Question about GE Adora (DSF25KGTBG) Side by Side Refrigerator
Water coming out very slow - GE Adora (DSF25KGTBG) Side by Side Refrigerator
    Problem Solver:
  • 23 Answers
Check for a crimped water supply located behind the unit...Also check that te shut-off valve is fully open
Posted on Sep 02, 2010
Why would the water be coming out really slow in my refrigerator
your water filter or lines to and from the water supply to the filter and to the dispenser can be plugged with lime,also if you use a saddle tap from the water line in the house feeding the dispenser hose they can plug up with lime also
Apr 08, 2013 | Frigidaire Refrigerators
Slow fill of tank after flush
Why do say a lot of waste? Is not the water going into the tank. Is the water slow coming into the tank? Sounds like the valve letting the water in is blocked with sediment thus keeping the water from coming in. You may just need a new float assembly
Mar 28, 2013 | Home
Can water flow be adjusted water comes out very slow
Yes, providing the water filter has been changed regulary. That would be number one reason for water slowing down. If you hae done that we will work with supply, Sea Breeze
May 19, 2010 | GE GSS25SGPSS Side by Side Refrigerator
Water going into machine slow, water coming from
there will be either 2 or 3 screws on the rear of the lid,remove and slide the lid backwards, lifting slightly on some models.
Oct 04, 2009 | Washing Machines
Water in door too slow coming out
A strainer before the inlet valve can get stopped up restricting flow. It's on the back where the water supply connects.
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then see how fast the water comes out when you try the dispenser. If it's slow here there is a valve our water supply problem. If it's normal, disconnect it at the bottom of the freezer door and try again.If it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
Sep 20, 2009 | Refrigerators
Why would the water start coming out very slow?
If you are referring to water coming out the fountain it could be a leak in the system somewhere allowing air into the lines that run the water, if you are referring to water coming out of the ice maker itself you need a new ice maker the lining is bad
Jul 14, 2009 | Kenmore 52632 / 52634 / 52639 Side by Side...
Slow water coming out od water dispencer in door.
first off replac ethe water filter in the unit this will slow down the flow
Feb 15, 2009 | Amana ARSE66MB Side by Side Refrigerator
Cold water will come in verry slow
if your water pressure is good the water valves are bad.
Dec 14, 2008 | Washing Machines
Kenmore wash macine
its in your cold water line valve to the washer if it works good with hot water the valve are incoming line being blocked when you turn it on the pressure comes in fast then when pressure is gone water slows down so when its off the pressure builds back up it runs fast then slow
Feb 27, 2008 | Washing Machines
Water in refrigerator door coming out slow
Hi Ben22 Sounds like some thing pluging the water line or the water line pinched some where.. if the hole was 1/4 inch you should get enough water with that big of a hole. I would check the water line for a obstruction. Let me know if this helps. Krazytech
Sep 29, 2007 | Whirlpool ED5SHAXM Side by Side...
GE Adora (DSF25KGTBG) Side by Side Refrigerator Logo
74 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
