Question about Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph
Pump makes the sound of working but the water is not sucking in or pushing out
  • Intex Master
  • 8,404 Answers
Your impeller has probably broken
Posted on Sep 26, 2010
Condensate drain sucking sound
Sounds like a dirty float switch, making the pump work when there isn't much water in the trough. If you can remove the central fan there is a panel in the corner that unscrews. The pump and float switch are in there. Wear a dust mask - it'll be pretty dirty in there!!!
May 17, 2012 | Heating & Cooling
I have a Kenmore ice maker that makes a sucking sound while cycling. The water pan will not fill up all the way between cycles and my ice harvested is thin and cloudy. Do I have a pump problem? Can it...
It sounds like your water supply line might be partially clogged probably at the water inlet valve in the bottom left front of the machine. I think there is a screen in there that you can clean out. The circulation pump will make a sloshy surging sound when not enough water is cycling through it as it pumps it up to the ice making sheet. You may need to replace the inlet valve itself. Pour extra water into the water reservoir in the interior of the machine and see if the pump runs smoothly thereafter.
Dec 31, 2010 | Kenmore 51lb. Clear Ice Maker
Pump not sucking in water what would cause this?
These pumps are not designed to **** water like some might think. There is going to be some vacuum created for the fact that it is an axial pump. You really should have a water supply pushing water to the unit instead of trying to use it to **** water.
I have used a pump like this to **** water but it only would pull water from a 6 to 7 ft hose and nothing longer. If it use to **** before then it sounds like your low pressure valves in the pump are becoming worn out and would have to be replaced.
Oct 21, 2010 | Comet GXD2527G Pressure Washer Pump
I have the Oreck Sanapathic DMS2000 Handheld Steam Vacuum, but no steam comes out when I push the button. I hear the motor, is there any buttons I am missing or any help on how to make it work, been...
ORECK DMS2000 No Steam
First, tested tank and filter flow together using suction via
plastic tubing. Worked freely Second, removed pump
and disconnected hoses and terminals [watch location,
three terminals on pump, two plugs]. Pump has a slug inside
and I could blow water either way. Sucked white vinegar
both ways until check action returned. Use distilled water
in future!
Apr 26, 2010 | Oreck Sanapathic DMS2000 Handheld Steam...
Pump runs too long
Install a float switch that will switch-off the pump once the water reaches its level.
Feb 23, 2009 | Genius Wayne Submersible Sump Pump With ...
Kitchenaid dishwasher sucking noise when ON
the sucking noise is the water valve, opening but it doesn't not sound it getting any water in. have the water valve replaced.
do you get any error messages on the display?
Sep 13, 2008 | KitchenAid 24 in. KUDS01FLBL Built-in...
Will not wash
sounds like the circulating pump. could be a foreign object stuck in the pump impellor. could also be the pump capacitor - cheap part
Sep 03, 2008 | Kenmore 24 in. 16693 Built-in Dishwasher
Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph Logo
118 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Colin Stickland
Colin Stickland
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
