Question about Nintendo Super NES Console
When i turn on the snes the screen turns black with no sound or anything. is it the game console or the actual game cartridges?
    President:
  • 894 Answers
Well its possible that your Super NES is starting to die or it might be the gamepacks so clean them out with qutips and rubbing alcohal if that doesn't work the chances are that your console is having an internal problem.
Posted on Aug 12, 2011
If all of your games are doing the same thing, then my guess is that it's the console. Mine started doing the same thing a couple months ago. If you find out how to fix yours, send me a message @ whitewolfbumblebee3@hotmail.com
Posted on Oct 08, 2010
Hi i just got a fc twin and i am trying to get a nes mario/ duckhunt game to go in and i cant figure it out.. i have other games but they wont go in eaither
The front slot is made for NES games such as mario/duckhunt, and the back slot is made for SNES games. Make sure you put them in the right direction as well.
Good Luck,
Rodrick
Apr 22, 2011 | Vs Clothing FC Twin Video Game System for...
M still getting a rainbow effect on my SNES, its extremely noticeable when the screen goes black or is a dark scene, when the colors go down the screen i get green bushes turning blue, blue water turning...
Well I think that there might be an connection problem with inside of the console like the 62 pinconnecter has gone bad or one of the chips is broken you should buy a new one if its that awful.
Dec 16, 2010 | Nintendo Super NES Console
Im still getting a rainbow effect on my SNES, its extremely noticeable when the screen goes black or is a dark scene, when the colors go down the screen i get green bushes turning blue, blue water turning...
Well the cartiage reader is bad and needs to be replaced or some of the pieces inside of the super NES console went bad then. You should buy a new one if its that severe and don't use it any more either.
I am trying to get my old snes to work I plug everything up and when i turn it on the tv goes to a black screen i am using the original rf adapter that came with it model no:nes-003 nintendo rf switch. I...
Try the game with another TV to see if you will have same problem. If you do not have that problem that means the TV you are using is faulty.
Thanks for contacting Fixya.
Jul 06, 2010 | Video Game Consoles & Games
Super NES Console: My super Nintendo gets power (red light turns on) ...
Maybe the one that is not turning on to play game is broken then. Ensure that you have a known-good game cartridge inserted before powering on the SNES console. Most older, cartridge-based game consoles don't boot without a game installed.
Does the power light to the left of the controller ports turn on when you turn on the power switch?
If not, check your power adapter and outlet for functionality and good connection.
Check that the reset switch is not stuck. Wiggle it back and forth through its range of motion a few times. If something sticky gets in there it can get jammed in the reset position, which will prevent any game from booting.
You mentioned that there is no image. Are you getting any sound from your games after waiting a few minutes with everything connected and turned on?
If you hear game sounds or music from the SNES, but see no picture and you've already (really and truly) ruled out the cabling and TV, then you might have a bad main board in the console.
If you don't get any video or sound, then it's not booting your game. You can find other recommendations about how to clean game and console connections, but usually inserting and ejecting a game 10-20 times will knock loose or grind off enough gunk to get a game to boot. Try this, and be sure to use the eject lever instead of ripping the game out to avoid console connector damage. If it's still not working, repeat with another game.
May 18, 2010 | Nintendo Super NES Console
The snes console will say its turned on but on the tv screen nothing will come up, is it broken? can it be fixed?
if your using an AV cable, make sure all the connections are tight both at the console and at the TV or switcher. if your using an old-fashioned RF switch, make sure IT is plugged in tight to the console. check to make sure you have a working game, or clean the cartridge (which often causes a blank screen of death)
Jun 12, 2009 | Nintendo Super NES Console
My Super Nintendo-- Black screen, white lines, buzzing sound
You just need to clean the game. Wipe the gold strip on the bottom of the game with a q-tip dipped in rubbing alcohol.
Jun 04, 2009 | Nintendo Super NES Console
Picture is only black screen with white lines
Are the console and the TV both tuned to Channel 3 or Both to Channel 4. On the SNES there is a little switch on the bottom of the back labelled 3 on one side and 4 on the other.
May 31, 2009 | Nintendo Super NES Console
SNES doesn't display?
The CIC chip, also known as lock out chip, may have gone bad. Here is a quote from a site I found.
"Every SNES control deck has a regional lockout chip (known as a CIC), as does every original SNES game cartridge. Before a game is loaded, the console will attempt to communicate with the CIC chip on the game cartridge. If the CIC chip doesn't respond or does not correspond with the consoles CIC, the console won't load the game. In most cases, a black screen is displayed."
http://www.chronicgames.net/articles/snes-museum.aspx
Yea basically I am having the same prob with my system and I am trying to fix it. Ill let ya know if i figure it out
Jun 14, 2008 | Nintendo Super NES Console
SNES Game/System incompatibility?
check your connections, try cleaning your snes system with some rubbing alcohol (the party where the game connects to the system), you might have to take it apart to do that...
one way we use to do with the NES was cut a piece of paper out to fit inside the game, make it wet with rubbing alcohol, then push the game in and pull it out a few times (of course if the paper gets stuck you'll have to take it apart to get it out.
SNES's are pretty cheap so u may have to purchase a new one
Jan 06, 2008 | Nintendo Super NES Console
Nintendo Super NES Console Logo
394 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
