Question about American Standard 4021 White Cadet 3 Toilet Tank Lid
HAVING TROUBLE WITH THE RUBBER SEAL. WHEN I TIGHTEN THE BOLTS AS FAR AS I CAN THE TANK STILL WOBBLES,HOW CAN I SOLVE THIS PROBLEM
  • 707 Answers
You will have some movement..........If to much movement use shorter bolts or build it up eith wasers.
Posted on Sep 04, 2010
Seal between tank and base leaks
Get a new seal and apply some Vaseline to help seal it . When putting tank on, nestle it in place and then tighten the tanks bolts to the bowl evenly and securely . The rubber washers should compress some to make it snug.
Jan 19, 2013 | Sterling Home
Repairing toilet. Replaced hardware and seal between tank and bowl. The seal is a black rubber material that fits around the 3" diameter opening. It has extensions on two sides of the seal where...
Look to see if the rubber seal got twisted or folded or out of place some how. Also check to make sure tank screws go through holes in extensions and did not just punch their own holes. check to make sure everything is tight, but don't tighten so far as to crack the bowl. Also look and make sure the tank is level compared to the bowl if it is crooked it may mean the rubber is out of place. Good luck,
Jun 19, 2011 | Eljer Home
How tight should I tighten the tank to the bowl on the American Standard Champion Toilet?
There is no torque value as far as I know. There should be rubber washers to minmize the chance of cracking the ceramic and to provide a water seal.
But to try to give some sort of guideline, on a scale of 1 - 10, I'd say a 6 would be about right -- or perhaps you could call that medium tight. In any event, the bolts have to be tight enough to prevent leaking -- if it leaks, you'll have to keep tightening.
Charlie
Mar 28, 2011 | American Standard Traditional Champion4...
Replace toilet tank bolts
Go to a plumbing supply house and get 2 or 3 bolts, 2 or 3 rubber sleeves for the bolts, and a new rubber gasket to go between the tank and toilet. Turn the supply water off, sorry, but, you don't know how many people don't do that. Disconnect the supply line from the tank. Flush the toilet, to remove water from the tank. Unbolt the tank. On the back underside of the toilet, you have 2 or 3 nuts to remove, depending on the toilet. Lift off the tank. Turn over the tank and set it on a towel. Now, gently tap down the bolts. Turn tank over and pull out the bolts. Turn tank back over and remove the tank and bolt gaskets, just push them in. Turn tank over. push in the new gaskets. Replace tank gasket, and gently tap down new bolts. Remount the tank. tighten the nuts, be careful, always tighten the nuts about the same. never tighten one all the way, and then another. YOU can crack the tank when tightening. Just nice and snug. Re hook the water supply, and turn on. Always check for leaks. If dripping, just tighten a little more. Just remember to tighten the all the nuts a little at a time. Keeping the tank level when tightening.
Dec 24, 2010 | Sterling 402315-0 White Windham Two-Piece...
Toto Pacifica Gmax elongated toilet problem. Same problem I cannot solve. I can replace the flapper, no sweat. But I have replaced the large ring gasket, located on the plastic exit port of the tank,...
Hi, Dayne here
Those large gasket seldom leak unless the two bolts are not tight enough. DO NOT over tighten. The water is probably coming from the bolts themselves. The rubber washer goes on the inside of the tank, and then a nut should be on the outside with a metal washer. Tighten pretty tight, but not too tight.
Thanks.
Dec 12, 2010 | Home
I am installing 2 new american standard champion 4 toilets and on both of them the tank will not sit on the base. the thick rubber gasket seems to be too thick to allow this. i don't want to crank down too...
The reason the tank doesn't sit down on the bowl is cause it's not supposed to just sit flush from the start. Your suppose to tighten the tank bolts down in order to get a water tight seal. There is also these little rubber " U " shaped things that sit on the porcelain lip on the back of the bowl thats what's there to protect it from cracking when you tighten the bolts down. Just place 1 on the right side and the the other on on the left side. and tighten down 'til the tank touches the bowl.
Nov 17, 2010 | American Standard AMERICAN STD 12 RGH...
The big black washer between the tank and bottom is deteriorating also the black washers on the bolts that hold the tank to the bottom are coming apart and the tank is leaking
Any hardware stores where plumbing supply is sold including lowes and home depot sell toilet seal kits including toilet to tank seals as well as toilet rebuild kits. Ask for a toilet to tank seal and washers for the bolts which might come with the large seal(check)
1. Close toilet water valve
2. Drain tank or sop with a towel and squeeze into tub until toilet is empty or bail water out with a cup.
3. Remove two tank bolts
4. clean area where old seals were
5. put tank seal on bowl and set tank lining it on top of seal.
6. Install tank bolts with new seals and tighten evenly
7. Don't over tighten or tank will crack. You probably can tighten until tank and toilet touch evenly on both sides.
8. Fill and check for leaks.
Aug 19, 2010 | Jacuzzi Home
Cannot get the bolts and rubber washers to seal properly in the holding tank of our new TOTO Drake toilets
Some manufacturers specify only to use rubber washers inside the tank, and only one bolt on bottom. I usually assemble the bolt with one metal washer on bolt ( or bolt with large head) then a rubber washer, then through tank, then another washer, then a metal washer (brass or stainless) then another nut. Snug these nuts up tight, but be careful not to over tighten or you'll break the tank. Do this to all the bolts. Then set the tank on bowl, with the bolts extending through the bottom. Make sure your gasket is up all the way on the nipple, so the tank will tighten to the stops on the bowl. Now put another set of rubber washer, and metal washer and nut (thumb nuts are fine here) Tighten till tank doesn't rock and is resting on stops. Now it doesn't have to be so tight, as the bolts are already tight in the tank. You can get a fluidmaster bolt kit at home depot that has enough bolts, washers and all
Aug 02, 2010 | Toto Home
Installing new jacuzzi 1.6 gallon maxima toilet. despite following the instructions, the water is leaking from between where the tank connects to the bowl. Please help.
Yes, it seems the folks who wrote the instructions have never actually done any plumbing.
first place a rubber washer on the bolt, then put it through the hole in the tank. Then place another rubber washer on the bolt, followed by a metal washer and a nut. Tighten the nut, not the bolt.
Using a screwdriver hold the bolt in place, and tighten the nut until snug and the rubber washers are compressed slightly.
Follow this step with all the "tank to bowl" bolts.
Now the bolts are tight to the tank and will not leak water.
Then place the large rubber gasket over the flush valve hole on the bottom of the tank. and set the tank on the bowl with the bolts through the bowls holes.
Place a metal washer on the bolt, and then a nut.
Tighten each nut equally until the tank has no wobble.
Oct 01, 2009 | Jacuzzi Bath Maxima EL61 959 White...
American Standard 4021 White Cadet 3 Toilet Tank Lid Logo
182 people viewed this question
Top American Standard Home Experts
Donni Steen
Mike
john h
Are you an American Standard Home Expert? Answer questions, earn points and help others
