator coils, you can use mild soapy water to more thoroughly clean them.
Clean the grill on the front of the refrigerator as it will also help eliminate the noise. The grill on front of the refrigerator should snap off and on, but check for screws first. Then pull firmly toward you to remove the grill.
Do these troubleshoots and the buzzing should stop
Posted on Sep 02, 2010
I have an 03 Ford Explorer 4.0 v6. We JUST replaced the timing chains. A week later, I had a belt shred and got that changed as well. Since then, it has started having a little rattling noise, which has...
I would double check the belt tensioner, it may have been damaged during the timing chain replacement. Also if those chains use a tensioner, this could be the culprit as well
Nov 18, 2013 | Cars & Trucks
2005 Honda Accord sunvisor buzz or rattle
has the visor got a slider for the mirror,if so, close it when not in use if not change it for a solid tinted plexiglass visor(no mirror) sorry but females will need to use central mirror for makeup..i am not a sexist by the way .........
Feb 11, 2010 | 2008 Honda Accord
Loud rattling / buzzing noise from engine when cold not seconday air pump or air valve as already replaced.Timing belt,water pump and aux pullies all checked and ok.The colder the weather the louder the...
If the rattling changes with the revs of the engine, it might be that the valve compensators are either worn or not getting enough lubrication. 20V engines have quite small oil passages travelling to the head. They tend to clog up with gunk if the oil change is not frequent enough.
Jun 03, 2017 | 2003 Volkswagen Passat
Maytag Dryer - funny buzz sound and then nothing
my dryer makes a buzzy sound bt it wnt start just make a buzzy sound
Jul 10, 2009 | Whirlpool LER4634J Electric Dryer
Refridgerator
IF THE BUZZING SOUND IS ONLY THERE WHEN THE MOTOR IS RUNNING THAT COULD MEAN ONLY ONE THING.YOUR PISTON IN SIDE THE COMPRESSOR IS NOISEY THE ONLY WAY TO SOLVE THAT IS TO REPLACE THE COMPRESSOR.BEST YOU HAVE A TECH TO ADVICE YOU FUTHER.GOODLUCK.MOHAMED
Jul 21, 2008 | Whirlpool ED2FHEXN Side by Side...
Loud buzzing noise from inside Jenn Air 2389G fridge
i don't know jennair specifically being from england.
however, there is often a fan inside the back panel and the noise you heard was the fan hitting ice. the reason now not heard and fridge not working may be that the ice has built up so much the fan is jammed
Jun 25, 2008 | Jenn-Air JCB2388G Side by Side...
Refrigerator buzzing for 10 seconds every 4 or 5 minutes
Buzzing is usually a fan, like one in the freezer, or back bottom - for cooling the freon. The compressor over-heat usually will make a single click (off) and a few minutes later a click (on). If the fan in the freezer stops working well, the freezer will frost up and the fridge section will not be cold enough.
Apr 20, 2008 | Refrigerators
Dacor refridgerator model # ef488dcbss
Air flow from freezer to fridge box may be obstructed, ck for free flow there, no big steaks in the way of air to lower unit, or may be set too cold. Thats all i got for now, try it.
May 14, 2017 | Refrigerators
Refrigerators Logo
56 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
