Question about Frigidaire FRS26KW3AW Side by Side Refrigerator
Started making a click on click off noise. Completely stopped cooling and freezing during the night and smelled smoke while unloading contents. 8 years old. Worth trying to fix? Buy new?
5 Suggested Answers
HVACRH20
  • 237 Answers
SOURCE: Our refrigerator/freezer will stop working (not cool or freeze) then days later will begin to work again.
It's either the start device on the compressor or you have a bad compressor. You'll have to pull it away from the wall and take the bottom back panel off to check the compressor. It will likely be real hot to the touch from what you described happening. If there is a little white colored box on the left side take that off and remove the wires, etc. and shake it... if it rattles and debris falls out then that's the problem. It's fairly common and they make a kit to replace it with a better designed part that's real easy to install yourself. If your compressor has a label on it with a blue indian head symbol, then you're out of luck as that brand pretty much sucks and is destroyed by heat. It would mean a new compressor and then you'd be lucky if the new one even worked from the factory. Avoid those Tecumseh compressors at all cost.
Posted on Jan 08, 2007
Cerfer39
  • 709 Answers
SOURCE: GE Frigerator has intermittant Freezing
It sounds like the defrost heater is burned out. Remove the inside back cover in the freezer to see if the coils are frozen up. If so, more than likely your defrost heater has bit the dust. It is located at the bottom of the inside coil of the freezer.
Also, you could be have a clogged condensor coil. It is located on the out side back of the Fridge. You need to remove the panel from the lower part of the fridge and do a thorugh cleaning.
Posted on Nov 03, 2007
  • 408 Answers
SOURCE: 5 year old refrigerator stopped cooling
Sounds like your refridgerant compressor or the motor driving it has bit the dust.  I am assuming it does not kick on or you can't hear it running.  Call a local appliance repair to get a quote, but 9 times out of 10, it is cheaper to replace the fridge.  A motor and compressor can cost upwards of 300-600 bucks.  That is just from my knowledge and your model may be higher or lower.  Best to get an appliance guy to take a look.
Posted on Mar 11, 2009
  • 358 Answers
SOURCE: MOD FRS6B7EESB5 - Stopped cooling, fan is working,
Replace the relay (no more than $20) and if still won't start the compresor has to be replaced.
Posted on Aug 19, 2009
My refrigerator started smelling like burning electrical wires, it was clicking, then this smoke started coming out the back bottom of the refrigerator. What happened?
it sounds like the motor or electrical conections have burnt out, does it still turn on or has it stopped working completely?
Jan 30, 2012 | Kenmore Refrigerators
Hello! My Frigidaire FAH086N1T Thru-Wall/Window Air Conditioner was on the fan setting (high) and it started smoke and smell burned. What happened?!
Hi, it sounds to me like you are loosing this motor. Normally when a blower motor fails, which in your case you have a dual shaft motor which also cools the outdoor coil, the condenser, and blows cool air indoors. If it started blowing smoke inside and you smelled an electrical smell, it was either the motor has a burned spot on the armature from dirt or age. If the motor seems to be running ok, try switching it to cool to see if the compressor is working, and do this to all positions on the selector switch. Wait about 5 minutes in between. If all is working properly, its only a matter of time before the motor fails completely. I would run it until it dies out. There are many safetys on the unit, so you are in no danger of a fire when it fails, it will just make noise and freeze up. You will save money if you replace the complete unit and not the motor. If you call out a tech they will remove it and take it to there shop to make repairs charging you by the HR, and this will add up including the cost of the dual shaft motor.Please take my advice as I have had to do this many times before.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Ps, Please keep me posted and be kind in rating any help I have been to you? Thank you!!
Aug 28, 2011 | Frigidaire FAH086N1T Thru-Wall/Window Air...
My fridge/freezer made a buzzing noise, then hot smell, then smoke then stopped cooling/freezing. It is still running and powered on, no more smell, smoke, etc.
need model #` but it sounds like a control board . .. more info needed .. to help you more mod ser # .. sxs ? or top freezer things like that .. but it sounds like a main control board .. mm hope this helps feed back pls ..
Jul 09, 2011 | Maytag Refrigerators
Washer make noise doing spin cycle smell smoke make the power cord warm to touch
Thanks for choosing FixYa and welcome to the site Joe. Usually, if a washer makes noises during spinning, it means the drive basket is broken. Make sure your pulley's are not sticking and rubbing the belt. This causes the basket to be unstable during the spin cycle. As far as the smell of smoke, try checking the belt and make sure it is not worn or loose. Inspect the motor to check for noises, grinding, or smoke. Your transmission may be burning up. Usually, the cord will remain warm, but not hot. The washer may be working extra if a belt is sticking or during the spinning process. If you have any other questions Joe, just let me know. Thanks for using FixYa.
Mar 31, 2011 | Kenmore Washing Machines
My hard drive has been making a clicking noise for a while, the computer freezes up at times, I do not think the cooling fan is working, could this cause the issue with the hard drive making noise, and if...
More than likely, your hard drive is failing. This COULD be the cause for the freezing. The other thing that could cause the freezing is if the processor is getting too hot due to the failed fan. Either way you will need to have your HD replaced before it fails completely. The clicking you are hearing is the read head hitting the case of the hard drive. It might have started from being too hot. If the parts of your computer are getting too hot, it will increase the chances that they will fail in the future.
Jan 24, 2010 | Dell Inspiron 530 Desktop Computer
Stopped working, burning smell, clicking noise while plugged in.
have a technician check it out. burning smell is always fire hazzard. A connection may have gone loose or connections are soaked.
May 12, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Freezer not working , clicking noise coming from fridge
Clicking was a relay. Replaced relatively inexpensive relay and now working fine.
Jan 17, 2009 | Jenn-Air JCD2389G Side by Side...
Heating system outlets
1st, the fuse location is marked, what is the 20 Amp fuse for? 2nd, did the smoke have a nauseating sweet smell to it? If it smells like described it is the heater core leaking, coolant steam looks like smoke.
Nov 02, 2008 | 1994 Jeep Grand Cherokee
98 f150 4.2 110.000 miles went to start up engine started clacking and smoking out exhaust
the intakes go bad on these engines....... they leak coolant in the cylinders and cause a hydro lock that causes the rods to bend making the piston skirt hit the crank......" clicking noise" theres a law suit in progress for this issue......... you can find info on the internet
Oct 15, 2008 | 1998 Ford F150 Regular Cab
Frigidaire FRS26KW3AW Side by Side Refrigerator Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
